    MMM-NotificationTrigger transform payload
    24 Posts 4 Posters 7.6k Views 4 Watching
      corius
      Hi there…
      first of all sorry for my english
      Can someone explain how I can transfer the payload “title” of the standard calendar module to the payload “massage” of the alert module? This is the configuration I’ve tested:
        module: "MMM-NotificationTrigger",
          triggers:[
              trigger: "CALENDAR_EVENTS",
              fires: [
                  fire:"SHOW_ALERT",
                  payload: (payload) => {
                    return {
                      type: "notification",
                      title: "test",
                      message: payload.title
      The result of this configuration is that I only see the title in the alert.
      Thanks.
        corius
        can nobody help me?
          sdetweil @corius
          @corius what is ‘title’? the incoming message is an array of calendar events…
            corius
            by the title i mean the title of the individual calendar events. but ok then it doesn’t work that way. So again asked differently: is there a way to display upcoming calendar events via the alert module?
            S lavolp3L 2 Replies Last reply Reply Quote 0
              sdetweil @corius
              @corius said in MMM-NotificationTrigger transform payload:
              what does that mean? if I have 20 entries, u want 1 alert with 20 entries, or 20 alerts with 1 entry each?
              or just today, or?
              alert module is expecting a single line of text
              • lavolp3L Offline
                lavolp3 Module Developer @corius
                @corius you need to have a look at how the payload looks. If it’s an array, you should be able to catch the title of specific elements by using something like payload.entries[n].title
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • lavolp3L Offline
                  @corius Considering you want to alert the next event happening in say 15 minutes, you could first check what event is in a range of the next 15 minutes, then take it’s title and alert that one. Can all be done inside the callback function you’ve shown above.
                  Is that what you want?
                    sdetweil @lavolp3
                    @lavolp3 actually payload IS an array
                    (from my system default cal)
                    0: {title: "M L King Day", startDate: "1579500000000", endDate: "1579586400000", fullDayEvent: true, location: "United States", …}
                    1: {title: "Valentine's Day", startDate: "1581660000000", endDate: "1581746400000", fullDayEvent: true, location: "United States", …}
                    2: {title: "Presidents' Day", startDate: "1581919200000", endDate: "1582005600000", fullDayEvent: true, location: "United States", …}
                    3: {title: "Good Friday", startDate: "1586494800000", endDate: "1586581200000", fullDayEvent: true, location: "United States", …}
                    4: {title: "Easter Sunday", startDate: "1586667600000", endDate: "1586754000000", fullDayEvent: true, location: "United States", …}
                    5: {title: "Mother's Day", startDate: "1589086800000", endDate: "1589173200000", fullDayEvent: true, location: "United States", …}
                    6: {title: "Memorial Day", startDate: "1590382800000", endDate: "1590469200000", fullDayEvent: true, location: "United States", …}
                    7: {title: "Father's Day", startDate: "1592715600000", endDate: "1592802000000", fullDayEvent: true, location: "United States", …}
                    8: {title: "Independence Day Holiday", startDate: "1593752400000", endDate: "1593838800000", fullDayEvent: true, location: "United States", …}
                    9: {title: "Independence Day", startDate: "1593838800000", endDate: "1593925200000", fullDayEvent: true, location: "United States", …}
                    so the js would be
                    payload[0].title
                    for the title (cal subject) of the 1st cal entry
                    I found this by using the developers window (ctrl-shift-i), selecting the ‘Sources’ tab,
                    expanding the modules entry, and then the calendar entry to get to calendar.js
                    then knowing it is a notification,(notificationreceived) i searched (ctrl-f) for ‘sendnotification’
                    I put a stop on that line, hit refesh(f5), and the web page starts over, and stops on that line, then use the mouse to hover over the eventlist variable name, and it expands to the data layout
                      corius
                      @lavolp3 yes that is exacly wat i want. can you please post the code? Thank you
                      • lavolp3L Offline
                            triggers:[
                                fires: [
                                    fire:"SHOW_ALERT",
                                      var testMessage = "";
                                      payload.forEach(event => {
                                        if (moment(event.startDate) > moment() && moment(event.startDate) < moment().add("15", minutes)) {
                                         testMessage += event.title + ", "
                                      return {
                                               title: "test",
                                               message: testMessage
                        This will most probably not work and needs to be de-bugged, but might be worth as a starting point. And I hope you get what I’m hinting at.
                        • lavolp3L Offline
                          @corius
                          Took me 10 seconds :smiling_face_with_sunglasses:
                          No, of course I was already working on it.
                          Seriously, I like the idea, that’s why I did a contribution.But you need to be more specific if you want to have the complete solution
                            corius
                            @lavolp3 Thank you for the fast answer. I tried this code. the result is that I get a notification but so far it only contains the title (test) but not the massage (title of the calendar event)
                              corius @lavolp3
                              @lavolp3 what do you mean by “more specific”?
                                sdetweil @corius
                                @corius did u have an event within the next 15 minutes?
                                  sdetweil @corius
                                  @corius >what do you mean by “more specific”?
                                  all the questions we have been asking… title, time filter, number to show, …
                                    corius @sdetweil
                                    @sdetweil yes i have
                                    • lavolp3L Offline
                                      @corius Well to be honest I did not expect it to work from scratch. But I am considering taking this into my own mirror to remind me of taking out the trash. :smiling_face:
                                      I won’t get it done today.
                                      If you don’t know how to work on from here I need to ask for your patience, and I’ll have a closer look at it myself in the next days.
                                        sdetweil @lavolp3
                                        @lavolp3 i am debugging it now
                                        not making any progress… can’t get the time compare to work
                                        let now = moment()
                                        let end = now.add(15, "minutes")
                                        let event_time=moment(event.startDate)
                                        if(event_time.isAfter(now) && event_time.isBefore(end))
                                        its 11:53, event starts at 12:00 and ends as 12:15
                                        so 12:00.isAfter(11:53) should be true, but is false
                                        and 12:00.isBefore(12:08), should be true,m but is false
                                          A Former User
                                          I think it’s better to build a new module about alerting events by the condition.
                                            corius
                                            @lavolp3 @sdetweil thank you for the time you have spent so far. I would be happy if someone else has an idea how to implement it. Thanks:smiling_face:
