    MMM-Buttons to activate MMM-Assistantmk2 (v3)
    15 Posts 3 Posters 2.6k Views 3 Watching
      A Former User @Apartment_Moose
      @Apartment_Moose
      Can you show me the logs? To make things simple, except clock, MMM-Button, MMM-AssistantMk2, You’d better remove all other modules from config.js. Execute MM, then show me what happens in log. (add debug:true to MMM-AssistantMk2’s config)
        sdetweil @Guest
        @Sean said in MMM-Buttons to activate MMM-Assistantmk2 (v3):
        just add
        disabled:true,
        after the each module: u want to turn off
          Apartment_Moose
          Hi @Sean & @sdetweil
          i restarted the raspberrypi last night and now the module is working (? no idea how) and the assistant is working when i speak.
          my issue now is i have no audio with the assistant (even though recording & playback are fine) & the assistant doesn’t turn off until i repeat the button press a few times until it doesn’t understands me.
          I have run the log with only one failure in the log when i press the button to activate
          mmap() failed: Cannot allocate memory
          Failed to create permanent mapping for memfd region with ID = 2853658957
          Ignoring received block reference with non-registered memfd ID = 2853658957
          Failed to create permanent mapping for memfd region with ID = 2893321627
          Ignoring received block reference with non-registered memfd ID = 2893321627
          any help here ?
          thanks
            @Apartment_Moose
            I have no idea about mmap(). I’m not sure even whether this issue would be related to my module.
            Set debug:true of MMM-AssistantMk2 then show me the log of MMM-AssistantMk2.
              Apartment_Moose
              see below
              [15:09:19.817] [LOG]    [AMK2] QUERY: { type: 'MIC',
                profile: { profileFile: 'default.json', lang: 'en-US' },
                key: null,
                lang: null,
                useScreenOutput: true,
                useAudioOutput: true,
                session: 1579273759810,
                status: 'standby',
                secretMode: false,
                sayMode: false }
              [15:09:19.985] [LOG]    [AMK2:AS] MIC:RECORDING START.
              Failed to create permanent mapping for memfd region with ID = 2467795728
              Ignoring received block reference with non-registered memfd ID = 2467795728
              [15:09:20.546] [LOG]    [AMK2:AS] CONVERSATION:RESPONSE
              [15:09:22.659] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'test', done: false }
              [15:09:22.792] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: false }
              [15:09:23.520] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: false }
              [15:09:23.548] [LOG]    [AMK2:AS] CONVERSATION:END_OF_UTTERANCE
              [15:09:23.551] [LOG]    [AMK2:AS] MIC:RECORDING_END
              [15:09:23.585] [LOG]    [AMK2:AS] Recorder Error: arecord has exited with error code 1.
              Enable debugging with the environment variable DEBUG=record.
              [15:09:23.599] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: true }
              [15:09:23.906] [LOG]    [AMK2:AS] CONVERSATION:SCREEN object
              [15:09:23.915] [LOG]    [AMK2:AS] CONVERSATION:ACTION { requestId: '5e215c36-0000-2e45-8016-089e0826d0a0' }
              [15:09:23.918] [LOG]    [AMK2:AS] CONVERSATION:RESPONSE
              [15:09:23.929] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.931] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.933] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.937] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.938] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.940] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.941] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.943] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.944] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.945] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.947] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.949] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.950] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.951] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.953] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.955] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.959] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.962] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.966] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.968] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.970] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.972] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.975] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.979] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.982] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.984] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.986] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.987] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.989] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.990] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.992] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.993] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.995] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.997] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:23.999] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.000] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.002] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.004] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.006] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.008] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.010] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.012] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.015] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.017] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.019] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.022] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.027] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.031] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.034] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.036] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.039] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.041] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.043] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.046] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.051] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.056] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
              [15:09:24.058] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 14
              [15:09:24.065] [LOG]    [AMK2:AS] CONVERSATION_ALL_RESPONSES_RECEIVED
              [15:09:24.066] [LOG]    [AMK2:AS] CONVERSATION_END:COMPLETED
              [15:09:24.067] [LOG]    [AMK2:AS] CONVERSATION_PP:RESPONSE_AUDIO_MAKING
              [15:09:24.097] [LOG]    [AMK2:BW] RESPONSE_WAV_FILE_CREATED
              [15:09:24.099] [LOG]    [AMK2:AS] CONVERSATION_PP:RESPONSE_AUDIO_CREATED tmp/lastResponse.wav
              [15:09:24.228] [LOG]    [AMK2] { session: 1579273759810,
                error: null,
                action: { requestId: '5e215c36-0000-2e45-8016-089e0826d0a0' },
                text: null,
                screen:
                 { help: [ 'What can you do?' ],
                   trysay: 'Try saying…',
                   links: [],
                   text: 'You\'re coming in loud and clear 👌',
                   photos: [],
                   path:
                    '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/lastScreenOutput.html',
                   uri: 'tmp/lastScreenOutput.html' },
                audio:
                 { path:
                    '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/lastResponse.wav',
                   uri: 'tmp/lastResponse.wav' },
                transcription: { transcription: 'testing', done: true },
                continue: false,
                lastQuery:
                 { type: 'MIC',
                   key: null,
                   lang: null,
                   status: 'standby',
                   secretMode: false,
                   sayMode: false } }
              Failed to create permanent mapping for memfd region with ID = 3652511026
              Ignoring received block reference with non-registered memfd ID = 3652511026
                @Apartment_Moose
                Well, the module itself is working as log says. But the mmap() failed means, you have not enough memory. (I don’t know why) mmap() issue could happen with various reasons, so hard to point out exactly.
                I think it is not related to my module directly because there was no same issue report but I cannot declare definitely.
                  Apartment_Moose
                  @Sean
                  ok thanks for taking a look.
                  dont know what the mmap() issue is but i will look into it
                  do you potentially know what could cause this ?
                    sdetweil @Apartment_Moose
                    @Apartment_Moose said in MMM-Buttons to activate MMM-Assistantmk2 (v3):
                    mmap is memory mapped file
                    here is a site with a pretty decent dewscription of what to look for and what to change
                    https://mroonga.org/docs/faq/mmap_cannot_allocate_memory.html
                      Apartment_Moose
                      Thanks for getting back to me on this. I will check it out over the weekend when I next am free (probably sunday). I will report back on if this fixed it. Thanks again for the support as I couldnt find anything on google.
                        @Apartment_Moose i just did a search on google for “mmap Cannot allocate memory”
