    MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion
    50 Posts 5 Posters 20.8k Views 5 Watching
    • G
      guongthongminh @sdetweil
      @sdetweil I understand this but what I need to do is call PAGE_READER_LOAD get the url from ARTICLE_INFO_REQUEST to display on MagicMirror.
      Can this idea be implemented or not possible but I have to use other methods to get url from newfeeds?
        A Former User @guongthongminh
          sdetweil @guongthongminh
          @guongthongminh I do not know. I have never seen a request to get info and then use that info to send another request
          G 1 Reply Last reply
          • G
            @sdetweil My ideas have been implemented.
            Can you help me how to instruct the hotword to return to the mirror screen after full screen display?
              @guongthongminh no, sorry, i have about 1% skill in those modules…
              • G
                How to run a python file at the same time with MM
                • cowboysdudeC
                  cowboysdude Module Developer @guongthongminh
                  @guongthongminh I run my PIR py script first then I load the Mirror…if that helps… so basically I have 2 terminal windows open…
                  • G
                    guongthongminh @cowboysdude
                    @cowboysdude
                    If the mirror opens automatically with pm2, how can I make the python file run at the same time as it?
                    Is there a way for a python file to run after the operating system boots up?
                    cowboysdudeC S 2 Replies Last reply
                    • cowboysdudeC
                      @guongthongminh try this ;)
                      https://stackoverflow.com/questions/24518522/run-python-script-at-startup-in-ubuntu
                        @guongthongminh u can use pm2 to launch the python file too
                        • G
                          Thanks everyone! Now I want to schedule for start up or on / off when I need it, if voice is too great.
                          • G
                            guongthongminh
                            @Sean
                            Why when I call the display “ARTICLE_TOGGLE_FULL” it works (it hears and shows the hotword on the mirror) but I call it “ARTICLE_LESS_DETAILS” to hide it (the hot word doesn’t appear on the mirror). I see it heard but didn’t execute for me (at terminal)
                            alt text
                            ? 1 Reply Last reply
                              @guongthongminh
                              Show me your current config of MMM-Hotword and serverlog. I’m not a
                              clairvoyance.
                              Are you still using MMM-NotificationTrigger ?
                              • G
                                guongthongminh @Guest
                                @Sean
                                I see the hotword received and done correctly but it stopped like the second picture for a long time and couldn’t receive another hot word so I couldn’t give it any more orders.alt text
                                alt text
                                  @guongthongminh
                                  you’ve set restart to false. So MMM-Hotword is stopped after Hien_Tin_tuc.
                                  • G
                                    @Sean Sorry for my mistake, thank you very much!!!
                                    • 3 / 3
