    602 Posts 67 Posters 2.4m Views 68 Watching
    • evroomE
      evroom @Number_5
      @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      thats my config.js
      So it means you were able to get the RTSP config to open?
      And when you entered the URL for your cam, did it show you a video stream from your cam?
      I forgot if it does do that, or just builds the config part for config.js.
      MagicMirror version: 2.37.0
      N 1 Reply Last reply
      • evroomE
        evroom @sdetweil
        @sdetweil said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        no port specified, has camera ip that worked with vlc.
        What bothers me, is the fact that vlc did not take the supplied user and password, but queried again for it.
        omxplayer will not do that; will just fail to open.
          sdetweil @evroom
          @evroom i was looking at the standalone omxplayer commandline we asked him to execute, not the
          config
          • N
            Number_5 @evroom
            @evroom
            i have done 2 things.
            a) create the textfile and opened it in the vlc player on raspberry - then answered the querry (user and id)j, so i could saw the camerastream
            b) followed your steps:
            step 6
            Add the module to the config.js (replace the initial one):
            vi ~/MagicMirror/config/config.js
            after execute the commando "vi ~/MagicMirror/config/config.js " in commandline , the config.js openend
            evroomE 1 Reply Last reply
            • evroomE
              evroom @Number_5
              @Number_5
              Could you please change your admin password of your cam to something without characters like ! and & ?
              When really needed, use + and/or _.
              Perhaps omxplayer has a parsing problem.
              Even tough we use single quotes to avoid this.
              I get the same error when using ?.
              Then try (with the changed password):
              omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland_1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
              You can also try the vlc player ‘trick’.
              IMHO it should not ask for user & password.
              Also try to play with the port.
              Either nothing, or :80 or :554.
              Btw, 192.168.2.140.2.108 is not a valid IP address.
              It is either 192.168.2.108 or 192.168.2.140.
              I guess 192.168.2.140 is your MM / Rasperry Pi IP and 192.168.2.108 is your Dahua cam IP.
              Good luck.
              • N
                Number_5
                ok, sorry,
                a) create the textfile and opened it in the vlc player on raspberry - then answered the querry **(user and password),not id !!!so i could saw the camerastream
                • evroomE
                  evroom @Number_5
                  Yes, sorry about that, vi is a text editor.
                  Close it with :q! or [ESC]:q! (where [ESC] is the escape key)
                  Then use the editor of your choice, like nano.
                  nano ~/MagicMirror/config/config.js
                  • evroomE
                    evroom @Number_5
                    ok, sorry,
                    I am sorry too :-)
                    Did you change the actual password of your cam or just changed the text in the admin:roland!?1971 part ?
                    I do not have a Dahua cam, so I do not know where and how to set it.
                    Probably there is a GUI (a web page) where you can do this.
                    I guess you can open it like this:
                    http://192.168.2.108
                    But once you did set it to the password we are seeing right now, so you ought to know :-)
                    • N
                      Number_5
                      would like to give you an interim report.
                      1. password has been changed, none
                      1. Stream with VlC programm possible, without query , :-)
                      2. no error in the log file, see below
                      3. i will try more on Friday or Saturday
                      pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
                      Vcodec id unknown: ad
                      have a nice day ;)
                      pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108/cam/realmonitor?channel=2&subtyp
                      e=0'
                      have a nice day ;)
                      have a nice day ;)
                      pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&su
                      btype=0'
                      have a nice day ;)
                      pi@raspberrypi:~/MagicMirror $ more omxplayer.log
                      18:31:12 T:1550613812   DEBUG: DllBcm: Using omx system library
                      18:31:12 T:1550615108   DEBUG: DllOMX: Using omx system library
                      18:31:12 T:1550615746   DEBUG: DllAvFormat: Using libavformat system library
                      18:31:12 T:1550617254   DEBUG: DBus connection succeeded
                      18:31:12 T:1550618196   DEBUG: Keyboard: DBus connection succeeded
                      18:31:12 T:1550618346   DEBUG: OMXThread::Create - Thread with id -1388339520 started
                      18:31:12 T:1550618446   DEBUG: DllAvUtilBase: Using libavutil system library
                      18:31:12 T:1550618468   DEBUG: DllAvCodec: Using libavcodec system library
                      18:31:12 T:1550618487   DEBUG: DllAvFormat: Using libavformat system library
                      18:31:12 T:1550618829   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                      18:31:12 T:1550714583   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                      18:31:13 T:1551680437   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x6d6140
                      18:31:13 T:1551681127   DEBUG: OMXClock::OMXStop
                      18:31:13 T:1551681450   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
                      18:31:13 T:1551681918   DEBUG: DllAvUtilBase: Using libavutil system library
                      18:31:13 T:1551681973   DEBUG: DllAvCodec: Using libavcodec system library
                      18:31:13 T:1551682018   DEBUG: DllAvFormat: Using libavformat system library
                      18:31:13 T:1551682225   DEBUG: OMXClock::OMXStop
                      18:31:13 T:1551684333   DEBUG: OMXThread::Run - Exited thread with  id -1388339520
                      18:31:13 T:1551684932   DEBUG: OMXThread::StopThread - Thread stopped
                      18:31:13 T:1551688082   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.clock handle 0x6d6140
                      Thanks for your help
                      • N
                        Number_5
                        thats the logfile without a port:
                        omxplayer --genlog --avdict rtsp_transport:tcp -pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                        have a nice day ;)
                        20:09:20 T:18446744072557925778   DEBUG: DllBcm: Using omx system library
                        20:09:20 T:18446744072557926899   DEBUG: DllOMX: Using omx system library
                        20:09:20 T:18446744072557927508   DEBUG: DllAvFormat: Using libavformat system library
                        20:09:20 T:18446744072557928896   DEBUG: DBus connection succeeded
                        20:09:20 T:18446744072557929631   DEBUG: Keyboard: DBus connection succeeded
                        20:09:20 T:18446744072557929778   DEBUG: OMXThread::Create - Thread with id -1388339520 started
                        20:09:20 T:18446744072557929873   DEBUG: DllAvUtilBase: Using libavutil system library
                        20:09:20 T:18446744072557929894   DEBUG: DllAvCodec: Using libavcodec system library
                        20:09:20 T:18446744072557929910   DEBUG: DllAvFormat: Using libavformat system library
                        20:09:20 T:18446744072557930230   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                        20:09:20 T:18446744072558104967   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                        20:09:21 T:18446744072559101936   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x79d170
                        20:09:21 T:18446744072559102429   DEBUG: OMXClock::OMXStop
                        20:09:21 T:18446744072559102650   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
                        20:09:21 T:18446744072559103080   DEBUG: DllAvUtilBase: Using libavutil system library
                        20:09:21 T:18446744072559103130   DEBUG: DllAvCodec: Using libavcodec system library
                        20:09:21 T:18446744072559103172   DEBUG: DllAvFormat: Using libavformat system library
                        20:09:21 T:18446744072559103634   DEBUG: OMXClock::OMXStop
                        20:09:21 T:18446744072559115423   DEBUG: OMXThread::Run - Exited thread with  id -1388339520
                        20:09:21 T:18446744072559115981   DEBUG: OMXThread::StopThread - Thread stopped
                        20:09:21 T:18446744072559118051   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.clock handle 0x79d170
                        • evroomE
                          evroom @Number_5
                          @Number_5
                          Can you try this, to try to see what codec is used?
                          omxplayer --info --genlog --avdict rtsp_transport:tcp --win,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                          • N
                            Number_5
                            pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                            /usr/bin/omxplayer.bin: unrecognized option '--win,424,1138,666'
                            20:09:20 T:18446744072557930230   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxxx@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                            • evroomE
                              evroom @Number_5
                              @Number_5
                              Copy/paste error on my side
                              omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                              Hope this works better.
                              • N
                                Number_5
                                Hello evroom,
                                thats the result.
                                pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                [rtsp @ 0x1e70770] method OPTIONS failed: 401 Unauthorized
                                have a nice day ;)
                                20:59:38 T:1866439265   DEBUG: DllBcm: Using omx system library
                                20:59:38 T:1866440312   DEBUG: DllOMX: Using omx system library
                                20:59:38 T:1866440900   DEBUG: DllAvFormat: Using libavformat system library
                                20:59:38 T:1866442436   DEBUG: DBus connection succeeded
                                20:59:38 T:1866443340   DEBUG: Keyboard: DBus connection succeeded
                                20:59:38 T:1866443488   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                20:59:38 T:1866443585   DEBUG: DllAvUtilBase: Using libavutil system library
                                20:59:38 T:1866443604   DEBUG: DllAvCodec: Using libavcodec system library
                                20:59:38 T:1866443620   DEBUG: DllAvFormat: Using libavformat system library
                                20:59:38 T:1866443952   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/re
                                20:59:38 T:1866474815   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/re
                                20:59:38 T:1866484802   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                20:59:38 T:1866485061   DEBUG: OMXThread::StopThread - Thread stopped
                                evroomE 2 Replies Last reply
                                • evroomE
                                  evroom @Number_5
                                  401 Unauthorized
                                  Did you supply your user and password iso xxx.xxx ?
                                  • N
                                    Number_5
                                    Yes, I changed it in xxx.xxx when I send the log to the the fourm
                                    • evroomE
                                      evroom @Number_5
                                      @Number_5
                                      One more thing.
                                      Can you also try with subtype=1 and subtype=2 ?
                                      Looks to be a decoding issue and subtype=0 might be too new for omxplayer.
                                      Someone claims this is working:
                                      channel=1&subtype=2
                                      • N
                                        Number_5
                                        here the result
                                        p```
                                        i@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1'
                                        [rtsp @ 0xaf9770] method OPTIONS failed: 401 Unauthorized
                                        have a nice day ;)
                                        21:22:31 T:18446744072654331549   DEBUG: DllBcm: Using omx system library
                                        21:22:31 T:18446744072654332606   DEBUG: DllOMX: Using omx system library
                                        21:22:31 T:18446744072654333203   DEBUG: DllAvFormat: Using libavformat system library
                                        21:22:31 T:18446744072654334714   DEBUG: DBus connection succeeded
                                        21:22:31 T:18446744072654335626   DEBUG: Keyboard: DBus connection succeeded
                                        21:22:31 T:18446744072654335771   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                        21:22:31 T:18446744072654335867   DEBUG: DllAvUtilBase: Using libavutil system library
                                        21:22:31 T:18446744072654335887   DEBUG: DllAvCodec: Using libavcodec system library
                                        21:22:31 T:18446744072654335903   DEBUG: DllAvFormat: Using libavformat system library
                                        21:22:31 T:18446744072654336238   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
                                        21:22:31 T:18446744072654372616   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
                                        21:22:31 T:18446744072654377098   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                        21:22:31 T:18446744072654377333   DEBUG: OMXThread::StopThread - Thread stopped
                                        pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2'
                                        [rtsp @ 0xd1d770] method OPTIONS failed: 401 Unauthorized
                                        have a nice day ;)
                                        21:23:48 T:18446744072731535779   DEBUG: DllBcm: Using omx system library
                                        21:23:48 T:18446744072731536888   DEBUG: DllOMX: Using omx system library
                                        21:23:48 T:18446744072731537505   DEBUG: DllAvFormat: Using libavformat system library
                                        21:23:48 T:18446744072731538801   DEBUG: DBus connection succeeded
                                        21:23:48 T:18446744072731539526   DEBUG: Keyboard: DBus connection succeeded
                                        21:23:48 T:18446744072731539667   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                        21:23:48 T:18446744072731539768   DEBUG: DllAvUtilBase: Using libavutil system library
                                        21:23:48 T:18446744072731539790   DEBUG: DllAvCodec: Using libavcodec system library
                                        21:23:48 T:18446744072731539805   DEBUG: DllAvFormat: Using libavformat system library
                                        21:23:48 T:18446744072731540190   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
                                        21:23:48 T:18446744072731573465   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
                                        21:23:48 T:18446744072731579918   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                        21:23:48 T:18446744072731580203   DEBUG: OMXThread::StopThread - Thread stopped
                                        • evroomE
                                          evroom @Number_5
                                          401 Unauthorized
                                          401 Unauthorized
                                          means user password combination is not correct.
                                          admin:roland
                                          Note the : and of course your correct password.
                                          • N
                                            Number_5
                                            sorry,
                                            with subtype=0 the second attempt
                                            pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                            Input #0, rtsp, from 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0':
                                            Metadata:
                                              title           : Media Server
                                            Duration: N/A, start: 0.080000, bitrate: N/A
                                              Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080, 25 fps, 25 tbr, 90k tbn, 90k tbc
                                            have a nice day ;)
                                            21:49:12 T:545640871   DEBUG: DllBcm: Using omx system library
                                            21:49:12 T:545641966   DEBUG: DllOMX: Using omx system library
                                            21:49:12 T:545642575   DEBUG: DllAvFormat: Using libavformat system library
                                            21:49:12 T:545643867   DEBUG: DBus connection succeeded
                                            21:49:12 T:545644603   DEBUG: Keyboard: DBus connection succeeded
                                            21:49:12 T:545644749   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                            21:49:12 T:545644849   DEBUG: DllAvUtilBase: Using libavutil system library
                                            21:49:12 T:545644870   DEBUG: DllAvCodec: Using libavcodec system library
                                            21:49:12 T:545644885   DEBUG: DllAvFormat: Using libavformat system library
                                            21:49:12 T:545645216   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                            21:49:12 T:545805065   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                                            21:49:13 T:546749810   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                            21:49:13 T:546750434   DEBUG: OMXThread::StopThread - Thread stopped
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 30
                                            • 31
                                            • 22 / 31
