    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 13.8k Views 2 Watching
      bachoo786
      @sdetweil nope its only one version
        sdetweil @bachoo786
        @bachoo786 version = instance… sorry
        pm2 status
        if something is running, shut it down
          bachoo786 @sdetweil
          @sdetweil ok so what shall I do now? I am lost. I always avoid updating my magicmirror as the new update always breaks it.
            sdetweil @bachoo786
            @bachoo786
            please read my posts
            do
            pm2 status
            if anything is running, not stopped then do
            pm2 stop ??
            where xx is the name or number of the item running
            once u have nothing running, then redo the npm start from the MagicMirror folder so we can diagnose the rest of the problem
              bachoo786 @sdetweil
              @sdetweil ok I have done that and here is the result:
              > magicmirror@2.10.0 start /home/pi/MagicMirror
              > ./run-start.sh
              + ./untrack-css.sh
              + '[' -z '' ']'
              + export DISPLAY=:0
              + DISPLAY=:0
              ++ uname -m
              + arch=armv7l
              + false=false
              ++ grep -v '^\s//' config/config.js
              ++ grep -i serveronly:
              ++ awk '{print tolower($2)}'
              ++ tr -d ',"'\'''
              + serveronly=
              + serveronly=false
              ++ pgrep Xorg
              + xorg=519
              ++ uname
              + mac=Linux
              + '[' false. '!=' false. -o armv7l == armv6l ']'
              + '[' 519. == . -a Linux '!=' Darwin ']'
              + electron js/electron.js
              [15:51:26.871] [LOG]    Starting MagicMirror: v2.10.0
              [15:51:26.879] [LOG]    Loading config ...
              [15:51:26.884] [LOG]    Loading module helpers ...
              [15:51:26.924] [LOG]    Initializing new module helper ...
              [15:51:26.925] [LOG]    Module helper loaded: updatenotification
              [15:51:26.926] [LOG]    No helper found for module: clock.
              [15:51:27.306] [LOG]    Initializing new module helper ...
              [15:51:27.306] [LOG]    Module helper loaded: MMM-SystemStats
              [15:51:27.307] [LOG]    No helper found for module: currentweather.
              [15:51:27.308] [LOG]    No helper found for module: weatherforecast.
              [15:51:27.308] [LOG]    No helper found for module: random_quotes.
              [15:51:27.310] [LOG]    Initializing new module helper ...
              [15:51:27.311] [LOG]    Module helper loaded: MMM-homeassistant-sensors
              [15:51:27.697] [LOG]    Initializing new module helper ...
              [15:51:27.698] [LOG]    Module helper loaded: MMM-UKNationalRail
              [15:51:27.699] [LOG]    No helper found for module: MMM-TFL.
              [15:51:27.735] [LOG]    Initializing new module helper ...
              [15:51:27.735] [LOG]    Module helper loaded: newsfeed
              [15:51:27.736] [LOG]    All module helpers loaded.
              [15:51:27.737] [LOG]    Starting server on port 8181 ...
              [15:51:27.744] [INFO]   You're using a full whitelist configuration to allow for all IPs
              [15:51:27.750] [LOG]    Server started ...
              [15:51:27.751] [LOG]    Connecting socket for: updatenotification
              [15:51:27.752] [LOG]    Connecting socket for: MMM-SystemStats
              [15:51:27.753] [LOG]    Connecting socket for: MMM-homeassistant-sensors
              [15:51:27.754] [LOG]    Connecting socket for: MMM-UKNationalRail
              [15:51:27.754] [LOG]    MMM-UKNationalRail helper started ...
              [15:51:27.755] [LOG]    Connecting socket for: newsfeed
              [15:51:27.756] [LOG]    Starting module: newsfeed
              [15:51:27.756] [LOG]    Sockets connected & modules started ...
              [15:51:27.943] [LOG]    Launching application.
              [15:51:29.943] [LOG]    Create new news fetcher for url: http://feeds.bbci.co.uk/news/england/rss.xml - Interval: 300000
              [15:51:29.984] [LOG]    Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 300000
                sdetweil @bachoo786
                @bachoo786 ok, so the node_helper side is working ok…
                now open the developers window, ctrl-shift-i, select the console tab, and scroll up to see any errors
                  bachoo786 @sdetweil
                  @sdetweil I dont have access to the mirror now as I am not home. The thing that stopped working was when I updated MM I cannot access it anymore remotely. Before updating mm I could as my ports are also forwarded.
                    sdetweil @bachoo786
                    @bachoo786 said in Magic Mirror updated now doesnt work:
                    i don’t understand that. update app has nothing to do with ssh type access…
                    if u mean MMM-remotecontrol type access, correct, the mirror app is down for some reason… that is what we are debugging
                      from the prior message, the backend is happy (node_helpers, web server)
                        bachoo786 @sdetweil
                        @sdetweil I mean when I updated my to 2.10 that’s when all the problem started. Before updating my I installed mmm remote control now I don’t know if that module has caused this issue of me not being able to access magic mirror remotely.
                        • 2 / 4
