    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 16.9k Views 2 Watching
      bachoo786
      Hi all
      I have update my MM to 2.10.0 and now my MM doesnt show on the screen. Here are my logs:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.13.4
      3 info using node@v10.18.0
      5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
      6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
      7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr$
      9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.10.0~start: Args: [ '-c', './run-start.sh' ]
      11 silly lifecycle magicmirror@2.10.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.10.0 start: `./run-start.sh`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.10.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.75-v7l+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v10.18.0
      19 verbose npm  v6.13.4
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.10.0 start: `./run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.10.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      Can anyone help please?
      Thanks.
        bachoo786 @sdetweil
        @sdetweil it seems to be working fine now after few reboots to the pi.
          sdetweil @bachoo786
          @bachoo786 how did u update? manual, git pull? or the automated script
            bachoo786 @sdetweil
            @sdetweil git pull but I had to stash as I had made changes to the .css file of one of the modules.
              sdetweil @bachoo786
              @bachoo786 did u also do the required npm install after the git pull??
              apologize, where did u see the instructions?
              many users are having this problem, want to see if I can fix that
                bachoo786 @sdetweil
                @sdetweil I just searched on MM forum I did git pull and after that done the npm install but have problems. I cannot also access the mirror on another machine. I have forwarded the mirror ports too.
                  sdetweil @bachoo786
                  @bachoo786 ok, did the npm install good…
                  please edit the run-start.sh and change line 1 to
                  #!/bin/bash -x
                  save
                  then npm start again
                  also, what modules do you have installed?
                  if they have a package.json, did u do an npm install in those module folders?
                    bachoo786 @sdetweil
                    @sdetweil my run-start.sh already contains the # before !bin/bash-x see below:
                    #!/bin/bash
                      # use bash instead of sh
                    ./untrack-css.sh
                    if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                            export DISPLAY=:0 # Set by default display
                    fi
                    # get the processor architecture
                    arch=$(uname -m)
                    false='false'
                    all my modules have package.json and I did do a npm install. The last module I installed was mmm-remote control via the script that was on the module github page.
                      sdetweil @bachoo786
                      @bachoo786 you missed the -x at the end… turns on bash debug
                      #!/bin/bash -x
                        sdetweil @bachoo786
                        @bachoo786 said in Magic Mirror updated now doesnt work:
                        SINCE you did the magicmirror upgrade?
                          bachoo786 @sdetweil
                          @sdetweil so this is the result:
                          > magicmirror@2.10.0 start /home/pi/MagicMirror
                          > ./run-start.sh
                          + ./untrack-css.sh
                          + '[' -z '' ']'
                          + export DISPLAY=:0
                          + DISPLAY=:0
                          ++ uname -m
                          + arch=armv7l
                          + false=false
                          ++ grep -v '^\s//' config/config.js
                          ++ grep -i serveronly:
                          ++ tr -d ',"'\'''
                          ++ awk '{print tolower($2)}'
                          + serveronly=
                          + serveronly=false
                          ++ pgrep Xorg
                          + xorg=519
                          ++ uname
                          + mac=Linux
                          + '[' false. '!=' false. -o armv7l == armv6l ']'
                          + '[' 519. == . -a Linux '!=' Darwin ']'
                          + electron js/electron.js
                          [15:39:07.703] [LOG]    Starting MagicMirror: v2.10.0
                          [15:39:07.725] [LOG]    Loading config ...
                          [15:39:07.735] [LOG]    Loading module helpers ...
                          [15:39:07.814] [LOG]    Initializing new module helper ...
                          [15:39:07.817] [LOG]    Module helper loaded: updatenotification
                          [15:39:07.819] [LOG]    No helper found for module: clock.
                          [15:39:08.557] [LOG]    Initializing new module helper ...
                          [15:39:08.558] [LOG]    Module helper loaded: MMM-SystemStats
                          [15:39:08.559] [LOG]    No helper found for module: currentweather.
                          [15:39:08.560] [LOG]    No helper found for module: weatherforecast.
                          [15:39:08.561] [LOG]    No helper found for module: random_quotes.
                          [15:39:08.564] [LOG]    Initializing new module helper ...
                          [15:39:08.564] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                          [15:39:09.297] [LOG]    Initializing new module helper ...
                          [15:39:09.298] [LOG]    Module helper loaded: MMM-UKNationalRail
                          [15:39:09.299] [LOG]    No helper found for module: MMM-TFL.
                          [15:39:09.368] [LOG]    Initializing new module helper ...
                          [15:39:09.369] [LOG]    Module helper loaded: newsfeed
                          [15:39:09.370] [LOG]    All module helpers loaded.
                          [15:39:09.372] [LOG]    Starting server on port 8181 ...
                          [15:39:09.389] [INFO]   You're using a full whitelist configuration to allow for all IPs
                          [15:39:09.408] [LOG]    Server started ...
                          [15:39:09.410] [LOG]    Connecting socket for: updatenotification
                          [15:39:09.413] [LOG]    Connecting socket for: MMM-SystemStats
                          [15:39:09.415] [LOG]    Connecting socket for: MMM-homeassistant-sensors
                          [15:39:09.418] [LOG]    Connecting socket for: MMM-UKNationalRail
                          [15:39:09.420] [LOG]    MMM-UKNationalRail helper started ...
                          [15:39:09.421] [LOG]    Connecting socket for: newsfeed
                          [15:39:09.422] [LOG]    Starting module: newsfeed
                          [15:39:09.423] [LOG]    Sockets connected & modules started ...
                          [15:39:09.587] [LOG]    Whoops! There was an uncaught exception...
                          [15:39:09.588] [ERROR]  { Error: listen EADDRINUSE 127.0.0.1:8181
                              at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                              at listenInCluster (net.js:1378:12)
                              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                            errno: 'EADDRINUSE',
                            code: 'EADDRINUSE',
                            syscall: 'listen',
                            address: '127.0.0.1',
                            port: 8181 }
                          [15:39:09.605] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [15:39:09.605] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [15:39:09.652] [LOG]    Launching application.
                            sdetweil @bachoo786
                            so, it looks like u have another version running,
                            pm2 status
                            pm2 stop 0
                            then npm start
                              bachoo786 @sdetweil
                              @sdetweil do I have to do that? I never did update the modules after I upgraded the mirror.
                                sdetweil @bachoo786
                                yes… if the base dependencies change, then u should update the dependencies of the modules
                                my automated upgrade script does all this.
                                  bachoo786
                                  @sdetweil nope its only one version
                                    sdetweil @bachoo786
                                    @bachoo786 version = instance… sorry
                                    pm2 status
                                    if something is running, shut it down
                                      bachoo786 @sdetweil
                                      @sdetweil ok so what shall I do now? I am lost. I always avoid updating my magicmirror as the new update always breaks it.
                                        sdetweil @bachoo786
                                        @bachoo786
                                        please read my posts
                                        do
                                        pm2 status
                                        if anything is running, not stopped then do
                                        pm2 stop ??
                                        where xx is the name or number of the item running
                                        once u have nothing running, then redo the npm start from the MagicMirror folder so we can diagnose the rest of the problem
                                          bachoo786 @sdetweil
                                          @sdetweil ok I have done that and here is the result:
                                          > ./run-start.sh
                                          + ./untrack-css.sh
                                          + '[' -z '' ']'
                                          + export DISPLAY=:0
                                          + DISPLAY=:0
                                          ++ uname -m
                                          + arch=armv7l
                                          + false=false
                                          ++ tr -d ',"'\'''
                                          + serveronly=
                                          + serveronly=false
                                          ++ pgrep Xorg
                                          + xorg=519
                                          ++ uname
                                          + mac=Linux
                                          [15:51:26.871] [LOG]    Starting MagicMirror: v2.10.0
                                          [15:51:26.879] [LOG]    Loading config ...
                                          [15:51:26.884] [LOG]    Loading module helpers ...
                                          [15:51:26.924] [LOG]    Initializing new module helper ...
                                          [15:51:26.925] [LOG]    Module helper loaded: updatenotification
                                          [15:51:26.926] [LOG]    No helper found for module: clock.
                                          [15:51:27.306] [LOG]    Initializing new module helper ...
                                          [15:51:27.306] [LOG]    Module helper loaded: MMM-SystemStats
                                          [15:51:27.307] [LOG]    No helper found for module: currentweather.
                                          [15:51:27.308] [LOG]    No helper found for module: weatherforecast.
                                          [15:51:27.308] [LOG]    No helper found for module: random_quotes.
                                          [15:51:27.310] [LOG]    Initializing new module helper ...
                                          [15:51:27.311] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                          [15:51:27.697] [LOG]    Initializing new module helper ...
                                          [15:51:27.698] [LOG]    Module helper loaded: MMM-UKNationalRail
                                          [15:51:27.699] [LOG]    No helper found for module: MMM-TFL.
                                          [15:51:27.735] [LOG]    Initializing new module helper ...
                                          [15:51:27.735] [LOG]    Module helper loaded: newsfeed
                                          [15:51:27.736] [LOG]    All module helpers loaded.
                                          [15:51:27.737] [LOG]    Starting server on port 8181 ...
                                          [15:51:27.744] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                          [15:51:27.750] [LOG]    Server started ...
                                          [15:51:27.751] [LOG]    Connecting socket for: updatenotification
                                          [15:51:27.752] [LOG]    Connecting socket for: MMM-SystemStats
                                          [15:51:27.753] [LOG]    Connecting socket for: MMM-homeassistant-sensors
                                          [15:51:27.754] [LOG]    Connecting socket for: MMM-UKNationalRail
                                          [15:51:27.754] [LOG]    MMM-UKNationalRail helper started ...
                                          [15:51:27.755] [LOG]    Connecting socket for: newsfeed
                                          [15:51:27.756] [LOG]    Starting module: newsfeed
                                          [15:51:27.756] [LOG]    Sockets connected & modules started ...
                                          [15:51:27.943] [LOG]    Launching application.
                                          [15:51:29.943] [LOG]    Create new news fetcher for url: http://feeds.bbci.co.uk/news/england/rss.xml - Interval: 300000
                                          [15:51:29.984] [LOG]    Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 300000
                                            sdetweil @bachoo786
                                            @bachoo786 ok, so the node_helper side is working ok…
                                            now open the developers window, ctrl-shift-i, select the console tab, and scroll up to see any errors
                                              bachoo786 @sdetweil
                                              @sdetweil I dont have access to the mirror now as I am not home. The thing that stopped working was when I updated MM I cannot access it anymore remotely. Before updating mm I could as my ports are also forwarded.
