    602 Posts 67 Posters 2.3m Views 68 Watching
    • N Offline
      Number_5 @evroom
      @evroom
      thats the result with the port 554
      pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
      have a nice day ;)
      pi@raspberrypi:~/MagicMirror/config $ head -30 omxplayer.log
      21:33:25 T:18446744071806154291   DEBUG: DllBcm: Using omx system library
      21:33:25 T:18446744071806155602   DEBUG: DllOMX: Using omx system library
      21:33:25 T:18446744071806156277   DEBUG: DllAvFormat: Using libavformat system library
      21:33:25 T:18446744071806157458 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
      21:33:25 T:18446744071806157567 WARNING: DBus connection failed, trying alternate
      21:33:25 T:18446744071806158687   DEBUG: DBus connection succeeded
      21:33:25 T:18446744071806159455   DEBUG: Keyboard: DBus connection succeeded
      21:33:25 T:18446744071806159602   DEBUG: OMXThread::Create - Thread with id -1387290944 started
      21:33:25 T:18446744071806159705   DEBUG: DllAvUtilBase: Using libavutil system library
      21:33:25 T:18446744071806159738   DEBUG: DllAvCodec: Using libavcodec system library
      21:33:25 T:18446744071806159756   DEBUG: DllAvFormat: Using libavformat system library
      21:33:25 T:18446744071806160118   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
      21:33:25 T:18446744071806160518   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
      21:33:25 T:18446744071806179771   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
      21:33:25 T:18446744071806180025   DEBUG: OMXThread::StopThread - Thread stopped
      • N Offline
        Number_5
        Hello Sam,
        with 0.0.0.0.8080/MMM-rtspStream I was able to open the module configurator.
        evroom said:
        And see
        https://github.com/shbatm/MMM-RTSPStream
        “Using the module” on the config.html part I was referring to.
        The IP there, is the MM IP, or localhost, not your cam IP.
        It means the mirror id is not the raspberry pi?
        where can I find the mm id?
        evroomE S 3 Replies Last reply Reply Quote 0
        • evroomE Offline
          evroom @Number_5
          @Number_5
          When you run MM locally on your Pi, then your MM IP is your Pi IP.
          IP being the IP address, not an id.
          When you are able to open the RTSPStream configurator using 0.0.0.0.8080/MMM-rtspStream, then that’s fine.
          Continue with step 2 from this post:
          https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/379
          MagicMirror version: 2.37.0
            sdetweil @Number_5
            @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            I don’t see that (mirror id) in the doc for this module
            i do see this for testing the camera connection
            Testing a camera feed
            To test to make sure you have a working url for a camera feed: create a text file with the URL as the first and only line in the file. Save the file as .strm and open the file with a video player like VLC.
            unfortuantely I can’t use this module on my dev system as there is no omxplayer…
            • evroomE Offline
              evroom @Number_5
              @Number_5
              One more thing to try. Just leave out the port altogether.
              I use it without specifying the port.
              omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
              • N Offline
                Number_5 @sdetweil
                @sdetweil said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                create a text file
                Hallo Sam,
                1. i have created a textfile wit this line:
                rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=1&subtype=0
                2 )opend in vlc player direct on raspberry
                3) query answered user:admin passwort:roland!?1971
                4) saw the stream thats working fine
                rtsp://User:Passwort@IP:PORT/cam/realmonitor?channel=1&subtype=0
                here i inserted the user, passwort , Ip and port, channel from the camera.
                • N Offline
                  Number_5 @evroom
                  Hello evroom,
                  thats the result. Error after debug the file.
                  pi@raspberrypi:~/MagicMirror $ pm2 stop 1
                  [PM2] Applying action stopProcessId on app [1](ids: 1)
                  [PM2] omx_stream1 ✓
                  │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                  │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 0 │ 0 │ 0 │ stopped │ 0% │ 0b │ pi │ disabled │
                  │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 30 │ stopped │ 0% │ 0b │ pi │ disabled │
                  pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                  have a nice day ;)
                  pi@raspberrypi:~/MagicMirror $ more omxplayer.log
                  20:10:50 T:18446744072147623537   DEBUG: DllBcm: Using omx system library
                  20:10:50 T:18446744072147624751   DEBUG: DllOMX: Using omx system library
                  20:10:50 T:18446744072147625400   DEBUG: DllAvFormat: Using libavformat system library
                  20:10:50 T:18446744072147626711   DEBUG: DBus connection succeeded
                  20:10:50 T:18446744072147627442   DEBUG: Keyboard: DBus connection succeeded
                  20:10:50 T:18446744072147627591   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                  20:10:50 T:18446744072147627696   DEBUG: DllAvUtilBase: Using libavutil system library
                  20:10:50 T:18446744072147627719   DEBUG: DllAvCodec: Using libavcodec system library
                  20:10:50 T:18446744072147627738   DEBUG: DllAvFormat: Using libavformat system library
                  20:10:50 T:18446744072147628026   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                  20:10:50 T:18446744072147628457   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                  20:10:50 T:18446744072147647754   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                  20:10:50 T:18446744072147648005   DEBUG: OMXThread::StopThread - Thread stopped
                  • N Offline
                    Number_5 @evroom
                    @evroom
                    @evroom
                    Hello evroom
                    thats my config.js
                    var config = {
                            address: "0.0.0.0", // Address to listen on, can be:
                            port: 8080,
                            ipWhitelist: [], // Set [] to allow all IP addresses
                    //        module: 'MMM-RTSPStream',
                    //        position: 'middle_center',
                    //        config: {
                    //            initialSetup: true,
                        module: "MMM-RTSPStream",
                        position: "middle_center",
                            autoStart: true,
                            rotateStreams: true,
                            rotateStreamTimeout: 10,
                            moduleWidth: 354,
                            moduleHeight: 240,
                            localPlayer: 'ffmpeg',
                            remotePlayer: 'none',
                            showSnapWhenPaused: true,
                            remoteSnaps: true,
                            shutdownDelay: 12,
                                stream1: {
                                url: 'rtsp://admin:roland!?1971@192.168.2.140.2.108:554/cam/realmonitor?channel=2&subtype=0',
                                frameRate: 'undefined',
                                snapshotType: 'url',
                                snapshotRefresh: 10,
                                width: undefined,
                                height: undefined,
                                ffmpegPort: 9999,
                    1. pm2 flush
                    pi@raspberrypi:~ $ pm2 flush
                    [PM2] Flushing /home/pi/.pm2/pm2.log
                    [PM2] Flushing:
                    [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                    [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                    [PM2] Flushing:
                    [PM2] /dev/null
                    [PM2] /home/pi/.pm2/logs/omx-stream1-error.log
                    [PM2] Logs flushed
                    pi@raspberrypi:~ $
                    in this case i have took the ;
                    url: ‘rtsp://admin:roland!?1971@192.168.2.140.2.108:554/cam/realmonitor?channel=2&subtype=0’,
                    User, passwot from camera, id from raspberry, port as suggested, but with port 80 the real port its also not working.
                    rtsp://Benutzer:Passwort@IP:PORT/cam/realmonitor?channel=1&subtype=0
                    evroomE 2 Replies Last reply Reply Quote 0
                    • evroomE Offline
                      evroom @Number_5
                      1. query answered
                      Did vlc player come with this query for user and password?
                      The reason for supplying it in the URL is to not have to supply user and password.
                      So, perhaps omxplayer has the same issue, but it will not ask for user and password like vlc player does.
                      When vlc did not ask for the user and password, then we know the URL is correct, or at least can be parsed correct.
                      • N Offline
                        Number_5
                        yes, thats correct, querry follows after confirmation the url. then the stream follows
                        thanks for your help.
                        • evroomE Offline
                          evroom @Number_5
                          I suggested to NOT use a port, so to ditch the :80 or :554.
                          And when using the omxplayer command, you will need to supply the cam IP.
                          Does your spelling check change the word IP in id??
                          I know it can be confusing, but you will need to read things right in order for us (the community) to be able to help you. He says in a friendly tone and manner :-)
                            sdetweil @evroom
                            @evroom he did that
                            no port specified, has camera ip that worked with vlc.
                            • evroomE Offline
                              evroom @Number_5
                              Then we might have a parsing issue with your URL.
                              I think your password may cause a problem.
                              The ! an ? may cause a problem as they have meaning for your bash shell.
                              Have to think on that …
                              • evroomE Offline
                                evroom @sdetweil
                                he did that
                                Sorry, then I misread.
                                I read:
                                So now I am confused :-)
                                • evroomE Offline
                                  evroom @Number_5
                                  thats my config.js
                                  So it means you were able to get the RTSP config to open?
                                  And when you entered the URL for your cam, did it show you a video stream from your cam?
                                  I forgot if it does do that, or just builds the config part for config.js.
                                  • evroomE Offline
                                    evroom @sdetweil
                                    What bothers me, is the fact that vlc did not take the supplied user and password, but queried again for it.
                                    omxplayer will not do that; will just fail to open.
                                      sdetweil @evroom
                                      @evroom i was looking at the standalone omxplayer commandline we asked him to execute, not the
                                      config
                                      • N Offline
                                        Number_5 @evroom
                                        @evroom
                                        i have done 2 things.
                                        a) create the textfile and opened it in the vlc player on raspberry - then answered the querry (user and id)j, so i could saw the camerastream
                                        b) followed your steps:
                                        step 6
                                        Add the module to the config.js (replace the initial one):
                                        vi ~/MagicMirror/config/config.js
                                        after execute the commando "vi ~/MagicMirror/config/config.js " in commandline , the config.js openend
                                        • evroomE Offline
                                          evroom @Number_5
                                          @Number_5
                                          Could you please change your admin password of your cam to something without characters like ! and & ?
                                          When really needed, use + and/or _.
                                          Perhaps omxplayer has a parsing problem.
                                          Even tough we use single quotes to avoid this.
                                          I get the same error when using ?.
                                          Then try (with the changed password):
                                          omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland_1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                                          You can also try the vlc player ‘trick’.
                                          IMHO it should not ask for user & password.
                                          Also try to play with the port.
                                          Either nothing, or :80 or :554.
                                          Btw, 192.168.2.140.2.108 is not a valid IP address.
                                          It is either 192.168.2.108 or 192.168.2.140.
                                          I guess 192.168.2.140 is your MM / Rasperry Pi IP and 192.168.2.108 is your Dahua cam IP.
                                          Good luck.
                                          • N Offline
                                            Number_5
                                            ok, sorry,
                                            a) create the textfile and opened it in the vlc player on raspberry - then answered the querry **(user and password),not id !!!so i could saw the camerastream
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 30
                                            • 31
                                            • 22 / 31
