    MMM-Buttons to activate MMM-Assistantmk2 (v3)
    15 Posts 3 Posters 3.0k Views 3 Watching
      Apartment_Moose
      I am looking to activate MMM-Assistantmk2 (v3) by using the MMM-Buttons module.
      i.e - Press a physical push button to then activate the google assistant.
      I have the buttons working as i can get the speakers to make a sound when i press the button, and the 4 circles start to spin around.
      issue is nothing happens beyond this point. they just continue to spin in a circle…
      I have the below config
          module: "MMM-Buttons",
              buttons: [
                      pin: 25,
                      shortPress: {
                          notification: "ASSISTANT_ACTIVATE",
                          payload: {}
        module: "MMM-AssistantMk2",
        position: "top_center",
      	ui: "Classic",
      	assistantConfig: {
            latitude:xxxxxxxxxxxxxxx,
            longitude: -xxxxxxxxxxxxxxxx,
           defaultProfile: "default",
          micConfig: {
            recorder: "arecord",
            device: "plughw:0",
      i have even tried putting in a payload…
      payload: {type:"MIC"}
      and this gets the 4 dots in a line doing a wave pattern… but again no further
      my mic is working as per testing it on
      arecord -D plughw:0,0 -d 3 test.wav && aplay test.wav
      Any help would be great,
      thanks
        [[global:former-user]] @Apartment_Moose
        @Apartment_Moose
        Can you show me the logs? To make things simple, except clock, MMM-Button, MMM-AssistantMk2, You’d better remove all other modules from config.js. Execute MM, then show me what happens in log. (add debug:true to MMM-AssistantMk2’s config)
          sdetweil @Guest
          @Sean said in MMM-Buttons to activate MMM-Assistantmk2 (v3):
          just add
          disabled:true,
          after the each module: u want to turn off
            Apartment_Moose
            Hi @Sean & @sdetweil
            i restarted the raspberrypi last night and now the module is working (? no idea how) and the assistant is working when i speak.
            my issue now is i have no audio with the assistant (even though recording & playback are fine) & the assistant doesn’t turn off until i repeat the button press a few times until it doesn’t understands me.
            I have run the log with only one failure in the log when i press the button to activate
            mmap() failed: Cannot allocate memory
            Failed to create permanent mapping for memfd region with ID = 2853658957
            Ignoring received block reference with non-registered memfd ID = 2853658957
            Failed to create permanent mapping for memfd region with ID = 2893321627
            Ignoring received block reference with non-registered memfd ID = 2893321627
            any help here ?
            thanks
              @Apartment_Moose
              I have no idea about mmap(). I’m not sure even whether this issue would be related to my module.
              Set debug:true of MMM-AssistantMk2 then show me the log of MMM-AssistantMk2.
                Apartment_Moose
                see below
                [15:09:19.817] [LOG]    [AMK2] QUERY: { type: 'MIC',
                  profile: { profileFile: 'default.json', lang: 'en-US' },
                  key: null,
                  lang: null,
                  useScreenOutput: true,
                  useAudioOutput: true,
                  session: 1579273759810,
                  status: 'standby',
                  secretMode: false,
                  sayMode: false }
                [15:09:19.985] [LOG]    [AMK2:AS] MIC:RECORDING START.
                Failed to create permanent mapping for memfd region with ID = 2467795728
                Ignoring received block reference with non-registered memfd ID = 2467795728
                [15:09:20.546] [LOG]    [AMK2:AS] CONVERSATION:RESPONSE
                [15:09:22.659] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'test', done: false }
                [15:09:22.792] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: false }
                [15:09:23.520] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: false }
                [15:09:23.548] [LOG]    [AMK2:AS] CONVERSATION:END_OF_UTTERANCE
                [15:09:23.551] [LOG]    [AMK2:AS] MIC:RECORDING_END
                [15:09:23.585] [LOG]    [AMK2:AS] Recorder Error: arecord has exited with error code 1.
                Enable debugging with the environment variable DEBUG=record.
                [15:09:23.599] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: true }
                [15:09:23.906] [LOG]    [AMK2:AS] CONVERSATION:SCREEN object
                [15:09:23.915] [LOG]    [AMK2:AS] CONVERSATION:ACTION { requestId: '5e215c36-0000-2e45-8016-089e0826d0a0' }
                [15:09:23.918] [LOG]    [AMK2:AS] CONVERSATION:RESPONSE
                [15:09:23.929] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.931] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.933] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.937] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.938] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.940] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.941] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.943] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.944] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.945] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.947] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.949] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.950] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.951] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.953] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.955] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.959] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.962] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.966] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.968] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.970] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.972] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.975] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.979] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.982] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.984] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.986] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.987] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.989] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.990] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.992] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.993] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.995] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.997] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:23.999] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.000] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.002] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.004] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.006] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.008] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.010] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.012] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.015] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.017] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.019] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.022] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.027] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.031] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.034] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.036] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.039] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.041] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.043] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.046] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.051] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.056] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
                [15:09:24.058] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 14
                [15:09:24.065] [LOG]    [AMK2:AS] CONVERSATION_ALL_RESPONSES_RECEIVED
                [15:09:24.066] [LOG]    [AMK2:AS] CONVERSATION_END:COMPLETED
                [15:09:24.067] [LOG]    [AMK2:AS] CONVERSATION_PP:RESPONSE_AUDIO_MAKING
                [15:09:24.097] [LOG]    [AMK2:BW] RESPONSE_WAV_FILE_CREATED
                [15:09:24.099] [LOG]    [AMK2:AS] CONVERSATION_PP:RESPONSE_AUDIO_CREATED tmp/lastResponse.wav
                [15:09:24.228] [LOG]    [AMK2] { session: 1579273759810,
                  error: null,
                  action: { requestId: '5e215c36-0000-2e45-8016-089e0826d0a0' },
                  text: null,
                  screen:
                   { help: [ 'What can you do?' ],
                     trysay: 'Try saying…',
                     links: [],
                     text: 'You\'re coming in loud and clear 👌',
                     photos: [],
                     path:
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/lastScreenOutput.html',
                     uri: 'tmp/lastScreenOutput.html' },
                  audio:
                   { path:
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/lastResponse.wav',
                     uri: 'tmp/lastResponse.wav' },
                  transcription: { transcription: 'testing', done: true },
                  continue: false,
                  lastQuery:
                   { type: 'MIC',
                     key: null,
                     lang: null,
                     status: 'standby',
                     secretMode: false,
                     sayMode: false } }
                Failed to create permanent mapping for memfd region with ID = 3652511026
                Ignoring received block reference with non-registered memfd ID = 3652511026
                  @Apartment_Moose
                  Well, the module itself is working as log says. But the mmap() failed means, you have not enough memory. (I don’t know why) mmap() issue could happen with various reasons, so hard to point out exactly.
                  I think it is not related to my module directly because there was no same issue report but I cannot declare definitely.
                    Apartment_Moose
                    @Sean
                    ok thanks for taking a look.
                    dont know what the mmap() issue is but i will look into it
                    do you potentially know what could cause this ?
                      sdetweil @Apartment_Moose
                      @Apartment_Moose said in MMM-Buttons to activate MMM-Assistantmk2 (v3):
                      mmap is memory mapped file
                      here is a site with a pretty decent dewscription of what to look for and what to change
                      https://mroonga.org/docs/faq/mmap_cannot_allocate_memory.html
                        Apartment_Moose
                        Thanks for getting back to me on this. I will check it out over the weekend when I next am free (probably sunday). I will report back on if this fixed it. Thanks again for the support as I couldnt find anything on google.
                          @Apartment_Moose i just did a search on google for “mmap Cannot allocate memory”
                            Apartment_Moose
                            Hi @sdetweil
                            thanks for the help so far, I have edited the vm map count as per the link you linked (with the 16gb used in the example)
                            i am still getting the same log error however
                            Failed to create permanent mapping for memfd region with ID = 738611435
                            Ignoring received block reference with non-registered memfd ID = 738611435
                            any ideas as i am stumped…
                              Apartment_Moose
                              I seem to have fixed the issue by switching everything to my raspberry 4.
                              didn’t look like the 3 b+ could handle it for some reason and now it is all working.
                              thank you for your help, it was greatly appreciated!
                              @Sean
                              quick one for you if you don’t, (after upgrading to 3.0.1) When i speak a command and it responds, the google wheel continues to spin as per the picture. (log file doesn’t do anything unless i press the button to activate again)
                              is this normal? or should it return to the floating bubbles?
                              also, log files show after any open questions such as “hello google” its status goes to standby after responding with the log showing the continue line on set to “false”.
                              if i press the button and dont say anything, then it resets due to the timer setting.
                                @Apartment_Moose
                                We found some issues under specific condition about memory shortage. so we are trying another approach to use smaller memory. wait a while. sorry.
                                  Apartment_Moose @Guest
                                  @Sean
                                  thanks for the response :) i will close this as solve for now.
                                  thank you
