    602 Posts 67 Posters 2.2m Views 68 Watching
    • N Offline
      Number_5
      ok, sorry,
      a) create the textfile and opened it in the vlc player on raspberry - then answered the querry **(user and password),not id !!!so i could saw the camerastream
      • evroomE Offline
        evroom @Number_5
        @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        after execute the commando "vi ~/MagicMirror/config/config.js " in commandline , the config.js openend
        Yes, sorry about that, vi is a text editor.
        Close it with :q! or [ESC]:q! (where [ESC] is the escape key)
        Then use the editor of your choice, like nano.
        nano ~/MagicMirror/config/config.js
        MagicMirror version: 2.37.0
        • evroomE Offline
          evroom @Number_5
          ok, sorry,
          I am sorry too :-)
          Did you change the actual password of your cam or just changed the text in the admin:roland!?1971 part ?
          I do not have a Dahua cam, so I do not know where and how to set it.
          Probably there is a GUI (a web page) where you can do this.
          I guess you can open it like this:
          http://192.168.2.108
          But once you did set it to the password we are seeing right now, so you ought to know :-)
          • N Offline
            Number_5
            would like to give you an interim report.
            1. password has been changed, none
            1. Stream with VlC programm possible, without query , :-)
            2. no error in the log file, see below
            3. i will try more on Friday or Saturday
            pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
            Vcodec id unknown: ad
            have a nice day ;)
            pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108/cam/realmonitor?channel=2&subtyp
            e=0'
            have a nice day ;)
            have a nice day ;)
            pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&su
            btype=0'
            have a nice day ;)
            pi@raspberrypi:~/MagicMirror $ more omxplayer.log
            18:31:12 T:1550613812   DEBUG: DllBcm: Using omx system library
            18:31:12 T:1550615108   DEBUG: DllOMX: Using omx system library
            18:31:12 T:1550615746   DEBUG: DllAvFormat: Using libavformat system library
            18:31:12 T:1550617254   DEBUG: DBus connection succeeded
            18:31:12 T:1550618196   DEBUG: Keyboard: DBus connection succeeded
            18:31:12 T:1550618346   DEBUG: OMXThread::Create - Thread with id -1388339520 started
            18:31:12 T:1550618446   DEBUG: DllAvUtilBase: Using libavutil system library
            18:31:12 T:1550618468   DEBUG: DllAvCodec: Using libavcodec system library
            18:31:12 T:1550618487   DEBUG: DllAvFormat: Using libavformat system library
            18:31:12 T:1550618829   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
            18:31:12 T:1550714583   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
            18:31:13 T:1551680437   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x6d6140
            18:31:13 T:1551681127   DEBUG: OMXClock::OMXStop
            18:31:13 T:1551681450   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
            18:31:13 T:1551681918   DEBUG: DllAvUtilBase: Using libavutil system library
            18:31:13 T:1551681973   DEBUG: DllAvCodec: Using libavcodec system library
            18:31:13 T:1551682018   DEBUG: DllAvFormat: Using libavformat system library
            18:31:13 T:1551682225   DEBUG: OMXClock::OMXStop
            18:31:13 T:1551684333   DEBUG: OMXThread::Run - Exited thread with  id -1388339520
            18:31:13 T:1551684932   DEBUG: OMXThread::StopThread - Thread stopped
            18:31:13 T:1551688082   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.clock handle 0x6d6140
            Thanks for your help
            • N Offline
              Number_5
              thats the logfile without a port:
              omxplayer --genlog --avdict rtsp_transport:tcp -pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
              have a nice day ;)
              20:09:20 T:18446744072557925778   DEBUG: DllBcm: Using omx system library
              20:09:20 T:18446744072557926899   DEBUG: DllOMX: Using omx system library
              20:09:20 T:18446744072557927508   DEBUG: DllAvFormat: Using libavformat system library
              20:09:20 T:18446744072557928896   DEBUG: DBus connection succeeded
              20:09:20 T:18446744072557929631   DEBUG: Keyboard: DBus connection succeeded
              20:09:20 T:18446744072557929778   DEBUG: OMXThread::Create - Thread with id -1388339520 started
              20:09:20 T:18446744072557929873   DEBUG: DllAvUtilBase: Using libavutil system library
              20:09:20 T:18446744072557929894   DEBUG: DllAvCodec: Using libavcodec system library
              20:09:20 T:18446744072557929910   DEBUG: DllAvFormat: Using libavformat system library
              20:09:20 T:18446744072557930230   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108/cam/realmonitor?channel=2&subtype=0
              20:09:20 T:18446744072558104967   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
              20:09:21 T:18446744072559101936   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x79d170
              20:09:21 T:18446744072559102429   DEBUG: OMXClock::OMXStop
              20:09:21 T:18446744072559102650   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
              20:09:21 T:18446744072559103080   DEBUG: DllAvUtilBase: Using libavutil system library
              20:09:21 T:18446744072559103130   DEBUG: DllAvCodec: Using libavcodec system library
              20:09:21 T:18446744072559103172   DEBUG: DllAvFormat: Using libavformat system library
              20:09:21 T:18446744072559103634   DEBUG: OMXClock::OMXStop
              20:09:21 T:18446744072559115423   DEBUG: OMXThread::Run - Exited thread with  id -1388339520
              20:09:21 T:18446744072559115981   DEBUG: OMXThread::StopThread - Thread stopped
              20:09:21 T:18446744072559118051   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.clock handle 0x79d170
              • evroomE Offline
                evroom @Number_5
                @Number_5
                Can you try this, to try to see what codec is used?
                omxplayer --info --genlog --avdict rtsp_transport:tcp --win,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                • N Offline
                  Number_5
                  pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                  /usr/bin/omxplayer.bin: unrecognized option '--win,424,1138,666'
                  20:09:20 T:18446744072557930230   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxxx@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                  • evroomE Offline
                    evroom @Number_5
                    @Number_5
                    Copy/paste error on my side
                    omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                    Hope this works better.
                    • N Offline
                      Number_5
                      Hello evroom,
                      thats the result.
                      pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                      [rtsp @ 0x1e70770] method OPTIONS failed: 401 Unauthorized
                      have a nice day ;)
                      20:59:38 T:1866439265   DEBUG: DllBcm: Using omx system library
                      20:59:38 T:1866440312   DEBUG: DllOMX: Using omx system library
                      20:59:38 T:1866440900   DEBUG: DllAvFormat: Using libavformat system library
                      20:59:38 T:1866442436   DEBUG: DBus connection succeeded
                      20:59:38 T:1866443340   DEBUG: Keyboard: DBus connection succeeded
                      20:59:38 T:1866443488   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                      20:59:38 T:1866443585   DEBUG: DllAvUtilBase: Using libavutil system library
                      20:59:38 T:1866443604   DEBUG: DllAvCodec: Using libavcodec system library
                      20:59:38 T:1866443620   DEBUG: DllAvFormat: Using libavformat system library
                      20:59:38 T:1866443952   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/re
                      20:59:38 T:1866474815   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/re
                      20:59:38 T:1866484802   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                      20:59:38 T:1866485061   DEBUG: OMXThread::StopThread - Thread stopped
                      evroomE 2 Replies Last reply Reply Quote 0
                      • evroomE Offline
                        evroom @Number_5
                        401 Unauthorized
                        Did you supply your user and password iso xxx.xxx ?
                        • N Offline
                          Number_5
                          Yes, I changed it in xxx.xxx when I send the log to the the fourm
                          • evroomE Offline
                            evroom @Number_5
                            @Number_5
                            One more thing.
                            Can you also try with subtype=1 and subtype=2 ?
                            Looks to be a decoding issue and subtype=0 might be too new for omxplayer.
                            Someone claims this is working:
                            channel=1&subtype=2
                            • N Offline
                              Number_5
                              here the result
                              p```
                              i@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1'
                              [rtsp @ 0xaf9770] method OPTIONS failed: 401 Unauthorized
                              have a nice day ;)
                              21:22:31 T:18446744072654331549   DEBUG: DllBcm: Using omx system library
                              21:22:31 T:18446744072654332606   DEBUG: DllOMX: Using omx system library
                              21:22:31 T:18446744072654333203   DEBUG: DllAvFormat: Using libavformat system library
                              21:22:31 T:18446744072654334714   DEBUG: DBus connection succeeded
                              21:22:31 T:18446744072654335626   DEBUG: Keyboard: DBus connection succeeded
                              21:22:31 T:18446744072654335771   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                              21:22:31 T:18446744072654335867   DEBUG: DllAvUtilBase: Using libavutil system library
                              21:22:31 T:18446744072654335887   DEBUG: DllAvCodec: Using libavcodec system library
                              21:22:31 T:18446744072654335903   DEBUG: DllAvFormat: Using libavformat system library
                              21:22:31 T:18446744072654336238   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
                              21:22:31 T:18446744072654372616   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
                              21:22:31 T:18446744072654377098   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                              21:22:31 T:18446744072654377333   DEBUG: OMXThread::StopThread - Thread stopped
                              pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2'
                              [rtsp @ 0xd1d770] method OPTIONS failed: 401 Unauthorized
                              have a nice day ;)
                              21:23:48 T:18446744072731535779   DEBUG: DllBcm: Using omx system library
                              21:23:48 T:18446744072731536888   DEBUG: DllOMX: Using omx system library
                              21:23:48 T:18446744072731537505   DEBUG: DllAvFormat: Using libavformat system library
                              21:23:48 T:18446744072731538801   DEBUG: DBus connection succeeded
                              21:23:48 T:18446744072731539526   DEBUG: Keyboard: DBus connection succeeded
                              21:23:48 T:18446744072731539667   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                              21:23:48 T:18446744072731539768   DEBUG: DllAvUtilBase: Using libavutil system library
                              21:23:48 T:18446744072731539790   DEBUG: DllAvCodec: Using libavcodec system library
                              21:23:48 T:18446744072731539805   DEBUG: DllAvFormat: Using libavformat system library
                              21:23:48 T:18446744072731540190   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
                              21:23:48 T:18446744072731573465   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
                              21:23:48 T:18446744072731579918   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                              21:23:48 T:18446744072731580203   DEBUG: OMXThread::StopThread - Thread stopped
                              • evroomE Offline
                                evroom @Number_5
                                401 Unauthorized
                                401 Unauthorized
                                means user password combination is not correct.
                                admin:roland
                                Note the : and of course your correct password.
                                • N Offline
                                  Number_5
                                  sorry,
                                  with subtype=0 the second attempt
                                  pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                  Input #0, rtsp, from 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0':
                                  Metadata:
                                    title           : Media Server
                                  Duration: N/A, start: 0.080000, bitrate: N/A
                                    Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080, 25 fps, 25 tbr, 90k tbn, 90k tbc
                                  have a nice day ;)
                                  21:49:12 T:545640871   DEBUG: DllBcm: Using omx system library
                                  21:49:12 T:545641966   DEBUG: DllOMX: Using omx system library
                                  21:49:12 T:545642575   DEBUG: DllAvFormat: Using libavformat system library
                                  21:49:12 T:545643867   DEBUG: DBus connection succeeded
                                  21:49:12 T:545644603   DEBUG: Keyboard: DBus connection succeeded
                                  21:49:12 T:545644749   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                  21:49:12 T:545644849   DEBUG: DllAvUtilBase: Using libavutil system library
                                  21:49:12 T:545644870   DEBUG: DllAvCodec: Using libavcodec system library
                                  21:49:12 T:545644885   DEBUG: DllAvFormat: Using libavformat system library
                                  21:49:12 T:545645216   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                  21:49:12 T:545805065   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                                  21:49:13 T:546749810   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                  21:49:13 T:546750434   DEBUG: OMXThread::StopThread - Thread stopped
                                  • evroomE Offline
                                    evroom @Number_5
                                    And with subtype=1 and subtype=2 ?
                                    And with channel=1&subtype=1 ?
                                    You can leave out the omxplayer.log for the moment.
                                    • N Offline
                                      Number_5
                                      subtyp 0
                                      pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
                                      Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0':
                                        Metadata:
                                        Duration: N/A, start: 0.040000, bitrate: N/A
                                          Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080, 100 tbr, 90k tbn, 90k tbc
                                      have a nice day ;)
                                      subtyp 1
                                      pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1'
                                      Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1':
                                        Metadata:
                                          Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 352x288, 100 tbr, 90k tbn, 90k tbc
                                      have a nice day ;)
                                      subtype 2
                                      pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2'
                                      have a nice day ;)
                                      pi@raspberrypi:~ $
                                      • N Offline
                                        Number_5
                                        subtype 2 , with error in the log.
                                        pi@raspberrypi:~ $ more omxplayer.log
                                        22:23:44 T:18446744072031941972   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
                                        22:24:14 T:18446744072062033195   ERROR: COMXPlayer::interrupt_cb - Timed out
                                        22:24:14 T:18446744072062033629   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
                                        22:24:14 T:18446744072062034345   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                        22:24:14 T:18446744072062034889   DEBUG: OMXThread::StopThread - Thread stopped
                                        • evroomE Offline
                                          evroom @Number_5
                                          @Number_5
                                          Video: hevc
                                          It looks like this is the problem.
                                          The omxplayer cannot handle this, as it seems.
                                          Do you have access to this Dahua Config Tool GUI stuff:
                                          (I hope the picture shows)
                                          Cannot upload a picture to the forum :disappointed_face: :face_with_steam_from_nose:
                                          http://www.dh-vision.com/index.php/dahuaencoding
                                          How many Channels do you have ?
                                          Is there a channel with Compression H.264 (something not H.265) ?
                                          Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?
                                          What Compresion options are there ?
                                          We are looking for a "channel=X&subtype=Y"combination that might work.
                                          • N Offline
                                            Number_5
                                            Hello evroom,
                                            here the results
                                            How many Channels do you have ? 4 (LUNA DVR Player)
                                            channel 1 luna camera is connected and with channel 2 there is the dahua camera , channel 3 and 4 are free,
                                            Is there a channel with Compression H.264 (something not H.265) ? yes, i have changed it now from H265 to H264
                                            Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?there is a extrastream i have set it from h265 to h264
                                            also there was a Zero-Channel at the option “display” disabled , i have it enabled now with h264
                                            What Compresion options are there ? h264, h264b , h264 , h264h , h265
                                            subtype=0 with h264
                                              Metadata:
                                              Duration: N/A, start: 0.270000, bitrate: N/A
                                                Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 1920x1080, 100 tbr, 90k tbn, 180k tbc
                                            have a nice day ;)
                                            subtype=1 with h264
                                              Metadata:
                                              Duration: N/A, start: 0.480000, bitrate: N/A
                                                Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 352x288, 100 tbr, 90k tbn, 180k tbc
                                            have a nice day ;)
                                            subtype=2 with h264, its not working log with error
                                            have a nice day ;)
                                            pi@raspberrypi:~ $su
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 30
                                            • 31
                                            • 23 / 31
