    MMM-CalendarExt2
    486 Posts 83 Posters 920.6k Views 83 Watching
      A Former User @Jas
      @Jas
      For 2. filterPassedEvent makes not loading passed events at this moment, so it will not affect to tomorrow or future days. Only today will be affected.
      For 4. It will work on upcoming view. For daily view, this selector might work (not tested). Try yourself with documents.
      .CX2 .view.daily .eventCount_0 .slotFooter::after
        Jas @Guest
        @Sean I just want Today’s events to show up. So that should not list Tomorrow or any other day’s events. Sorry if I wasn’t clear.
          A Former User @Jas
          @Jas
          set slotCount: 1
          https://github.com/eouia/MMM-CalendarExt2/wiki/2c.-Configuration:View
            Jas @Guest
            @Sean Thank you so much! Yup all working now. I got the “No more events” to show up by using the following in the daily view if that helps anyone else.
            .CX2 .slot.eventCount_0 .slotContent::after {
              content: "No Scheduled Meetings"
            Thanks for the amazing work and support!
              A Former User @Jas
              @Jas
              .CX2 .slot.eventCount_0 this is not only for daily view, so could be risky on other views. Anyway, if it works at this moment, don’t mind. :D
                JRB1988 @JRB1988
                @Sean Hey Sean, not sure if you saw my last response. I updated to static with still no luck. Any ideas. I was thinking it might have to be with telling timeline the right name or something along those lines. This is my configure except dynamic switched to static. Thanks!
                • T Offline
                  Thekk @Guest
                  @Sean said in MMM-CalendarExt2:
                  @Thekk
                  Hmmm… I think there is no flag about repeated events. I’ll research about it.
                  For filtering; See this; https://github.com/eouia/MMM-CalendarExt2/wiki/Filtering-and-Sorting
                  And this also; https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Object
                  I haven’t seen any mention about that property in the filtering or event-object. I did browse through your parser and didn’t see any mention about repeating objects. I did Google a little further and found this function in (what I gather is) the underlying parser: http://mozilla-comm.github.io/ical.js/api/ICAL.Event.html#isRecurring
                  Rather proud that I did (eventually) get it to work. I added
                  // Check if an event is recurring and make a filterable property
                        ev.isRecurring = ri.isRecurring()
                  around line 140 in node_helper.js and added the following filter:
                  filter: (event) => {
                    if (event.isRecurring) {
                       return false
                    } else {
                        return true
                  to remove all recurring items from one of the views.
                  E ? 2 Replies Last reply Reply Quote 0
                    Arjan Project Sponsor
                    Last week I switched from MMM-CalendarExt to MMM-CalendarExt2 due to problems with showing full day events one day to late.
                    I have almost everything setup the way I would like with the custom.css, but have a few points left where I need some help with.
                    • Can you make the font larger for slotTitle in only “current” and “upcomming”.
                    • Can you make slotMaxHeight auto size in “week” and “current ”so that is always shows all events and not a +2.
                    • Can an event in “week” be bigger than 1 line, so no data is lost.
                    That’s all.
                      A Former User @Arjan
                      @Arjan
                      Well.
                      There are already hundreds of questions similar with this.
                      1. possible. See the MMM-CalendarExt2.css then find proper selector, then redefine it on your css/custom.css.
                      2. impossible. autosize? fit for what? How about number of events are over 100 in those views?
                      3. possible but not recommended. MM screen is too narrow to display week/month view with ALL DATA.
                        JRB1988
                        • 23
                        • 24
                        • 25
                        • 26
                        • 27
                        • 48
                        • 49
                        • 25 / 49
