    MMM-AssistantMk2
    16 Posts 3 Posters 6.9k Views 2 Watching
    • L
      ludacriss57
      thank you !
      it works.
      well I have a problem, how do we control it by voice?
      stop youtube it doesn’t work, it’s looking for an application that doesn’t exist.
      • ChrisC
        Chris
        Consult the module wiki.
        In the prepared recipes tab, it says:
        with-MMM-Youtube.js
        Youtube links detector. If a link with youtube is detected, the video is displayed.
        Youtube playlist detector
        You can also use youtube keyword to force search
        Vocal Control to stop video (modify pattern in your prefered language)
        Mute volune on assistant query
        known bugs : on Fullscreen ui, video is stopped when assistant activate
        Regards,
        • L
          ludacriss57
          I’m sorry but there I am lost.
          I am French, I put in:
          module: “MMM-YouTube”,
          hl: “fr”,
          but i still don’t know what to say to the wizard to stop reading.
          I also put in:
          module: “MMM-AssistantMk2”
          recipes: [“with-MMM-Hotword.js”, “with-MMM-Youtube.js”],
          am I good until then?
          ChrisC 2 Replies Last reply
          • L
            ludacriss57
            Where can I find the command list for the FR language?
            • ChrisC
              Chris @ludacriss57
              @ludacriss57 said in MMM-AssistantMk2:
              hl: “fr”,
              Strangely, I did not need to put it in French for youtube to work.
              To stop it, I just say SmartMirror.
              I also try to say “stop the video” but it doesn’t work.
              Maybe if Sean or Bugsounet goes through there, they can explain the procedure to us.
              Yes, that’s what I put in my configuration and it works.
              Regards
              • L
                ludacriss57
                In fact I feel like my problem is more complicated than that.
                if I deactivate MMM-Hotword and put MMM-AssistantMk2 back in normal voice mode (without recipe), it is impossible to trigger the assistant with “ok google”.
                as if he couldn’t hear me on MMM-AssistantMk2 but he heard me on MMM-HOTWORD.
                and actually at the install I had errors when I configure the microphone.
                but why does it work with hotword?
                I can not place orders from youtube by hotword?
                thank you
                • L
                  ludacriss57
                  here is my config file on the interesting part
                    module: "MMM-AssistantMk2",
                    position: "top_center",
                      ui: "Classic",
                      assistantConfig: {
                      latitude: *****,
                      longitude: *****,
                  responseConfig: {
                        useScreenOutput: true,
                        useAudioOutput: true,
                        useChime: true,
                        timer: 5000,
                        myMagicWord: false
                     micConfig: { // put there configuration generated by auto-installer
                       recorder: "arecord",
                       device: "plughw:1",
                  recipes: [ "with-MMM-Hotword.js", "with-MMM-Youtube.js", "Reboot-Restart-Shutdown.js" ],
                  profiles: {
                        "default": {
                          profileFile: "default.json",
                          lang: "fr-FR",
                  • L
                    ludacriss57
                    module: "MMM-Hotword",
                    position: "bottom_left",
                      useDisplay: false,
                      chimeOnFinish: null,
                      recipes: ["with-AMk2v3-noisy_Jarvis.js"],
                      mic: {
                        recordProgram: "arecord",
                        device: "plughw:1",
                    M 1 Reply Last reply
                    • L
                      ludacriss57
                        module: "MMM-YouTube",
                        position: "bottom_center",
                          verbose:true,
                          defaultQuality: "default",
                          disableCC: true,
                          showPlayingOnly: true,
                          defaultLoop: false,
                          defaultShuffle: false,
                          defaultAutoplay: true,
                          onStartPlay: null,
                          playerVars: {
                            controls: 0,
                            hl: "fr",
                            enablejsapi: 1,
                            showinfo: 0,
                            rel: 0,
                            cc_load_policy: 0,
                        meusprojetoskali @ludacriss57
                        @ludacriss57 I have the same problem, everything works fine, but does not respond to the STOP VIDEO, PAUSE VIDEO commands …
                        If you can solve it, please tell us what the solution was.
                        • L
                          ludacriss57
                          did you happen triggered the google assistant without mmm-hotword?
                          does it respond to “ok google”?
                          I already have a problem there. it does not respond to the recipe of mmm-assisantmk2.
                          ChrisC 1 Reply Last reply
                          • ChrisC
                            Chris @ludacriss57
                            @ludacriss57
                            I don’t think MMM-AssistantMK2 can work without MMM-Hotword.
                            See my exchange with Sean on this subject.
                            Regards,
                            • ChrisC
                              Chris @ludacriss57
                              Sean just gave the answer to your problem here,
                              Regards,
                              • L
                                ludacriss57
                                Thank you for the link
