    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      Jas @Guest
      @Sean Thank you so much! Yup all working now. I got the “No more events” to show up by using the following in the daily view if that helps anyone else.
      .CX2 .slot.eventCount_0 .slotContent::after {
        content: "No Scheduled Meetings"
      Thanks for the amazing work and support!
      ? 1 Reply Last reply
        A Former User @Jas
        @Jas
        .CX2 .slot.eventCount_0 this is not only for daily view, so could be risky on other views. Anyway, if it works at this moment, don’t mind. :D
          JRB1988 @JRB1988
          @Sean Hey Sean, not sure if you saw my last response. I updated to static with still no luck. Any ideas. I was thinking it might have to be with telling timeline the right name or something along those lines. This is my configure except dynamic switched to static. Thanks!
          • T
            Thekk @Guest
            @Sean said in MMM-CalendarExt2:
            @Thekk
            Hmmm… I think there is no flag about repeated events. I’ll research about it.
            For filtering; See this; https://github.com/eouia/MMM-CalendarExt2/wiki/Filtering-and-Sorting
            And this also; https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Object
            I haven’t seen any mention about that property in the filtering or event-object. I did browse through your parser and didn’t see any mention about repeating objects. I did Google a little further and found this function in (what I gather is) the underlying parser: http://mozilla-comm.github.io/ical.js/api/ICAL.Event.html#isRecurring
            Rather proud that I did (eventually) get it to work. I added
            // Check if an event is recurring and make a filterable property
                  ev.isRecurring = ri.isRecurring()
            around line 140 in node_helper.js and added the following filter:
            filter: (event) => {
              if (event.isRecurring) {
                 return false
              } else {
                  return true
            to remove all recurring items from one of the views.
            E ? 2 Replies Last reply
            • A
              Arjan Project Sponsor
              Last week I switched from MMM-CalendarExt to MMM-CalendarExt2 due to problems with showing full day events one day to late.
              I have almost everything setup the way I would like with the custom.css, but have a few points left where I need some help with.
              • Can you make the font larger for slotTitle in only “current” and “upcomming”.
              • Can you make slotMaxHeight auto size in “week” and “current ”so that is always shows all events and not a +2.
              • Can an event in “week” be bigger than 1 line, so no data is lost.
              That’s all.
                A Former User @Arjan
                @Arjan
                Well.
                There are already hundreds of questions similar with this.
                1. possible. See the MMM-CalendarExt2.css then find proper selector, then redefine it on your css/custom.css.
                2. impossible. autosize? fit for what? How about number of events are over 100 in those views?
                3. possible but not recommended. MM screen is too narrow to display week/month view with ALL DATA.
                  JRB1988
                    JRB1988
                    @Sean How do I remove these green underlines on current month header and current month events?
                    alt text
                      A Former User @JRB1988
                      @JRB1988
                      ? In default CSS, there is no green underline. I think you’ve modified CSS or there might be a collision with other modules.
                      J 1 Reply Last reply
                        JRB1988 @Guest
                        @Sean So strange. And the really weird thing is that it’s happening both on CalendarEXT and CalendarEXT2. But good to know its not supposed to be there. I’ll dig around more. Thanks!
                        Edit: seems to be some conflict with the Todoist Module. Thanks for the tip again, I think i would have been digging around the CSS forever trying to find what was underlining. Now to figure out why the other modules does this…
                        M 1 Reply Last reply
                          JRB1988
                          @Sean
                          Sorry, last question. Is there a max of 6 calendars? I have 7 and only the first 6 populate. If there is, can I up that limit?
                            @JRB1988
                            There is no calendars limit. hmmm… weird. Can you share the url of calendars with me? (eouia0819@gmail.com)
                              JRB1988 @Guest
                              @Sean I was able to find a work around for this. Essentially it was always just ignoring the last calendar for some reason so I just added a fake calendar at the end (so now the config has “eight” calendars and gives me the first seven)
                                @JRB1988
                                I cannot represent your symptom, Mine works well. So I should get your config and real ical url to diagnose.
                                  cskenney
                                  @JRB1988 I can confirm that 7 calendars works fine. I wonder if you have a syntax issue on the last one in your list. You should be able to look at the log window and see each of the calendars being read and the number of entries that are selected.
                                    mscrawford5 @JRB1988
                                    @JRB1988
                                    Did you happen to figure out why MMM-Todoist was causing the green underline on calendars ? I’m having the same problem and can’t seem to find a solution.
                                    Thank you in advance
                                      A Former User @mscrawford5
                                      @mscrawford5
                                      add this into your css/custom.css
                                      .today {
                                        text-decoration: inherit;
                                      .tomorrow {
                                      .MMM-Todoist .today {
                                        text-decoration: underline #03a05c;
                                      .MMM-Todoist .tomorrow {
                                        text-decoration: underline #166cec;
                                      Not tested, but you can catch the idea.
                                      • E
                                        EdO @Thekk
                                        @Thekk Thanks for this, just implemented it and it work like a charm. Took me a while to find node_helper.js until I did a find on it and found it in the MMM-CalendarExt2 folder (as well as everywhere else). I’m still a noob with the RPI so not all things are obvious.
                                        It took me no time at all to find the place to make the change and then I added the filter to the upcoming view while leaving the monthly view alone; exactly what I wanted! Thanks again.
                                        Now just need to make sure that this gets incorporated into the next module.
                                          mscrawford5 @Guest
                                          @Sean
                                          That worked.Thank you for your help!
                                            A Former User @Thekk
                                            @Thekk
                                            Thanks. I haven’t thought about that method. Now I updated that part in the module.
                                            T 1 Reply Last reply
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 24
                                            • 25
                                            • 13 / 25
