    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 12.5k Views 2 Watching
      bachoo786
      Hi all
      I have update my MM to 2.10.0 and now my MM doesnt show on the screen. Here are my logs:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.13.4
      3 info using node@v10.18.0
      5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
      6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
      7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr$
      9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.10.0~start: Args: [ '-c', './run-start.sh' ]
      11 silly lifecycle magicmirror@2.10.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.10.0 start: `./run-start.sh`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.10.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.75-v7l+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v10.18.0
      19 verbose npm  v6.13.4
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.10.0 start: `./run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.10.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      Can anyone help please?
      Thanks.
        bachoo786 @sdetweil
        @sdetweil it seems to be working fine now after few reboots to the pi.
          sdetweil @bachoo786
          @bachoo786 how did u update? manual, git pull? or the automated script
            bachoo786 @sdetweil
            @sdetweil git pull but I had to stash as I had made changes to the .css file of one of the modules.
              sdetweil @bachoo786
              @bachoo786 did u also do the required npm install after the git pull??
              apologize, where did u see the instructions?
              many users are having this problem, want to see if I can fix that
                bachoo786 @sdetweil
                @sdetweil I just searched on MM forum I did git pull and after that done the npm install but have problems. I cannot also access the mirror on another machine. I have forwarded the mirror ports too.
                  sdetweil @bachoo786
                  @bachoo786 ok, did the npm install good…
                  please edit the run-start.sh and change line 1 to
                  #!/bin/bash -x
                  save
                  then npm start again
                  also, what modules do you have installed?
                  if they have a package.json, did u do an npm install in those module folders?
                    bachoo786 @sdetweil
                    @sdetweil my run-start.sh already contains the # before !bin/bash-x see below:
                    #!/bin/bash
                      # use bash instead of sh
                    ./untrack-css.sh
                    if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                            export DISPLAY=:0 # Set by default display
                    fi
                    # get the processor architecture
                    arch=$(uname -m)
                    false='false'
                    all my modules have package.json and I did do a npm install. The last module I installed was mmm-remote control via the script that was on the module github page.
                      sdetweil @bachoo786
                      @bachoo786 you missed the -x at the end… turns on bash debug
                      #!/bin/bash -x
                        sdetweil @bachoo786
                        @bachoo786 said in Magic Mirror updated now doesnt work:
                        SINCE you did the magicmirror upgrade?
                          bachoo786 @sdetweil
                          @sdetweil so this is the result:
                          > magicmirror@2.10.0 start /home/pi/MagicMirror
                          > ./run-start.sh
                          + ./untrack-css.sh
                          + '[' -z '' ']'
                          + export DISPLAY=:0
                          + DISPLAY=:0
                          ++ uname -m
                          + arch=armv7l
                          + false=false
                          ++ grep -v '^\s//' config/config.js
                          ++ grep -i serveronly:
                          ++ tr -d ',"'\'''
                          ++ awk '{print tolower($2)}'
                          + serveronly=
                          + serveronly=false
                          ++ pgrep Xorg
                          + xorg=519
                          ++ uname
                          + mac=Linux
                          + '[' false. '!=' false. -o armv7l == armv6l ']'
                          + '[' 519. == . -a Linux '!=' Darwin ']'
                          + electron js/electron.js
                          [15:39:07.703] [LOG]    Starting MagicMirror: v2.10.0
                          [15:39:07.725] [LOG]    Loading config ...
                          [15:39:07.735] [LOG]    Loading module helpers ...
                          [15:39:07.814] [LOG]    Initializing new module helper ...
                          [15:39:07.817] [LOG]    Module helper loaded: updatenotification
                          [15:39:07.819] [LOG]    No helper found for module: clock.
                          [15:39:08.557] [LOG]    Initializing new module helper ...
                          [15:39:08.558] [LOG]    Module helper loaded: MMM-SystemStats
                          [15:39:08.559] [LOG]    No helper found for module: currentweather.
                          [15:39:08.560] [LOG]    No helper found for module: weatherforecast.
                          [15:39:08.561] [LOG]    No helper found for module: random_quotes.
                          [15:39:08.564] [LOG]    Initializing new module helper ...
                          [15:39:08.564] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                          [15:39:09.297] [LOG]    Initializing new module helper ...
                          [15:39:09.298] [LOG]    Module helper loaded: MMM-UKNationalRail
                          [15:39:09.299] [LOG]    No helper found for module: MMM-TFL.
                          [15:39:09.368] [LOG]    Initializing new module helper ...
                          [15:39:09.369] [LOG]    Module helper loaded: newsfeed
                          [15:39:09.370] [LOG]    All module helpers loaded.
                          [15:39:09.372] [LOG]    Starting server on port 8181 ...
                          [15:39:09.389] [INFO]   You're using a full whitelist configuration to allow for all IPs
                          [15:39:09.408] [LOG]    Server started ...
                          [15:39:09.410] [LOG]    Connecting socket for: updatenotification
                          [15:39:09.413] [LOG]    Connecting socket for: MMM-SystemStats
                          [15:39:09.415] [LOG]    Connecting socket for: MMM-homeassistant-sensors
                          [15:39:09.418] [LOG]    Connecting socket for: MMM-UKNationalRail
                          [15:39:09.420] [LOG]    MMM-UKNationalRail helper started ...
                          [15:39:09.421] [LOG]    Connecting socket for: newsfeed
                          [15:39:09.422] [LOG]    Starting module: newsfeed
                          [15:39:09.423] [LOG]    Sockets connected & modules started ...
                          [15:39:09.587] [LOG]    Whoops! There was an uncaught exception...
                          [15:39:09.588] [ERROR]  { Error: listen EADDRINUSE 127.0.0.1:8181
                              at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                              at listenInCluster (net.js:1378:12)
                              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                            errno: 'EADDRINUSE',
                            code: 'EADDRINUSE',
                            syscall: 'listen',
                            address: '127.0.0.1',
                            port: 8181 }
                          [15:39:09.605] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [15:39:09.605] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [15:39:09.652] [LOG]    Launching application.
                          • 1 / 4
