    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 133.6k Views 25 Watching
    • lavolp3L
      lavolp3 Module Developer @bachoo786
      @bachoo786 Same for me. Couldn’t get neither MMM-PIR nor MMM-PIR-Sensor to work, but on a Raspi3B+
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • FoziF
        Fozi Project Sponsor
        Hmmm…that’s strange.
        Here is my config for MMM-Pir-Sensor I use:
                module: 'MMM-PIR-Sensor',
                sensorPin: 4,
                powerSavingDelay: 150, // (seconds) how long the monitor will be turned on
        And this is the wiring of the sensor with the GPIO, which corresponds to the above config. ‘sensorPin: 4’ corresponds to GPIO_4 (brown cable)
        • lavolp3L
          lavolp3 Module Developer @Fozi
          @Fozi The odd thing is that I didn’t even get the module installed properly. However, just tried again and it seems to work now. Maybe because of MM v 2.10.0. I don’t know…
          FoziF 1 Reply Last reply Reply Quote 1
          • FoziF
            Fozi Project Sponsor @lavolp3
            @lavolp3 great!
            • hedmikH
              hedmik
              More or less the same problem for me…
              I’m using a velleman VMA314 connected to GPIO pin 11 (BCM GPIO 17) and module MMM-PIR-Sensor.
              I’ve updated wiringPi for Pi 4 (wiringPi updated to 2.52 for the Raspberry Pi 4B)
              I see that state changes using “gpio readall” but nothing happens…or to start with, connected screen does not even turn off after time set in config:
              				sensorPin: 17, // The pin (BCM numbering, NOT pin number itself) your PIR-sensor is connected to.
              				powerSaving: true, // Should the monitor be turned off if no user is present? (via HDMI or relay)
              				powerSavingDelay: 5, // Additional software side delay (in seconds) before the monitor will be turned off.
              				powerSavingNotification: true, // To display a notification before to switch screen off
              				powerSavingMessage: "Skärmen stängs av på grund av inaktivitet..." // Message notification to display before to switch screen off
              hedmikH 1 Reply Last reply Reply Quote 0
              • hedmikH
                hedmik @hedmik
                @hedmik sorry, my bad, i was editing config in another pi…
                Now it’s working now as it should :-)
                  sdetweil @hedmik
                  @hedmik said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                  doesn’t that drive u crazy?! I have 5 devices running, and all have open editors and file managers…
                  in the editor I can’t tell where the file came from…
                  hedmikH 2 Replies Last reply Reply Quote 0
                  • FoziF
                    You made my day, guys! 🤣
                    • hedmikH
                      hedmik @sdetweil
                      • hedmikH
                        hedmik @sdetweil
                        @sdetweil :rolling_on_the_floor_laughing:
                        Yes, i’ve built two mirrors and now working on my third bathroom mirror and with x number of files open in Notepad++ it’s getting messy…and even if you can see the file name and it’s location (host name) you end up editing elsewhere :dizzy_face:
                          devmil
                          What type of mirror glass do you all have?
                          I have a Pilkington Mirropane Chrome Spy and to me it seems that this type of Mirror glass interferes with the RCWL-0516.
                          When doing tests (mirror glass taken off) the sensor works as expected but as soon as I put the mirror glass back it stops working through the glass.
                          Waving my hand at the side still works.
                          Greetings
                          Michael
                          FoziF hedmikH 2 Replies Last reply Reply Quote 0
                          • FoziF
                            Fozi Project Sponsor @devmil
                            @devmil I have the same mirror, but 4mm thick, and it works really well. Thickness shouldn’t be an issue, because the sensor is easily able to detect motions in adjacent rooms separated by stone walls. I‘d suggest to increase slightly the sensitivity by increasing the trimmer value.
                            Further check the soldering joints between trimmer and sensor. Maybe they need to be reworked so that the solder provides a proper connection.
                            • hedmikH
                              hedmik @devmil
                              @devmil Hi Michael, i’ve been testing with d-c-fix mirror-effect privacy film and acrylic oneway mirror and both is interfering the PIR sensor so i had to put in a small box above the frame. Not a fancy design though…
                              For the acrylic i have spare place beneath the screen so i drilled a hole.
                              For the upcoming bath mirror i’ve ordered a Pilkington MirrorView. Don’t know yet if it will work with the sensor behind that glass though…otherwise i’ll put in a separate place/box. Hard to drill the glass and wouldn’t dare trying :-|
                              • uros76U
                                uros76
                                This is just amazing and pity I didn’t see it before I went into PIR usage.
                                If I put aluminum insulation on one side of sensor, can anyone confirm this can be used as 180-degree use?
                                • FoziF
                                  Fozi Project Sponsor @uros76
                                  @uros76 the detection range will very likely be more than 180 degree, as the emission characteristic is more or less spherical. Further, the detection range depends also on the layout of your rooms, walls etc. Just give it a try and see what the result is.
                                  • cowboysdudeC
                                    cowboysdude Module Developer @bachoo786
                                    @bachoo786 I have discovered that in the newer versions of the operating software for the PI that my scripts do NOT work any longer as the commands to turn the monitor on and off have changed… I have as of yet to find the correct command lines to make it work. I tested for 3 days and couldn’t get it to turn back on… It’s not MM…
                                    uros76U 1 Reply Last reply Reply Quote 0
                                    • uros76U
                                      uros76 @cowboysdude
                                      @cowboysdude scripts works fine with my pi3.
                                      It seems pi4 has different way of putting a monitor to sleep, I never figured out how to do it on pi4.
                                      Instead, I tested lubuntu on pi4 and managed to put it out of sleep with this mouse click script linked to PIR motion:
                                      xdotool click 1
                                      I can share more details on lubuntu setup if needed.
                                      • cowboysdudeC
                                        cowboysdude Module Developer @uros76
                                        @uros76 said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                                        Instead, I tested lubuntu on pi4 and managed to put it to sleep with this mouse click script linked to PIR motion:
                                        xdotool click 1
                                        Yes it works great on a Pi3… :) I am still using it for that…
                                        Yes please… I’d like to update the script for Pi4 but haven’t been able to get it working…
                                        Thank you!
                                        • uros76U
                                          uros76
                                          Ok.
                                          So, for a pi4 I managed to get PIR waking up MM screen with these steps:
                                          • Install latest Lubuntu with gdm3 environment
                                          • Edit /etd/gdm3/custom.conf. This will set autologin so that desktop environment loads every reboot
                                          # Enabling automatic login
                                            AutomaticLoginEnable = true
                                            AutomaticLogin = yourusername
                                          • Follow these steps to create wakeup script https://www.ketzler.de/2017/12/exit-screensaver-on-raspberry-pi-with-motion-sensor/
                                          • Create file “/etc/xdg/autostart/motion.desktop” with the following contents. This runs PIR sensing in the background after every reboot
                                          [Desktop Entry]
                                          Name=motion
                                          Exec=sudo gpio-watch -e rising 4
                                          • Set screensaver blank screen to desired timeout, 1min in my case. Lubutu knows how to handle pi4 blanking and puts to sleep my hdmi monitor
                                          This way I got pi4 waking up with PIR sensing. Not ideal setup but it works.
                                          I spent too much time trying to get pi4 work properly with Rapsberian, I simply had too many issues with it.
                                          At the end I am using pi3 for my first production MM and the pi4 is waiting for the next project.
                                          • cowboysdudeC
                                            @uros76 same here. I tried the Pi4 and had issues so I went back to the 3 and all the issues went away… so mine also sits waiting for the next project ;)
                                            Thank you for the info!!!
                                            • 3 / 6
