    Fresh install but pm2 error
    37 Posts 2 Posters 13.3k Views 2 Watching
    • H Offline
      Hubschra01 @sdetweil
      OK i did it. what else?
      if i reboot pm2 log show this.
      pi@raspberrypi:~ $ pm2 log
      /home/pi/.pm2/pm2.log last 15 lines:
      PM2        | 2020-01-20T15:12:28: PM2 log: PM2 version          : 4.2.1
      PM2        | 2020-01-20T15:12:28: PM2 log: Node.js version      : 10.18.1
      PM2        | 2020-01-20T15:12:28: PM2 log: Current arch         : arm
      PM2        | 2020-01-20T15:12:28: PM2 log: PM2 home             : /home/pi/.pm2
      PM2        | 2020-01-20T15:12:28: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
      PM2        | 2020-01-20T15:12:28: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
      PM2        | 2020-01-20T15:12:28: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
      PM2        | 2020-01-20T15:12:28: PM2 log: Application log path : /home/pi/.pm2/logs
      PM2        | 2020-01-20T15:12:28: PM2 log: Worker Interval      : 30000
      PM2        | 2020-01-20T15:12:28: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
      PM2        | 2020-01-20T15:12:28: PM2 log: Concurrent actions   : 2
      PM2        | 2020-01-20T15:12:28: PM2 log: SIGTERM timeout      : 1600
      PM2        | 2020-01-20T15:12:28: PM2 log: ===============================================================================
      PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] online
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir | npm ERR! code ELIFECYCLE
      0|MagicMir | npm ERR! errno 1
      0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
      0|MagicMir | npm ERR! Exit status 1
      0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|MagicMir |
      0|MagicMir | npm ERR! A complete log of this run can be found in:
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T14_12_10_107Z-debug.log
      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
      0|MagicMir | [15:12:38.792] [LOG]    Initializing new module helper ...
      0|MagicMir | [15:12:38.793] [LOG]    Module helper loaded: newsfeed
      0|MagicMir | [15:12:38.794] [LOG]    All module helpers loaded.
      0|MagicMir | [15:12:38.795] [LOG]    Starting server on port 8080 ...
      0|MagicMir | [15:12:38.819] [LOG]    Server started ...
      0|MagicMir | [15:12:38.820] [LOG]    Connecting socket for: updatenotification
      0|MagicMir | [15:12:38.822] [LOG]    Connecting socket for: calendar
      0|MagicMir | [15:12:38.823] [LOG]    Starting node helper for: calendar
      0|MagicMir | [15:12:38.825] [LOG]    Connecting socket for: newsfeed
      0|MagicMir | [15:12:38.826] [LOG]    Starting module: newsfeed
      0|MagicMir | [15:12:38.827] [LOG]    Sockets connected & modules started ...
      0|MagicMir | [15:12:39.460] [LOG]    Launching application.
      0|MagicMir | [15:12:43.347] [LOG]    Create new calendar fetcher for url: https:
        sdetweil @Hubschra01
        @Hubschra01 said in Fresh install but pm2 error:
        weird…
        can u show that log
        • H Offline
          sure here it is:
          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
          2 info using npm@6.13.4
          3 info using node@v10.18.1
          5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
          6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
          7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
          8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/n$
          9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
          10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
          11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
          12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
          13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
          13 verbose stack Exit status 1
          13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/nod$
          13 verbose stack     at EventEmitter.emit (events.js:198:13)
          13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/nod$
          13 verbose stack     at ChildProcess.emit (events.js:198:13)
          13 verbose stack     at maybeClose (internal/child_process.js:982:16)
          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_pro$
          14 verbose pkgid magicmirror@2.10.1
          15 verbose cwd /home/pi/MagicMirror
          16 verbose Linux 4.19.75-v7+
          17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
          18 verbose node v10.18.1
          19 verbose npm  v6.13.4
          20 error code ELIFECYCLE
          21 error errno 1
          22 error magicmirror@2.10.1 start: `./run-start.sh`
          22 error Exit status 1
          23 error Failed at the magicmirror@2.10.1 start script.
          23 error This is probably not a problem with npm. There is likely additional lo$
          24 verbose exit [ 1, true ]
            @Hubschra01 can u show output of
            ls ~/MagicMirror/run-start.sh -laF
            mine looks like
            -rwxrwxr-x 1 sam sam 2399 Jan 16 09:55 /home/sam/MagicMirror/run-start.sh*
            • H Offline
              -rwxr-xr-x 1 pi pi 1989 Jan 16 20:05 /home/pi/MagicMirror/run-start.sh*
                @Hubschra01 weird…
                can u change line 1 of run-start.sh to
                #!/bin/bash -x
                do pm2 flush
                and then reboot
                then show the pm2 logs --lines=100
                this has got to be a permissions error
                • H Offline
                  here it is…
                  PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] exited with code                      [2] via signal [SIGINT]
                  PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
                  PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] online
                  PM2        | 2020-01-20T16:05:31: PM2 log: Stopping app:MagicMirror id:0
                  PM2        | 2020-01-20T16:05:31: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                  PM2        | 2020-01-20T16:05:32: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                  PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                  PM2        | 2020-01-20T16:05:33: PM2 log: Process with pid 1305 still alive aft                     er 1600ms, sending it SIGKILL now...
                  PM2        | 2020-01-20T16:05:33: PM2 log: App [MagicMirror:0] exited with code                      [0] via signal [SIGKILL]
                  PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=process killed
                  PM2        | 2020-01-20T16:05:33: PM2 log: PM2 successfully stopped
                  PM2        | 2020-01-20T16:05:48: PM2 log: =====================================                     ==========================================
                  PM2        | 2020-01-20T16:05:48: PM2 log: --- New PM2 Daemon started ----------                     ------------------------------------------
                  PM2        | 2020-01-20T16:05:48: PM2 log: Time                 : Mon Jan 20 202                     0 16:05:48 GMT+0100 (GMT+01:00)
                  PM2        | 2020-01-20T16:05:48: PM2 log: PM2 version          : 4.2.1
                  PM2        | 2020-01-20T16:05:48: PM2 log: Node.js version      : 10.18.1
                  PM2        | 2020-01-20T16:05:48: PM2 log: Current arch         : arm
                  PM2        | 2020-01-20T16:05:48: PM2 log: PM2 home             : /home/pi/.pm2
                  PM2        | 2020-01-20T16:05:48: PM2 log: PM2 PID file         : /home/pi/.pm2/                     pm2.pid
                  PM2        | 2020-01-20T16:05:48: PM2 log: RPC socket file      : /home/pi/.pm2/                     rpc.sock
                  PM2        | 2020-01-20T16:05:48: PM2 log: BUS socket file      : /home/pi/.pm2/                     pub.sock
                  PM2        | 2020-01-20T16:05:48: PM2 log: Application log path : /home/pi/.pm2/                     logs
                  PM2        | 2020-01-20T16:05:48: PM2 log: Worker Interval      : 30000
                  PM2        | 2020-01-20T16:05:48: PM2 log: Process dump file    : /home/pi/.pm2/                     dump.pm2
                  PM2        | 2020-01-20T16:05:48: PM2 log: Concurrent actions   : 2
                  PM2        | 2020-01-20T16:05:48: PM2 log: SIGTERM timeout      : 1600
                  PM2        | 2020-01-20T16:05:48: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
                  PM2        | 2020-01-20T16:05:49: PM2 log: App [MagicMirror:0] online
                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                  0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi'
                  0|MagicMir | ./run-start.sh: Zeile 68: `fi'
                  0|MagicMir | npm ERR! errno 2
                  0|MagicMir | npm ERR! Exit status 2
                  0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely a                     dditional logging output above.
                  0|MagicMir |
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T15_05_29_835Z-debug.log
                  0|MagicMir | + ./untrack-css.sh
                  0|MagicMir | + '[' -z :0 ']'
                  0|MagicMir | ++ uname -m
                  0|MagicMir | + arch=armv7l
                  0|MagicMir | + false=false
                  0|MagicMir | ++ grep -v '^\s//' config/config.js
                  0|MagicMir | ++ grep -i serveronly:
                  0|MagicMir | ++ tr -d ',"'\'''
                  0|MagicMir | ++ awk '{print tolower($2)}'
                  0|MagicMir | + serveronly=
                  0|MagicMir | + serveronly=false
                  0|MagicMir | ++ pgrep Xorg
                  0|MagicMir | + xorg=
                  0|MagicMir | + mac=Linux
                  0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']'
                  0|MagicMir | + '[' . == . -a Linux '!=' Darwin ']'
                  0|MagicMir | + '[' false. == true. -o . == . ']'
                  0|MagicMir | + node serveronly
                  0|MagicMir | + xorg=437
                  0|MagicMir | + '[' 437. == . -a Linux '!=' Darwin ']'
                  0|MagicMir | + electron js/electron.js
                  /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                  0|MagicMir |
                  0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                  0|MagicMir | > ./run-start.sh
                  0|MagicMir |
                  0|MagicMir | [16:05:33.029] [LOG]    Starting MagicMirror: v2.10.1
                  0|MagicMir | [16:05:33.045] [LOG]    Loading config ...
                  0|MagicMir | [16:05:33.054] [LOG]    Loading module helpers ...
                  0|MagicMir | [16:05:33.057] [LOG]    No helper found for module: alert.
                  0|MagicMir | [16:05:33.129] [LOG]    Initializing new module helper ...
                  0|MagicMir | [16:05:33.131] [LOG]    Module helper loaded: updatenotification
                  0|MagicMir | [16:05:33.132] [LOG]    No helper found for module: clock.
                  0|MagicMir |
                  0|MagicMir |
                  0|MagicMir | [16:05:56.837] [LOG]    Starting MagicMirror: v2.10.1
                  0|MagicMir | [16:05:56.853] [LOG]    Loading config ...
                  0|MagicMir | [16:05:56.872] [LOG]    Loading module helpers ...
                  0|MagicMir | [16:05:56.875] [LOG]    No helper found for module: alert.
                  0|MagicMir | [16:05:57.006] [LOG]    Initializing new module helper ...
                  0|MagicMir | [16:05:57.012] [LOG]    Module helper loaded: updatenotification
                  0|MagicMir | [16:05:57.014] [LOG]    No helper found for module: clock.
                  0|MagicMir | [16:05:58.224] [LOG]    Initializing new module helper ...
                  0|MagicMir | [16:05:58.225] [LOG]    Module helper loaded: calendar
                  0|MagicMir | [16:05:58.226] [LOG]    No helper found for module: currentweather.
                  0|MagicMir | [16:05:58.227] [LOG]    No helper found for module: weatherforecast                     .
                  0|MagicMir | [16:05:58.315] [LOG]    Initializing new module helper ...
                  0|MagicMir | [16:05:58.316] [LOG]    Module helper loaded: newsfeed
                  0|MagicMir | [16:05:58.316] [LOG]    All module helpers loaded.
                  0|MagicMir | [16:05:58.318] [LOG]    Starting server on port 8080 ...
                  0|MagicMir | [16:05:58.341] [LOG]    Server started ...
                  0|MagicMir | [16:05:58.343] [LOG]    Connecting socket for: updatenotification
                  0|MagicMir | [16:05:58.345] [LOG]    Connecting socket for: calendar
                  0|MagicMir | [16:05:58.346] [LOG]    Starting node helper for: calendar
                  0|MagicMir | [16:05:58.347] [LOG]    Connecting socket for: newsfeed
                  0|MagicMir | [16:05:58.349] [LOG]    Starting module: newsfeed
                  0|MagicMir | [16:05:58.349] [LOG]    Sockets connected & modules started ...
                  0|MagicMir | [16:05:59.000] [LOG]    Launching application.
                  0|MagicMir | [16:06:02.809] [LOG]    Create new calendar fetcher for url: https:
                    0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi’
                    there is the problem, syntax error…
                    can show the run-start.sh
                    I have to leave in about 15 minutes for the rest of the day
                    • H Offline
                      here is the run-start.sh
                      #!/bin/bash -x
                        # use bash instead of sh
                      ./untrack-css.sh
                      if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                      	export DISPLAY=:0 # Set by default display
                      fi
                      # get the processor architecture
                      arch=$(uname -m)
                      false='false'
                      # get the config option, if any
                      # only check non comment lines
                      serveronly=$(grep -v '^\s//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\')
                      # set default if not defined in config
                      serveronly=${serveronly:-false}
                      # check for xwindows running
                      xorg=$(pgrep Xorg)
                      #check for macOS
                      mac=$(uname)
                      # if the user requested serveronly OR
                      #    electron support for armv6l has been dropped OR
                      #    system is in text mode
                      if [ "$serveronly." != "false." -o  "$arch" == "armv6l" ] ||  [ "$xorg." == "." -a $mac != 'Darwin' ]; then
                      	# if user explicitly configured to run server only (no ui local)
                      	# OR there is no xwindows running, so no support for browser graphics
                      	if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
                      	  # start server mode,
                      	  node serveronly
                      	else
                      		# start the server in the background
                      		# wait for server to be ready
                      		# need bash for this
                      		exec 3< <(node serveronly)
                      		# Read the output of server line by line until one line 'point your browser'
                      		while read line; do
                      			 case "$line" in
                      			 *point\ your\ browser*)
                      					echo $line
                      					break
                      					echo $line
                      					#sleep .25
                      			 esac
                      		done <&3
                      		# Close the file descriptor
                      		exec 3<&-
                      		# lets use chrome to display here now
                      		# get the server port address from the ready message
                      		port=$(echo $line | awk -F\: '{print $4}')
                      		# start chromium
                      		echo "Starting chromium browser now, have patience, it takes a minute"
                      		chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                      		exit
                      	fi
                      else
                      	# we can use electron directly
                      	electron js/electron.js $1;
                      fi
                        @Hubschra01 i don’t know… weird… don’t have more time today
                          Are u running two copies?
                          pm2 status
                          • H Offline
                            Hubschra01
                            No it is only one to see…
                            pi@raspberrypi:~/MagicMirror $ pm2 status
                            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                            │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                              @Hubschra01 weird… delete that instance
                              pm2 delete 0
                              then run my fixup script
                              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                              • H Offline
                                PM2        | 2020-01-21T11:38:39: PM2 log: Node.js version      : 10.18.1
                                PM2        | 2020-01-21T11:38:39: PM2 log: Current arch         : arm
                                PM2        | 2020-01-21T11:38:39: PM2 log: PM2 home             : /home/pi/.pm2
                                PM2        | 2020-01-21T11:38:39: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                                PM2        | 2020-01-21T11:38:39: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                                PM2        | 2020-01-21T11:38:39: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                                PM2        | 2020-01-21T11:38:39: PM2 log: Application log path : /home/pi/.pm2/logs
                                PM2        | 2020-01-21T11:38:39: PM2 log: Worker Interval      : 30000
                                PM2        | 2020-01-21T11:38:39: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                                PM2        | 2020-01-21T11:38:39: PM2 log: Concurrent actions   : 2
                                PM2        | 2020-01-21T11:38:39: PM2 log: SIGTERM timeout      : 1600
                                0|MagicMir | + xorg=429
                                0|MagicMir | + '[' 429. == . -a Linux '!=' Darwin ']'
                                0|MagicMir | [11:38:49.100] [LOG]    Module helper loaded: calendar
                                0|MagicMir | [11:38:49.101] [LOG]    No helper found for module: currentweather.
                                0|MagicMir | [11:38:49.103] [LOG]    No helper found for module: weatherforecast.
                                0|MagicMir | [11:38:49.191] [LOG]    Initializing new module helper ...
                                0|MagicMir | [11:38:49.192] [LOG]    Module helper loaded: newsfeed
                                0|MagicMir | [11:38:49.193] [LOG]    All module helpers loaded.
                                0|MagicMir | [11:38:49.195] [LOG]    Starting server on port 8080 ...
                                0|MagicMir | [11:38:49.218] [LOG]    Server started ...
                                0|MagicMir | [11:38:49.220] [LOG]    Connecting socket for: updatenotification
                                0|MagicMir | [11:38:49.222] [LOG]    Connecting socket for: calendar
                                0|MagicMir | [11:38:49.223] [LOG]    Starting node helper for: calendar
                                0|MagicMir | [11:38:49.225] [LOG]    Connecting socket for: newsfeed
                                0|MagicMir | [11:38:49.226] [LOG]    Starting module: newsfeed
                                0|MagicMir | [11:38:49.227] [LOG]    Sockets connected & modules started ...
                                0|MagicMir | [11:38:49.889] [LOG]    Launching application.
                                0|MagicMirror  | [11:38:53.980] [LOG]
                                0|MagicMirror  | Create new calendar fetcher for url
                                  @Hubschra01 that looks good now, right?
                                  • H Offline
                                    I think so, if this below is not an Error.
                                    But what caused the error or what was the mistake?
                                      @Hubschra01 u can remove the -x from run-start.sh 1st line.
                                      That is just debugging
                                      • H Offline
                                        Strange…
                                        I flushed the log and i remove the -x from the run-start.sh.
                                        after reboot i see this in the log again.
                                        0|MagicMir |
                                        0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log
                                        8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                        13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                        13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                        13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                        21 error errno 1
                                        23 error This is probably not a problem with npm. There is likely additional logging output above.
                                        weird:pouting_face:
                                          @Hubschra01 and the mirror did not start?
                                          • H Offline
                                            The Mirror start an work fine now. :-) Thanks to you
                                            So i have to consider the error in the log as normal?
