    MMM-FlightTracker - Real time plane tracker using ADS-B systems
    29 Posts 9 Posters 17.5k Views 10 Watching
    • T
      tbouron Module Developer
      Hum if we can get the data out of this then yes, I can look into this :)
      I’ll look at dump1090 and see what I can do. Wanted to go back to the output design anyway so might be a nice feature to add.
      I’ll let you know.
      • T
        HI @ytmytm.
        So I looked at this over the past week and it turns out to be more complicated than expected.
        dump1090 does expose a raw stream of data but I could not use it as the data there is serialised from a C struct, which cannot be reconstructed from nodejs. I then looked at the SBS1 (BaseStation) stream to get the parsed data directly. This is a bit fiddly to make it work with the current codebase, and requires changes into npn dependencies I’m using.
        However, this is the best alternative I could find so I’ll continue in that direction. Bear in mind that as I have to modify dependencies so this will take a bit of time before I can release something that works ok.
        • T
          Alright @ytmytm got something working with the data exposed by dump1090.
          This is available on the branch feature/network where also updated the README.md regarding the configuration: https://github.com/tbouron/MMM-FlightTracker/tree/feature/network. You will need to update the dependencies:
          git fetch && git pull feature/network && npm i
          I’m running this locally and seems to work quite well. However, can I ask you to test it and report back with any issues, or a thumbs up? I’ll push this “officially” when I’m sure it works for you :)
          Y 1 Reply Last reply
          • Y
            ytmytm @tbouron
            @tbouron This is working great:
            After npm iI had to do some more.
            I realized that librtlsdr is required also when using network mode, so this had to be installed first, with library headers:
            sudo apt install librtlsdr-dev
            Next I got messages about missing symbols fromrtl-sdr.node module:
            node: symbol lookup error: /home/pi/MagicMirror/modules/MMM-FlightTracker/node_modules/rtl-sdr/build/Release/rtlsdr.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorE
            So it had to be rebuilt against my librtlsdr:
            npm rebuild rtl-sdr --build-from-source
            Thumbs up! Thanks!
            T 1 Reply Last reply
            • T
              tbouron Module Developer @ytmytm
              @ytmytm Cool, glad it works fine! I actually just realised that my last commit is not quite right regarding the connection retry if the TCP stream is closed. I’ll fix that for the merge in master.
              Regarding the dependency issue, you are right, I missed the librtlsdr-dev dependency in the prerequisites list, I’ll add that (FYI, this is needed only for the rtlsdr mode). And I think you had to rebuild the module because it was missing when you executed npm i (It is certainly not something I had to do on my Pi)
              I’ll clean this up and push to master, probably tomorrow though.
              Finally, I’m also working on a new UI with better UX (I think), I’ll post screenshots when I can.
              • Y
                ytmytm @tbouron
                @tbouron said in MMM-FlightTracker - Real time plane tracker using ADS-B systems:
                That’s correct. I cleared everything and tried again. The rebuild step is not necessary because the module is actually built during npm install step.
                • T
                  @ytmytm Thanks for confirming this. I’ll take that into account when I’ll update the README.md
                  • T
                    That’s what I’m currently working on, a better layout to display the plane where:
                    • airline name can be toggled from the config
                    • aircraft type (if recognised) can be toggled from the config
                    • metadata can be toggled from the config
                    Also, the icon beside the altitude reflects the current vertical rate (stays horizontal if vertical rate is 0 or not defined)
                    • T
                      Hi there.
                      I just release v1.1.0 of the module. See the README.md for the new configuration + how it looks like.
                      To update, simply do a git checkout master && git fetch origin && git pull origin master && npm i
                      Reply Quote 2
                      • T
                        Hi again.
                        I just release v1.2.0 of the module which adds support for the distance and heading` from your current coordinates to the planes displayed. See the README.md for the new configuration + how it looks like.
                          sonicgoose
                          Any chance this can have the option of reading a dump1090 feed over a local network? I have three RPi’s feeding FlightAware, FlightRadar24, PlaneFinder, RadarBox24 and OpenSky Explorer plus an instance of Virtual Radar Server on a PC I have, which in turn is feeding BaseStation on the same PC. I have another RPi running a custom python script to capture the closest aircraft and display its details on a 7" screen. But I’d love to be able to do this with my two MagicMirrors, neither of which is in a position where an antenna can be connected.
                          • T
                            tbouron Module Developer @sonicgoose
                            Hi @sonicgoose.
                            It’s already available since v1.1.0. Check out the “setup” section of the README.md, it explains how to set it up.
                              sonicgoose @tbouron
                              Hi @sonicgoose.
                              Wow. How did I miss that?! I’ve been following this module’s progress but clearly not close enough. Now I want to go home and try it! (Stupid work prevents me, though.) Thanks!
                              • T
                                @sonicgoose said in MMM-FlightTracker - Real time plane tracker using ADS-B systems:
                                Hi @sonicgoose.
                                Ahah no problem. To be fair, I released this version only 7 days ago :)
                                Glad you get excited about it! Although, the module might not work as good as expected for you, given the volume of planes you track. You see, my module handles huge volume by… not handling it 😅 There is currently no limit in place in the number of planes returned by the socket or displayed on the mirror.
                                This is mainly due to my lack of good antenna (hence not a lot of planes to display) But I would be curious to hear how you think this should be done, especially how the filtering and ordering should be performed?
                                Let me know what you think @sonicgoose :)
                                  sonicgoose @tbouron
                                  I’m currently tracking 130 aircraft from 3 to 218 nautical miles away, so I’m getting a looooong list—but I’m happy to have it working! My preference would be to have the aircraft sorted by distance (nearest first) from latLng and then have an option to restrict the number of aircraft displayed (5, 10, 15…?)
                                  And feature request: display aircraft speed in metric, imperial or knots, since that’s the aviation standard.
                                  This is a great module! I’m really excited I got it working :)
                                  • T
                                    @sonicgoose Yeah, I thought this would happen at some point. Need to think about how I can implement this.
                                    Can I ask you a favour? Could you create issues on GitHub for the long list and the feature feature? Would be easier for me to track the different things. Thanks in advance :)
                                      sonicgoose @tbouron
                                      Done!
                                      • H
                                        hogedir
                                        thos module works on 2.20?
                                          sdetweil @hogedir
                                          @hogedir maybe, hasn’t been updated in 3 years
                                          • H
                                            hogedir
                                            works but not available I think, anyone can test, because i’m a noob in that
