    Fresh install but pm2 error
    37 Posts 2 Posters 11.2k Views 2 Watching
      sdetweil @Hubschra01
      @Hubschra01 how are you connecting to the pi? over ssh?
      did u set DISPLAY=:0
      • H Offline
        Hubschra01
        sorry i forget this.
        This is the CLI output i tried now.
        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
        > magicmirror@2.10.1 start /home/pi/MagicMirror
        > ./run-start.sh
        [23:11:47.885] [LOG]    Starting MagicMirror: v2.10.1
        [23:11:47.902] [LOG]    Loading config ...
        [23:11:47.911] [LOG]    Loading module helpers ...
        [23:11:47.914] [LOG]    No helper found for module: alert.
        [23:11:48.008] [LOG]    Initializing new module helper ...
        [23:11:48.010] [LOG]    Module helper loaded: updatenotification
        [23:11:48.012] [LOG]    No helper found for module: clock.
        [23:11:48.875] [LOG]    Initializing new module helper ...
        [23:11:48.876] [LOG]    Module helper loaded: calendar
        [23:11:48.877] [LOG]    No helper found for module: currentweather.
        [23:11:48.878] [LOG]    No helper found for module: weatherforecast.
        [23:11:48.935] [LOG]    Initializing new module helper ...
        [23:11:48.936] [LOG]    Module helper loaded: newsfeed
        [23:11:48.937] [LOG]    All module helpers loaded.
        [23:11:48.939] [LOG]    Starting server on port 8080 ...
        [23:11:48.962] [LOG]    Server started ...
        [23:11:48.964] [LOG]    Connecting socket for: updatenotification
        [23:11:48.966] [LOG]    Connecting socket for: calendar
        [23:11:48.967] [LOG]    Starting node helper for: calendar
        [23:11:48.969] [LOG]    Connecting socket for: newsfeed
        [23:11:48.970] [LOG]    Starting module: newsfeed
        [23:11:48.971] [LOG]    Sockets connected & modules started ...
        [23:11:49.186] [LOG]    Launching application.
        [23:11:52.113] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXX/basic.ics - Interval: 30000
        [23:11:52.265] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/XXXX - Interval: 30000
        [23:11:52.331] [LOG]    Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
          @Hubschra01 good, thank you
          last time you said
          But on the Mirror there is only the Desktop from Buster shown, not the Mirror Screen
          did the mirror app display correctly on the display this time? looks like it should have
          • H Offline
            Hubschra01
            Yes it did.
            I Start the Mirror again with
            pm2 restart MagicMirror
            and it works.
            Next step i flush the pm2 log and restart pm2 again.
            All works fine no errors.
            But if i reboot the pi the error appear again in the pm2 log…
              @Hubschra01
              ok do
              pm2 start  MagicMirror
              pm2 save
              • H Offline
                Hubschra01 @sdetweil
                OK i did it. what else?
                if i reboot pm2 log show this.
                pi@raspberrypi:~ $ pm2 log
                /home/pi/.pm2/pm2.log last 15 lines:
                PM2        | 2020-01-20T15:12:28: PM2 log: PM2 version          : 4.2.1
                PM2        | 2020-01-20T15:12:28: PM2 log: Node.js version      : 10.18.1
                PM2        | 2020-01-20T15:12:28: PM2 log: Current arch         : arm
                PM2        | 2020-01-20T15:12:28: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2020-01-20T15:12:28: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2020-01-20T15:12:28: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2020-01-20T15:12:28: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2020-01-20T15:12:28: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2020-01-20T15:12:28: PM2 log: Worker Interval      : 30000
                PM2        | 2020-01-20T15:12:28: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2020-01-20T15:12:28: PM2 log: Concurrent actions   : 2
                PM2        | 2020-01-20T15:12:28: PM2 log: SIGTERM timeout      : 1600
                PM2        | 2020-01-20T15:12:28: PM2 log: ===============================================================================
                PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] online
                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                0|MagicMir | npm ERR! code ELIFECYCLE
                0|MagicMir | npm ERR! errno 1
                0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                0|MagicMir | npm ERR! Exit status 1
                0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
                0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                0|MagicMir |
                0|MagicMir | npm ERR! A complete log of this run can be found in:
                0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T14_12_10_107Z-debug.log
                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|MagicMir | [15:12:38.792] [LOG]    Initializing new module helper ...
                0|MagicMir | [15:12:38.793] [LOG]    Module helper loaded: newsfeed
                0|MagicMir | [15:12:38.794] [LOG]    All module helpers loaded.
                0|MagicMir | [15:12:38.795] [LOG]    Starting server on port 8080 ...
                0|MagicMir | [15:12:38.819] [LOG]    Server started ...
                0|MagicMir | [15:12:38.820] [LOG]    Connecting socket for: updatenotification
                0|MagicMir | [15:12:38.822] [LOG]    Connecting socket for: calendar
                0|MagicMir | [15:12:38.823] [LOG]    Starting node helper for: calendar
                0|MagicMir | [15:12:38.825] [LOG]    Connecting socket for: newsfeed
                0|MagicMir | [15:12:38.826] [LOG]    Starting module: newsfeed
                0|MagicMir | [15:12:38.827] [LOG]    Sockets connected & modules started ...
                0|MagicMir | [15:12:39.460] [LOG]    Launching application.
                0|MagicMir | [15:12:43.347] [LOG]    Create new calendar fetcher for url: https:
                  @Hubschra01 said in Fresh install but pm2 error:
                  weird…
                  can u show that log
                  • H Offline
                    sure here it is:
                    1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                    2 info using npm@6.13.4
                    3 info using node@v10.18.1
                    5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                    6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                    7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                    8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/n$
                    9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
                    10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
                    11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
                    12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                    13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
                    13 verbose stack Exit status 1
                    13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/nod$
                    13 verbose stack     at EventEmitter.emit (events.js:198:13)
                    13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/nod$
                    13 verbose stack     at ChildProcess.emit (events.js:198:13)
                    13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                    13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_pro$
                    14 verbose pkgid magicmirror@2.10.1
                    15 verbose cwd /home/pi/MagicMirror
                    16 verbose Linux 4.19.75-v7+
                    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                    18 verbose node v10.18.1
                    19 verbose npm  v6.13.4
                    20 error code ELIFECYCLE
                    21 error errno 1
                    22 error magicmirror@2.10.1 start: `./run-start.sh`
                    22 error Exit status 1
                    23 error Failed at the magicmirror@2.10.1 start script.
                    23 error This is probably not a problem with npm. There is likely additional lo$
                    24 verbose exit [ 1, true ]
                      @Hubschra01 can u show output of
                      ls ~/MagicMirror/run-start.sh -laF
                      mine looks like
                      -rwxrwxr-x 1 sam sam 2399 Jan 16 09:55 /home/sam/MagicMirror/run-start.sh*
                      • H Offline
                        -rwxr-xr-x 1 pi pi 1989 Jan 16 20:05 /home/pi/MagicMirror/run-start.sh*
                        • 1 / 4
