    MMM-AssistantMk2
    16 Posts 3 Posters 5.6k Views 2 Watching
    • L Offline
      ludacriss57
      I’m sorry but there I am lost.
      I am French, I put in:
      module: “MMM-YouTube”,
      hl: “fr”,
      but i still don’t know what to say to the wizard to stop reading.
      I also put in:
      module: “MMM-AssistantMk2”
      recipes: [“with-MMM-Hotword.js”, “with-MMM-Youtube.js”],
      am I good until then?
      ChrisC 2 Replies Last reply Reply Quote 0
      • L Offline
        ludacriss57
        Where can I find the command list for the FR language?
        • ChrisC Offline
          Chris @ludacriss57
          @ludacriss57 said in MMM-AssistantMk2:
          hl: “fr”,
          Strangely, I did not need to put it in French for youtube to work.
          To stop it, I just say SmartMirror.
          I also try to say “stop the video” but it doesn’t work.
          Maybe if Sean or Bugsounet goes through there, they can explain the procedure to us.
          Yes, that’s what I put in my configuration and it works.
          Regards
          • L Offline
            ludacriss57
            In fact I feel like my problem is more complicated than that.
            if I deactivate MMM-Hotword and put MMM-AssistantMk2 back in normal voice mode (without recipe), it is impossible to trigger the assistant with “ok google”.
            as if he couldn’t hear me on MMM-AssistantMk2 but he heard me on MMM-HOTWORD.
            and actually at the install I had errors when I configure the microphone.
            but why does it work with hotword?
            I can not place orders from youtube by hotword?
            thank you
            • L Offline
              ludacriss57
              here is my config file on the interesting part
                module: "MMM-AssistantMk2",
                position: "top_center",
                  ui: "Classic",
                  assistantConfig: {
                  latitude: *****,
                  longitude: *****,
              responseConfig: {
                    useScreenOutput: true,
                    useAudioOutput: true,
                    useChime: true,
                    timer: 5000,
                    myMagicWord: false
                 micConfig: { // put there configuration generated by auto-installer
                   recorder: "arecord",
                   device: "plughw:1",
              recipes: [ "with-MMM-Hotword.js", "with-MMM-Youtube.js", "Reboot-Restart-Shutdown.js" ],
              profiles: {
                    "default": {
                      profileFile: "default.json",
                      lang: "fr-FR",
              • L Offline
                ludacriss57
                module: "MMM-Hotword",
                position: "bottom_left",
                  useDisplay: false,
                  chimeOnFinish: null,
                  recipes: ["with-AMk2v3-noisy_Jarvis.js"],
                  mic: {
                    recordProgram: "arecord",
                    device: "plughw:1",
                • L Offline
                  ludacriss57
                    module: "MMM-YouTube",
                    position: "bottom_center",
                      verbose:true,
                      defaultQuality: "default",
                      disableCC: true,
                      showPlayingOnly: true,
                      defaultLoop: false,
                      defaultShuffle: false,
                      defaultAutoplay: true,
                      onStartPlay: null,
                      playerVars: {
                        controls: 0,
                        hl: "fr",
                        enablejsapi: 1,
                        showinfo: 0,
                        rel: 0,
                        cc_load_policy: 0,
                    meusprojetoskali @ludacriss57
                    @ludacriss57 I have the same problem, everything works fine, but does not respond to the STOP VIDEO, PAUSE VIDEO commands …
                    If you can solve it, please tell us what the solution was.
                    • L Offline
                      ludacriss57
                      did you happen triggered the google assistant without mmm-hotword?
                      does it respond to “ok google”?
                      I already have a problem there. it does not respond to the recipe of mmm-assisantmk2.
                      ChrisC 1 Reply Last reply Reply Quote 0
                      • ChrisC Offline
                        Chris @ludacriss57
                        @ludacriss57
                        I don’t think MMM-AssistantMK2 can work without MMM-Hotword.
                        See my exchange with Sean on this subject.
                        Regards,
