    MMM-AssistantMk2
    16 Posts 3 Posters 6.7k Views 2 Watching
    • ChrisC Offline
      Chris @ludacriss57
      @ludacriss57 said in MMM-AssistantMk2:
      I’m sorry but there I am lost.
      I am French, I put in:
      module: “MMM-YouTube”,
      hl: “fr”,
      but i still don’t know what to say to the wizard to stop reading.
      Strangely, I did not need to put it in French for youtube to work.
      To stop it, I just say SmartMirror.
      I also try to say “stop the video” but it doesn’t work.
      Maybe if Sean or Bugsounet goes through there, they can explain the procedure to us.
      module: “MMM-AssistantMk2”
      recipes: [“with-MMM-Hotword.js”, “with-MMM-Youtube.js”],
      am I good until then?
      Yes, that’s what I put in my configuration and it works.
      Regards
      • L Offline
        ludacriss57
        In fact I feel like my problem is more complicated than that.
        if I deactivate MMM-Hotword and put MMM-AssistantMk2 back in normal voice mode (without recipe), it is impossible to trigger the assistant with “ok google”.
        as if he couldn’t hear me on MMM-AssistantMk2 but he heard me on MMM-HOTWORD.
        and actually at the install I had errors when I configure the microphone.
        but why does it work with hotword?
        I can not place orders from youtube by hotword?
        thank you
        • L Offline
          ludacriss57
          here is my config file on the interesting part
            module: "MMM-AssistantMk2",
            position: "top_center",
              ui: "Classic",
              assistantConfig: {
              latitude: *****,
              longitude: *****,
          responseConfig: {
                useScreenOutput: true,
                useAudioOutput: true,
                useChime: true,
                timer: 5000,
                myMagicWord: false
             micConfig: { // put there configuration generated by auto-installer
               recorder: "arecord",
               device: "plughw:1",
          recipes: [ "with-MMM-Hotword.js", "with-MMM-Youtube.js", "Reboot-Restart-Shutdown.js" ],
          profiles: {
                "default": {
                  profileFile: "default.json",
                  lang: "fr-FR",
          • L Offline
            ludacriss57
            module: "MMM-Hotword",
            position: "bottom_left",
              useDisplay: false,
              chimeOnFinish: null,
              recipes: ["with-AMk2v3-noisy_Jarvis.js"],
              mic: {
                recordProgram: "arecord",
                device: "plughw:1",
            • L Offline
              ludacriss57
                module: "MMM-YouTube",
                position: "bottom_center",
                  verbose:true,
                  defaultQuality: "default",
                  disableCC: true,
                  showPlayingOnly: true,
                  defaultLoop: false,
                  defaultShuffle: false,
                  defaultAutoplay: true,
                  onStartPlay: null,
                  playerVars: {
                    controls: 0,
                    hl: "fr",
                    enablejsapi: 1,
                    showinfo: 0,
                    rel: 0,
                    cc_load_policy: 0,
                meusprojetoskali @ludacriss57
                @ludacriss57 I have the same problem, everything works fine, but does not respond to the STOP VIDEO, PAUSE VIDEO commands …
                If you can solve it, please tell us what the solution was.
                • L Offline
                  ludacriss57
                  did you happen triggered the google assistant without mmm-hotword?
                  does it respond to “ok google”?
                  I already have a problem there. it does not respond to the recipe of mmm-assisantmk2.
                  ChrisC 1 Reply Last reply Reply Quote 0
                  • ChrisC Offline
                    Chris @ludacriss57
                    @ludacriss57
                    I don’t think MMM-AssistantMK2 can work without MMM-Hotword.
                    See my exchange with Sean on this subject.
                    Regards,
                    • ChrisC Offline
                      Chris @ludacriss57
                      Where can I find the command list for the FR language?
                      Sean just gave the answer to your problem here,
                      Regards,
                      • L Offline
                        ludacriss57
                        Thank you for the link
