    MMM-NotificationTrigger transform payload
    24 Posts 4 Posters 6.6k Views 4 Watching
      corius @sdetweil
      @sdetweil yes i have
      • lavolp3L Offline
        lavolp3 Module Developer @corius
        @corius Well to be honest I did not expect it to work from scratch. But I am considering taking this into my own mirror to remind me of taking out the trash. :smiling_face:
        I won’t get it done today.
        If you don’t know how to work on from here I need to ask for your patience, and I’ll have a closer look at it myself in the next days.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @lavolp3
          @lavolp3 i am debugging it now
          not making any progress… can’t get the time compare to work
          let now = moment()
          let end = now.add(15, "minutes")
          let event_time=moment(event.startDate)
          if(event_time.isAfter(now) && event_time.isBefore(end))
          its 11:53, event starts at 12:00 and ends as 12:15
          so 12:00.isAfter(11:53) should be true, but is false
          and 12:00.isBefore(12:08), should be true,m but is false
            A Former User
            I think it’s better to build a new module about alerting events by the condition.
              corius
              @lavolp3 @sdetweil thank you for the time you have spent so far. I would be happy if someone else has an idea how to implement it. Thanks:smiling_face:
              • lavolp3L Offline
                @corius So I tamed the beast but I’m getting the feeling that @Sean is right.
                The following would alert you of the next event every time the calendar sends a calendar_event notification:
                	  module: "MMM-NotificationTrigger",
                		triggers:[
                			trigger: "CALENDAR_EVENTS",
                			fires: [
                					fire:"SHOW_ALERT",
                					payload: (payload) => {
                						var testMessage = "";
                						var nextEvent = payload.find(event => event.startDate > moment().format("x"));
                						testMessage = nextEvent.title + " " + moment(nextEvent.startDate, "x").format("HH:mm");
                						return {
                							type: "notification",
                							title: "Next event:",
                							message: testMessage
                For some yet unknown reason, I am getting this alert 8 times! The alert then vanishes quite shortly after.
                It is a good idea, but what I would do, no, WILL do, is implement a “Notification Alert Function” directly into the calendar module (or into MMM-CalendarExt, if you’re interested, @Sean).
                I think that would be a better way of ontrolling the alert created from a calendar event appearing.
                  sdetweil @lavolp3
                  @lavolp3 said in MMM-NotificationTrigger transform payload:
                  because it still sends an alert notification, with an empty payload
                  fire:“SHOW_ALERT”, (always)
                  • lavolp3L Offline
                    @sdetweil As far as I understand, it triggers when receiving the CALENDAR_EVENTS noti, and then “fires” a new notification, which is the “SHOW_ALERT” with the new payload.
                    This does not explain to me why it sends the “SHOW_ALERT” noti apparently 8 times in a row.
                      sdetweil @lavolp3
                      @lavolp3 cause calendar payload events is an array, fires once per
                      • 2 / 3
