    Rpi 4 and two monitors
    60 Posts 6 Posters 40.4k Views 6 Watching
    • N Offline
      NathTheDude
      Has anyone tried building a MM with an rpi4 and attaching two monitors?
      I wanted two hook up to 21.5 inch monitors as it would be cheaper than getting a slim 30+ inch monitor.
        sdetweil @NathTheDude
        @NathTheDude it should be simple, it appears the dual monitors is one big desktop by default.
        MM should extend over both as one single display.
        • N Offline
          NathTheDude @sdetweil
          @sdetweil thanks.
          I found it had to get cheaper monitors that are both slim and gave small bezel. Not sure how will look with about 3-4cm of bezel in the middle.
            chassain 0
            i tried to use a rpi4 with 2 hdmi on the same tv and the result is ok. You just need to adjust resolution on screen menu hdmi 1 and hdmi 2.
            It’s a solution for my work to use only one raspberry with 2 screen televisions.
            • N Offline
              NathTheDude
              Hey @sdetweil and @chassain-0 , so my kit for my v2 project has arrived. I have two 21.5 inch (same model) monitors connected up to an RPI4.
              I have had a look around the forum but not been able to see what the best method is for this. When we start pm2 or when the RPI reboots it will boot up with the MM on the first screen and the normal desktop seen on the 2nd screen.
              I think I would prefer to have two MM’s installed (one for each monitor), I assume this is ok todo or is the best approach to have the one MM on both screens?
              Nathan
              B S 2 Replies Last reply Reply Quote 0
              • N Offline
                NathTheDude
                I wondered if I needed to update the ‘mm.sh’ file within the ‘installers’ folder, I tried changing this from ‘0’ to ‘1’ - reboot the RPI but on reboot MM does not get started on either monitor.
                pi@MagicMirrors:~/MagicMirror/installers $ tvservice --list
                2 attached device(s), display ID’s are :
                Display Number 2, type HDMI 0
                Display Number 7, type HDMI 1
                  bhepler Module Developer @NathTheDude
                  @NathTheDude - I tried that one-pi-two-instances thing a couple years ago. I wasn’t using an RPI but rather a tiny Ubuntu box. My problem was that I couldn’t find a way to guarantee which instance would appear on which monitor at start. They usually both ended up in the same monitor on top of each other.
                  You may have more luck than I did. If you do figure it out, please let me know how you did it!
                    @NathTheDude said in Rpi 4 and two monitors:
                    the answer is yes, … depends on what you want to do…
                    to use two MM on the same full width display you will have to modify custom.css on the one to the right
                    and make its starting position 1/2 way across the screen
                    when MM is on the left, is the desktop a full image, or just the right side of the full image?
                    • N Offline
                      NathTheDude
                      Hey @sdetweil , I started with stopping MM (pm2 stop all). This then allowed me to use VNC to change the screen settings, as in just rotate the screen’s display.
                      The screens are showing as two seperate desktops and from VNC the mouse smoothly goes from one display to the other.
                      When MM is started this completly fills the first screen and a raspbian windows desktop is seen on the 2nd screen.
                        @NathTheDude try the raspian, preferences, appracne settings, desktop stretch across
                        • N Offline
                          NathTheDude
                          Thanks @sdetweil , I have just played with those settings again. These seem to only effect the desktop and the desktop background and not the MM site. Always appears on the first screen.
                            @NathTheDude but is the desktop all the way across as a single desktop, or two separate instances?
                            • N Offline
                              NathTheDude
                              @sdetweil , it is seen as two separate monitors. There is not a setting to scretch one screen to the other with the settings. The closest is ‘Strectch to cover screen’ but that does not seem to help.
                                bhepler Module Developer @sdetweil
                                @sdetweil - I don’t know if that capability is in the Raspi display drivers. It’s always going to see the two monitors as two separate devices with unique desktops. If you click on the Identify button, it should show you a different number on each monitor.
                                The only thing I can think of that would treat two monitors as a single continuous desktop is the AMD Eyefinity tech.
                                • N Offline
                                  NathTheDude
                                  Thanks @sdetweil and @bhepler , could you point me in the direction of how I would display a seperate instance of MM each monitor? I know this would mean I would need to update/maintain two different MM’s but maybe that is a better option if I want to add various modules?
                                    sdetweil @bhepler
                                    @bhepler said in Rpi 4 and two monitors:
                                    well, that is stupid sh… , in this day and age you should be able to config the thing like u want…
                                    I booted ubuntu on my desktop with has two displays and it made one big desktop by default…
                                    can’t understand why raspi should be so dumb
                                    • N Offline
                                      NathTheDude
                                      does this help
                                      pi@MagicMirrors:~ $ tvservice --list
                                      pi@MagicMirrors:~ $
                                        @NathTheDude MagicMirror startup in the run-start.sh file sets DISPLAY=:0 for the primary display
                                        I would guess that the second display is :1
                                        so, do
                                        export DISPLAY=:1
                                        then npm start
                                        see if it comes up on the second display
                                        • N Offline
                                          NathTheDude
                                          @sdetweil na, no joy. I did try this yesterday also but was not sure I was looking in the right place. For the sake of it I tried using numbers 0 to 9, all with the same result. This for example:
                                          npm ERR! code ENOENT
                                          npm ERR! syscall open
                                          npm ERR! errno -2
                                          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                          npm ERR! enoent This is related to npm not being able to find a file.
                                          npm ERR! enoent
                                          npm ERR!     /home/pi/.npm/_logs/2020-02-04T21_33_32_894Z-debug.log
                                          However if I reboot the RPI with run-start having the different value it will still display the MM on the first screen, this made me think that this script was not being used at the startup as I would expect it to fail and not display the MM - perhaps I am wrong.
                                            I wonder if we’re looking in the wrong place? Perhaps it’s how the MM process is calling Electron that determines where on the desktop the app appears.
