    Rpi 4 and two monitors
    60 Posts 6 Posters 34.2k Views 6 Watching
    • N Offline
      NathTheDude @sdetweil
      @sdetweil thanks.
      I found it had to get cheaper monitors that are both slim and gave small bezel. Not sure how will look with about 3-4cm of bezel in the middle.
        chassain 0
        i tried to use a rpi4 with 2 hdmi on the same tv and the result is ok. You just need to adjust resolution on screen menu hdmi 1 and hdmi 2.
        It’s a solution for my work to use only one raspberry with 2 screen televisions.
        • N Offline
          NathTheDude
          Hey @sdetweil and @chassain-0 , so my kit for my v2 project has arrived. I have two 21.5 inch (same model) monitors connected up to an RPI4.
          I have had a look around the forum but not been able to see what the best method is for this. When we start pm2 or when the RPI reboots it will boot up with the MM on the first screen and the normal desktop seen on the 2nd screen.
          I think I would prefer to have two MM’s installed (one for each monitor), I assume this is ok todo or is the best approach to have the one MM on both screens?
          Nathan
          bheplerB S 2 Replies Last reply Reply Quote 0
          • N Offline
            NathTheDude
            I wondered if I needed to update the ‘mm.sh’ file within the ‘installers’ folder, I tried changing this from ‘0’ to ‘1’ - reboot the RPI but on reboot MM does not get started on either monitor.
            pi@MagicMirrors:~/MagicMirror/installers $ tvservice --list
            2 attached device(s), display ID’s are :
            Display Number 2, type HDMI 0
            Display Number 7, type HDMI 1
            • bheplerB Offline
              bhepler Module Developer @NathTheDude
              @NathTheDude - I tried that one-pi-two-instances thing a couple years ago. I wasn’t using an RPI but rather a tiny Ubuntu box. My problem was that I couldn’t find a way to guarantee which instance would appear on which monitor at start. They usually both ended up in the same monitor on top of each other.
              You may have more luck than I did. If you do figure it out, please let me know how you did it!
                sdetweil @NathTheDude
                @NathTheDude said in Rpi 4 and two monitors:
                the answer is yes, … depends on what you want to do…
                to use two MM on the same full width display you will have to modify custom.css on the one to the right
                and make its starting position 1/2 way across the screen
                when MM is on the left, is the desktop a full image, or just the right side of the full image?
                • N Offline
                  NathTheDude
                  Hey @sdetweil , I started with stopping MM (pm2 stop all). This then allowed me to use VNC to change the screen settings, as in just rotate the screen’s display.
                  The screens are showing as two seperate desktops and from VNC the mouse smoothly goes from one display to the other.
                  When MM is started this completly fills the first screen and a raspbian windows desktop is seen on the 2nd screen.
                    @NathTheDude try the raspian, preferences, appracne settings, desktop stretch across
                    • N Offline
                      NathTheDude
                      Thanks @sdetweil , I have just played with those settings again. These seem to only effect the desktop and the desktop background and not the MM site. Always appears on the first screen.
                        @NathTheDude but is the desktop all the way across as a single desktop, or two separate instances?
                        • 1 / 6
