    MMM-NotificationTrigger transform payload
    24 Posts 4 Posters 7.1k Views 4 Watching
      corius
      @lavolp3 yes that is exacly wat i want. can you please post the code? Thank you
      • lavolp3L Offline
        lavolp3 Module Developer
          module: "MMM-NotificationTrigger",
            triggers:[
                trigger: "CALENDAR_EVENTS",
                fires: [
                    fire:"SHOW_ALERT",
                    payload: (payload) => {
                      var testMessage = "";
                      payload.forEach(event => {
                        if (moment(event.startDate) > moment() && moment(event.startDate) < moment().add("15", minutes)) {
                         testMessage += event.title + ", "
                      return {
                              type: "notification",
                               title: "test",
                               message: testMessage
        This will most probably not work and needs to be de-bugged, but might be worth as a starting point. And I hope you get what I’m hinting at.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L Offline
          lavolp3 Module Developer @corius
          @corius
          Took me 10 seconds :smiling_face_with_sunglasses:
          No, of course I was already working on it.
          Seriously, I like the idea, that’s why I did a contribution.But you need to be more specific if you want to have the complete solution
            corius
            @lavolp3 Thank you for the fast answer. I tried this code. the result is that I get a notification but so far it only contains the title (test) but not the massage (title of the calendar event)
            S lavolp3L 2 Replies Last reply Reply Quote 0
              corius @lavolp3
              @lavolp3 what do you mean by “more specific”?
                sdetweil @corius
                @corius did u have an event within the next 15 minutes?
                  sdetweil @corius
                  @corius >what do you mean by “more specific”?
                  all the questions we have been asking… title, time filter, number to show, …
                    corius @sdetweil
                    @sdetweil yes i have
                    • lavolp3L Offline
                      @corius Well to be honest I did not expect it to work from scratch. But I am considering taking this into my own mirror to remind me of taking out the trash. :smiling_face:
                      I won’t get it done today.
                      If you don’t know how to work on from here I need to ask for your patience, and I’ll have a closer look at it myself in the next days.
                        sdetweil @lavolp3
                        @lavolp3 i am debugging it now
                        not making any progress… can’t get the time compare to work
                        let now = moment()
                        let end = now.add(15, "minutes")
                        let event_time=moment(event.startDate)
                        if(event_time.isAfter(now) && event_time.isBefore(end))
                        its 11:53, event starts at 12:00 and ends as 12:15
                        so 12:00.isAfter(11:53) should be true, but is false
                        and 12:00.isBefore(12:08), should be true,m but is false
                          A Former User
                          I think it’s better to build a new module about alerting events by the condition.
                            corius
                            @lavolp3 @sdetweil thank you for the time you have spent so far. I would be happy if someone else has an idea how to implement it. Thanks:smiling_face:
                            • lavolp3L Offline
                              @corius So I tamed the beast but I’m getting the feeling that @Sean is right.
                              The following would alert you of the next event every time the calendar sends a calendar_event notification:
                              		triggers:[
                              			fires: [
                              					fire:"SHOW_ALERT",
                              						var nextEvent = payload.find(event => event.startDate > moment().format("x"));
                              						testMessage = nextEvent.title + " " + moment(nextEvent.startDate, "x").format("HH:mm");
                              						return {
                              							title: "Next event:",
                              For some yet unknown reason, I am getting this alert 8 times! The alert then vanishes quite shortly after.
                              It is a good idea, but what I would do, no, WILL do, is implement a “Notification Alert Function” directly into the calendar module (or into MMM-CalendarExt, if you’re interested, @Sean).
                              I think that would be a better way of ontrolling the alert created from a calendar event appearing.
                                sdetweil @lavolp3
                                @lavolp3 said in MMM-NotificationTrigger transform payload:
                                because it still sends an alert notification, with an empty payload
                                fire:“SHOW_ALERT”, (always)
                                • lavolp3L Offline
                                  @sdetweil As far as I understand, it triggers when receiving the CALENDAR_EVENTS noti, and then “fires” a new notification, which is the “SHOW_ALERT” with the new payload.
                                  This does not explain to me why it sends the “SHOW_ALERT” noti apparently 8 times in a row.
                                    sdetweil @lavolp3
                                    @lavolp3 cause calendar payload events is an array, fires once per
