    MMM-AssistantMk2
    16 Posts 3 Posters 5.6k Views 2 Watching
    • L Offline
      ludacriss57
      Where can I find the command list for the FR language?
      • ChrisC Offline
        Chris @ludacriss57
        @ludacriss57 said in MMM-AssistantMk2:
        I’m sorry but there I am lost.
        I am French, I put in:
        module: “MMM-YouTube”,
        hl: “fr”,
        but i still don’t know what to say to the wizard to stop reading.
        Strangely, I did not need to put it in French for youtube to work.
        To stop it, I just say SmartMirror.
        I also try to say “stop the video” but it doesn’t work.
        Maybe if Sean or Bugsounet goes through there, they can explain the procedure to us.
        module: “MMM-AssistantMk2”
        recipes: [“with-MMM-Hotword.js”, “with-MMM-Youtube.js”],
        am I good until then?
        Yes, that’s what I put in my configuration and it works.
        Regards
        • L Offline
          ludacriss57
          In fact I feel like my problem is more complicated than that.
          if I deactivate MMM-Hotword and put MMM-AssistantMk2 back in normal voice mode (without recipe), it is impossible to trigger the assistant with “ok google”.
          as if he couldn’t hear me on MMM-AssistantMk2 but he heard me on MMM-HOTWORD.
          and actually at the install I had errors when I configure the microphone.
          but why does it work with hotword?
          I can not place orders from youtube by hotword?
          thank you
          • L Offline
            ludacriss57
            here is my config file on the interesting part
              module: "MMM-AssistantMk2",
              position: "top_center",
                ui: "Classic",
                assistantConfig: {
                latitude: *****,
                longitude: *****,
            responseConfig: {
                  useScreenOutput: true,
                  useAudioOutput: true,
                  useChime: true,
                  timer: 5000,
                  myMagicWord: false
               micConfig: { // put there configuration generated by auto-installer
                 recorder: "arecord",
                 device: "plughw:1",
            recipes: [ "with-MMM-Hotword.js", "with-MMM-Youtube.js", "Reboot-Restart-Shutdown.js" ],
            profiles: {
                  "default": {
                    profileFile: "default.json",
                    lang: "fr-FR",
            • L Offline
              ludacriss57
              module: "MMM-Hotword",
              position: "bottom_left",
                useDisplay: false,
                chimeOnFinish: null,
                recipes: ["with-AMk2v3-noisy_Jarvis.js"],
                mic: {
                  recordProgram: "arecord",
                  device: "plughw:1",
              • L Offline
                ludacriss57
                  module: "MMM-YouTube",
                  position: "bottom_center",
                    verbose:true,
                    defaultQuality: "default",
                    disableCC: true,
                    showPlayingOnly: true,
                    defaultLoop: false,
                    defaultShuffle: false,
                    defaultAutoplay: true,
                    onStartPlay: null,
                    playerVars: {
                      controls: 0,
                      hl: "fr",
                      enablejsapi: 1,
                      showinfo: 0,
                      rel: 0,
                      cc_load_policy: 0,
                  meusprojetoskali @ludacriss57
                  @ludacriss57 I have the same problem, everything works fine, but does not respond to the STOP VIDEO, PAUSE VIDEO commands …
                  If you can solve it, please tell us what the solution was.
                  • L Offline
                    ludacriss57
                    did you happen triggered the google assistant without mmm-hotword?
                    does it respond to “ok google”?
                    I already have a problem there. it does not respond to the recipe of mmm-assisantmk2.
                    ChrisC 1 Reply Last reply Reply Quote 0
                    • ChrisC Offline
                      Chris @ludacriss57
                      @ludacriss57
                      I don’t think MMM-AssistantMK2 can work without MMM-Hotword.
                      See my exchange with Sean on this subject.
                      Regards,
                      • ChrisC Offline
                        Chris @ludacriss57
                        Sean just gave the answer to your problem here,
                        Regards,
