    MMM-DarkSkyForecast one part to other section ? - styling question
    7 Posts 3 Posters 2.0k Views 3 Watching
    • T Offline
      trividar
      Hmmmm no one can help?
      In general is that possible just to move this icons or a part from a module to an other section with css?
      THX
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @trividar
        @trividar does your globe update automatically??
        • T Offline
          trividar @Stoffbeuteluwe
          @Stoffbeuteluwe thats an old picture, so I don‘t use the globe anymore. I would like to have a big actually animated weather icon. But can‘t figure it out how to do that ;0(
          lavolp3L 2 Replies Last reply Reply Quote 0
          • lavolp3L Offline
            lavolp3 Module Developer @trividar
            @trividar You can’t easily move part of a module to a completely different section.
            So my answer is: “Not without tricks”.
            One “trick” would be to use the module in the center region a second time and hide everything but the cloud for that specific module. Slightly messy but possible via css.
            To the second question: There are animated icons included in MMM-DarkSkyForecast. Maybe have a look at that and check how these are implemented.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • lavolp3L Offline
              @trividar
              Also possible using MMM-DarkSkyForecast.
              You need to hide all forecast elements, all extra current conditions
              showExtraCurrentConditions: false,
              showSummary: false,
              showHourlyForecast: false,
              showDailyForecast: false
              and via your custom.css you need to set
              .MMM-DarkSkyForecast .current.temperature {
                  display: none;
              That hides hides current temperature and only shows the current icon.
              If you want to keep a complete second darksky-module you need to limit above selector to the region you where you want to hide the elements,
              e.g. .middle_center .MMM-DarkSkyForecast .current.temperature
              No guarantees this will work!
              • T Offline
                trividar @lavolp3
                @lavolp3 Thanks sooooo much!! I will try your suggestion and let you know if it worked. The current weather icons are animated, but not as cool as this one in .mov ;o) But first I will try to have only the icon in the middle of the screen. Thanks!!!
