    Fresh install but pm2 error
    37 Posts 2 Posters 15.3k Views 2 Watching
    • H
      Hubschra01
      sorry i forget this.
      This is the CLI output i tried now.
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      > magicmirror@2.10.1 start /home/pi/MagicMirror
      > ./run-start.sh
      [23:11:47.885] [LOG]    Starting MagicMirror: v2.10.1
      [23:11:47.902] [LOG]    Loading config ...
      [23:11:47.911] [LOG]    Loading module helpers ...
      [23:11:47.914] [LOG]    No helper found for module: alert.
      [23:11:48.008] [LOG]    Initializing new module helper ...
      [23:11:48.010] [LOG]    Module helper loaded: updatenotification
      [23:11:48.012] [LOG]    No helper found for module: clock.
      [23:11:48.875] [LOG]    Initializing new module helper ...
      [23:11:48.876] [LOG]    Module helper loaded: calendar
      [23:11:48.877] [LOG]    No helper found for module: currentweather.
      [23:11:48.878] [LOG]    No helper found for module: weatherforecast.
      [23:11:48.935] [LOG]    Initializing new module helper ...
      [23:11:48.936] [LOG]    Module helper loaded: newsfeed
      [23:11:48.937] [LOG]    All module helpers loaded.
      [23:11:48.939] [LOG]    Starting server on port 8080 ...
      [23:11:48.962] [LOG]    Server started ...
      [23:11:48.964] [LOG]    Connecting socket for: updatenotification
      [23:11:48.966] [LOG]    Connecting socket for: calendar
      [23:11:48.967] [LOG]    Starting node helper for: calendar
      [23:11:48.969] [LOG]    Connecting socket for: newsfeed
      [23:11:48.970] [LOG]    Starting module: newsfeed
      [23:11:48.971] [LOG]    Sockets connected & modules started ...
      [23:11:49.186] [LOG]    Launching application.
      [23:11:52.113] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXX/basic.ics - Interval: 30000
      [23:11:52.265] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/XXXX - Interval: 30000
      [23:11:52.331] [LOG]    Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
        sdetweil @Hubschra01
        @Hubschra01 good, thank you
        last time you said
        But on the Mirror there is only the Desktop from Buster shown, not the Mirror Screen
        did the mirror app display correctly on the display this time? looks like it should have
        • H
          Hubschra01
          Yes it did.
          I Start the Mirror again with
          pm2 restart MagicMirror
          and it works.
          Next step i flush the pm2 log and restart pm2 again.
          All works fine no errors.
          But if i reboot the pi the error appear again in the pm2 log…
            @Hubschra01
            ok do
            pm2 start  MagicMirror
            pm2 save
            H 1 Reply Last reply
            • H
              Hubschra01 @sdetweil
              OK i did it. what else?
              if i reboot pm2 log show this.
              pi@raspberrypi:~ $ pm2 log
              /home/pi/.pm2/pm2.log last 15 lines:
              PM2        | 2020-01-20T15:12:28: PM2 log: PM2 version          : 4.2.1
              PM2        | 2020-01-20T15:12:28: PM2 log: Node.js version      : 10.18.1
              PM2        | 2020-01-20T15:12:28: PM2 log: Current arch         : arm
              PM2        | 2020-01-20T15:12:28: PM2 log: PM2 home             : /home/pi/.pm2
              PM2        | 2020-01-20T15:12:28: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
              PM2        | 2020-01-20T15:12:28: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
              PM2        | 2020-01-20T15:12:28: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
              PM2        | 2020-01-20T15:12:28: PM2 log: Application log path : /home/pi/.pm2/logs
              PM2        | 2020-01-20T15:12:28: PM2 log: Worker Interval      : 30000
              PM2        | 2020-01-20T15:12:28: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
              PM2        | 2020-01-20T15:12:28: PM2 log: Concurrent actions   : 2
              PM2        | 2020-01-20T15:12:28: PM2 log: SIGTERM timeout      : 1600
              PM2        | 2020-01-20T15:12:28: PM2 log: ===============================================================================
              PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2        | 2020-01-20T15:12:28: PM2 log: App [MagicMirror:0] online
              /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
              0|MagicMir | npm ERR! code ELIFECYCLE
              0|MagicMir | npm ERR! errno 1
              0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
              0|MagicMir | npm ERR! Exit status 1
              0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
              0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              0|MagicMir |
              0|MagicMir | npm ERR! A complete log of this run can be found in:
              0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T14_12_10_107Z-debug.log
              /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
              0|MagicMir | [15:12:38.792] [LOG]    Initializing new module helper ...
              0|MagicMir | [15:12:38.793] [LOG]    Module helper loaded: newsfeed
              0|MagicMir | [15:12:38.794] [LOG]    All module helpers loaded.
              0|MagicMir | [15:12:38.795] [LOG]    Starting server on port 8080 ...
              0|MagicMir | [15:12:38.819] [LOG]    Server started ...
              0|MagicMir | [15:12:38.820] [LOG]    Connecting socket for: updatenotification
              0|MagicMir | [15:12:38.822] [LOG]    Connecting socket for: calendar
              0|MagicMir | [15:12:38.823] [LOG]    Starting node helper for: calendar
              0|MagicMir | [15:12:38.825] [LOG]    Connecting socket for: newsfeed
              0|MagicMir | [15:12:38.826] [LOG]    Starting module: newsfeed
              0|MagicMir | [15:12:38.827] [LOG]    Sockets connected & modules started ...
              0|MagicMir | [15:12:39.460] [LOG]    Launching application.
              0|MagicMir | [15:12:43.347] [LOG]    Create new calendar fetcher for url: https:
                @Hubschra01 said in Fresh install but pm2 error:
                weird…
                can u show that log
                • H
                  sure here it is:
                  1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                  2 info using npm@6.13.4
                  3 info using node@v10.18.1
                  5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                  6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                  7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                  8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/n$
                  9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror
                  10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ]
                  11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1  signal: null
                  12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                  13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh`
                  13 verbose stack Exit status 1
                  13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/nod$
                  13 verbose stack     at EventEmitter.emit (events.js:198:13)
                  13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/nod$
                  13 verbose stack     at ChildProcess.emit (events.js:198:13)
                  13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                  13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_pro$
                  14 verbose pkgid magicmirror@2.10.1
                  15 verbose cwd /home/pi/MagicMirror
                  16 verbose Linux 4.19.75-v7+
                  17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                  18 verbose node v10.18.1
                  19 verbose npm  v6.13.4
                  20 error code ELIFECYCLE
                  21 error errno 1
                  22 error magicmirror@2.10.1 start: `./run-start.sh`
                  22 error Exit status 1
                  23 error Failed at the magicmirror@2.10.1 start script.
                  23 error This is probably not a problem with npm. There is likely additional lo$
                  24 verbose exit [ 1, true ]
                    @Hubschra01 can u show output of
                    ls ~/MagicMirror/run-start.sh -laF
                    mine looks like
                    -rwxrwxr-x 1 sam sam 2399 Jan 16 09:55 /home/sam/MagicMirror/run-start.sh*
                    • H
                      -rwxr-xr-x 1 pi pi 1989 Jan 16 20:05 /home/pi/MagicMirror/run-start.sh*
                        @Hubschra01 weird…
                        can u change line 1 of run-start.sh to
                        #!/bin/bash -x
                        do pm2 flush
                        and then reboot
                        then show the pm2 logs --lines=100
                        this has got to be a permissions error
                        • H
                          here it is…
                          PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] exited with code                      [2] via signal [SIGINT]
                          PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
                          PM2        | 2020-01-20T16:05:29: PM2 log: App [MagicMirror:0] online
                          PM2        | 2020-01-20T16:05:31: PM2 log: Stopping app:MagicMirror id:0
                          PM2        | 2020-01-20T16:05:31: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                          PM2        | 2020-01-20T16:05:32: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                          PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=failed to kill - retryin                     g in 100ms
                          PM2        | 2020-01-20T16:05:33: PM2 log: Process with pid 1305 still alive aft                     er 1600ms, sending it SIGKILL now...
                          PM2        | 2020-01-20T16:05:33: PM2 log: App [MagicMirror:0] exited with code                      [0] via signal [SIGKILL]
                          PM2        | 2020-01-20T16:05:33: PM2 log: pid=1305 msg=process killed
                          PM2        | 2020-01-20T16:05:33: PM2 log: PM2 successfully stopped
                          PM2        | 2020-01-20T16:05:48: PM2 log: =====================================                     ==========================================
                          PM2        | 2020-01-20T16:05:48: PM2 log: --- New PM2 Daemon started ----------                     ------------------------------------------
                          PM2        | 2020-01-20T16:05:48: PM2 log: Time                 : Mon Jan 20 202                     0 16:05:48 GMT+0100 (GMT+01:00)
                          PM2        | 2020-01-20T16:05:48: PM2 log: PM2 version          : 4.2.1
                          PM2        | 2020-01-20T16:05:48: PM2 log: Node.js version      : 10.18.1
                          PM2        | 2020-01-20T16:05:48: PM2 log: Current arch         : arm
                          PM2        | 2020-01-20T16:05:48: PM2 log: PM2 home             : /home/pi/.pm2
                          PM2        | 2020-01-20T16:05:48: PM2 log: PM2 PID file         : /home/pi/.pm2/                     pm2.pid
                          PM2        | 2020-01-20T16:05:48: PM2 log: RPC socket file      : /home/pi/.pm2/                     rpc.sock
                          PM2        | 2020-01-20T16:05:48: PM2 log: BUS socket file      : /home/pi/.pm2/                     pub.sock
                          PM2        | 2020-01-20T16:05:48: PM2 log: Application log path : /home/pi/.pm2/                     logs
                          PM2        | 2020-01-20T16:05:48: PM2 log: Worker Interval      : 30000
                          PM2        | 2020-01-20T16:05:48: PM2 log: Process dump file    : /home/pi/.pm2/                     dump.pm2
                          PM2        | 2020-01-20T16:05:48: PM2 log: Concurrent actions   : 2
                          PM2        | 2020-01-20T16:05:48: PM2 log: SIGTERM timeout      : 1600
                          PM2        | 2020-01-20T16:05:48: PM2 log: App [MagicMirror:0] starting in -fork                      mode-
                          PM2        | 2020-01-20T16:05:49: PM2 log: App [MagicMirror:0] online
                          /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                          0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi'
                          0|MagicMir | ./run-start.sh: Zeile 68: `fi'
                          0|MagicMir | npm ERR! errno 2
                          0|MagicMir | npm ERR! Exit status 2
                          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely a                     dditional logging output above.
                          0|MagicMir |
                          0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-01-20T15_05_29_835Z-debug.log
                          0|MagicMir | + ./untrack-css.sh
                          0|MagicMir | + '[' -z :0 ']'
                          0|MagicMir | ++ uname -m
                          0|MagicMir | + arch=armv7l
                          0|MagicMir | + false=false
                          0|MagicMir | ++ grep -v '^\s//' config/config.js
                          0|MagicMir | ++ grep -i serveronly:
                          0|MagicMir | ++ tr -d ',"'\'''
                          0|MagicMir | ++ awk '{print tolower($2)}'
                          0|MagicMir | + serveronly=
                          0|MagicMir | + serveronly=false
                          0|MagicMir | ++ pgrep Xorg
                          0|MagicMir | + xorg=
                          0|MagicMir | + mac=Linux
                          0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']'
                          0|MagicMir | + '[' . == . -a Linux '!=' Darwin ']'
                          0|MagicMir | + '[' false. == true. -o . == . ']'
                          0|MagicMir | + node serveronly
                          0|MagicMir | + xorg=437
                          0|MagicMir | + '[' 437. == . -a Linux '!=' Darwin ']'
                          0|MagicMir | + electron js/electron.js
                          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                          0|MagicMir |
                          0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
                          0|MagicMir | > ./run-start.sh
                          0|MagicMir |
                          0|MagicMir | [16:05:33.029] [LOG]    Starting MagicMirror: v2.10.1
                          0|MagicMir | [16:05:33.045] [LOG]    Loading config ...
                          0|MagicMir | [16:05:33.054] [LOG]    Loading module helpers ...
                          0|MagicMir | [16:05:33.057] [LOG]    No helper found for module: alert.
                          0|MagicMir | [16:05:33.129] [LOG]    Initializing new module helper ...
                          0|MagicMir | [16:05:33.131] [LOG]    Module helper loaded: updatenotification
                          0|MagicMir | [16:05:33.132] [LOG]    No helper found for module: clock.
                          0|MagicMir |
                          0|MagicMir |
                          0|MagicMir | [16:05:56.837] [LOG]    Starting MagicMirror: v2.10.1
                          0|MagicMir | [16:05:56.853] [LOG]    Loading config ...
                          0|MagicMir | [16:05:56.872] [LOG]    Loading module helpers ...
                          0|MagicMir | [16:05:56.875] [LOG]    No helper found for module: alert.
                          0|MagicMir | [16:05:57.006] [LOG]    Initializing new module helper ...
                          0|MagicMir | [16:05:57.012] [LOG]    Module helper loaded: updatenotification
                          0|MagicMir | [16:05:57.014] [LOG]    No helper found for module: clock.
                          0|MagicMir | [16:05:58.224] [LOG]    Initializing new module helper ...
                          0|MagicMir | [16:05:58.225] [LOG]    Module helper loaded: calendar
                          0|MagicMir | [16:05:58.226] [LOG]    No helper found for module: currentweather.
                          0|MagicMir | [16:05:58.227] [LOG]    No helper found for module: weatherforecast                     .
                          0|MagicMir | [16:05:58.315] [LOG]    Initializing new module helper ...
                          0|MagicMir | [16:05:58.316] [LOG]    Module helper loaded: newsfeed
                          0|MagicMir | [16:05:58.316] [LOG]    All module helpers loaded.
                          0|MagicMir | [16:05:58.318] [LOG]    Starting server on port 8080 ...
                          0|MagicMir | [16:05:58.341] [LOG]    Server started ...
                          0|MagicMir | [16:05:58.343] [LOG]    Connecting socket for: updatenotification
                          0|MagicMir | [16:05:58.345] [LOG]    Connecting socket for: calendar
                          0|MagicMir | [16:05:58.346] [LOG]    Starting node helper for: calendar
                          0|MagicMir | [16:05:58.347] [LOG]    Connecting socket for: newsfeed
                          0|MagicMir | [16:05:58.349] [LOG]    Starting module: newsfeed
                          0|MagicMir | [16:05:58.349] [LOG]    Sockets connected & modules started ...
                          0|MagicMir | [16:05:59.000] [LOG]    Launching application.
                          0|MagicMir | [16:06:02.809] [LOG]    Create new calendar fetcher for url: https:
                            0|MagicMir | ./run-start.sh: Zeile 68: Syntaxfehler beim unerwarteten Wort `fi’
                            there is the problem, syntax error…
                            can show the run-start.sh
                            I have to leave in about 15 minutes for the rest of the day
                            • H
                              here is the run-start.sh
                              #!/bin/bash -x
                                # use bash instead of sh
                              ./untrack-css.sh
                              if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                              	export DISPLAY=:0 # Set by default display
                              fi
                              # get the processor architecture
                              arch=$(uname -m)
                              false='false'
                              # get the config option, if any
                              # only check non comment lines
                              serveronly=$(grep -v '^\s//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\')
                              # set default if not defined in config
                              serveronly=${serveronly:-false}
                              # check for xwindows running
                              xorg=$(pgrep Xorg)
                              #check for macOS
                              mac=$(uname)
                              # if the user requested serveronly OR
                              #    electron support for armv6l has been dropped OR
                              #    system is in text mode
                              if [ "$serveronly." != "false." -o  "$arch" == "armv6l" ] ||  [ "$xorg." == "." -a $mac != 'Darwin' ]; then
                              	# if user explicitly configured to run server only (no ui local)
                              	# OR there is no xwindows running, so no support for browser graphics
                              	if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
                              	  # start server mode,
                              	  node serveronly
                              	else
                              		# start the server in the background
                              		# wait for server to be ready
                              		# need bash for this
                              		exec 3< <(node serveronly)
                              		# Read the output of server line by line until one line 'point your browser'
                              		while read line; do
                              			 case "$line" in
                              			 *point\ your\ browser*)
                              					echo $line
                              					break
                              					echo $line
                              					#sleep .25
                              			 esac
                              		done <&3
                              		# Close the file descriptor
                              		exec 3<&-
                              		# lets use chrome to display here now
                              		# get the server port address from the ready message
                              		port=$(echo $line | awk -F\: '{print $4}')
                              		# start chromium
                              		echo "Starting chromium browser now, have patience, it takes a minute"
                              		chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                              		exit
                              	fi
                              else
                              	# we can use electron directly
                              	electron js/electron.js $1;
                              fi
                                @Hubschra01 i don’t know… weird… don’t have more time today
                                  Are u running two copies?
                                  pm2 status
                                  • H
                                    Hubschra01
                                    No it is only one to see…
                                    pi@raspberrypi:~/MagicMirror $ pm2 status
                                    │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                    │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                                      @Hubschra01 weird… delete that instance
                                      pm2 delete 0
                                      then run my fixup script
                                      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                      • H
                                        PM2        | 2020-01-21T11:38:39: PM2 log: Node.js version      : 10.18.1
                                        PM2        | 2020-01-21T11:38:39: PM2 log: Current arch         : arm
                                        PM2        | 2020-01-21T11:38:39: PM2 log: PM2 home             : /home/pi/.pm2
                                        PM2        | 2020-01-21T11:38:39: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                                        PM2        | 2020-01-21T11:38:39: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                                        PM2        | 2020-01-21T11:38:39: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                                        PM2        | 2020-01-21T11:38:39: PM2 log: Application log path : /home/pi/.pm2/logs
                                        PM2        | 2020-01-21T11:38:39: PM2 log: Worker Interval      : 30000
                                        PM2        | 2020-01-21T11:38:39: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                                        PM2        | 2020-01-21T11:38:39: PM2 log: Concurrent actions   : 2
                                        PM2        | 2020-01-21T11:38:39: PM2 log: SIGTERM timeout      : 1600
                                        0|MagicMir | + xorg=429
                                        0|MagicMir | + '[' 429. == . -a Linux '!=' Darwin ']'
                                        0|MagicMir | [11:38:49.100] [LOG]    Module helper loaded: calendar
                                        0|MagicMir | [11:38:49.101] [LOG]    No helper found for module: currentweather.
                                        0|MagicMir | [11:38:49.103] [LOG]    No helper found for module: weatherforecast.
                                        0|MagicMir | [11:38:49.191] [LOG]    Initializing new module helper ...
                                        0|MagicMir | [11:38:49.192] [LOG]    Module helper loaded: newsfeed
                                        0|MagicMir | [11:38:49.193] [LOG]    All module helpers loaded.
                                        0|MagicMir | [11:38:49.195] [LOG]    Starting server on port 8080 ...
                                        0|MagicMir | [11:38:49.218] [LOG]    Server started ...
                                        0|MagicMir | [11:38:49.220] [LOG]    Connecting socket for: updatenotification
                                        0|MagicMir | [11:38:49.222] [LOG]    Connecting socket for: calendar
                                        0|MagicMir | [11:38:49.223] [LOG]    Starting node helper for: calendar
                                        0|MagicMir | [11:38:49.225] [LOG]    Connecting socket for: newsfeed
                                        0|MagicMir | [11:38:49.226] [LOG]    Starting module: newsfeed
                                        0|MagicMir | [11:38:49.227] [LOG]    Sockets connected & modules started ...
                                        0|MagicMir | [11:38:49.889] [LOG]    Launching application.
                                        0|MagicMirror  | [11:38:53.980] [LOG]
                                        0|MagicMirror  | Create new calendar fetcher for url
                                          @Hubschra01 that looks good now, right?
                                          • H
                                            I think so, if this below is not an Error.
                                            But what caused the error or what was the mistake?
