    602 Posts 67 Posters 2.2m Views 68 Watching
    • N Offline
      Number_5
      pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
      /usr/bin/omxplayer.bin: unrecognized option '--win,424,1138,666'
      pi@raspberrypi:~/MagicMirror $ more omxplayer.log
      20:09:20 T:18446744072557925778   DEBUG: DllBcm: Using omx system library
      20:09:20 T:18446744072557926899   DEBUG: DllOMX: Using omx system library
      20:09:20 T:18446744072557927508   DEBUG: DllAvFormat: Using libavformat system library
      20:09:20 T:18446744072557928896   DEBUG: DBus connection succeeded
      20:09:20 T:18446744072557929631   DEBUG: Keyboard: DBus connection succeeded
      20:09:20 T:18446744072557929778   DEBUG: OMXThread::Create - Thread with id -1388339520 started
      20:09:20 T:18446744072557929873   DEBUG: DllAvUtilBase: Using libavutil system library
      20:09:20 T:18446744072557929894   DEBUG: DllAvCodec: Using libavcodec system library
      20:09:20 T:18446744072557929910   DEBUG: DllAvFormat: Using libavformat system library
      20:09:20 T:18446744072557930230   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxxx@192.168.2.108/cam/realmonitor?channel=2&subtype=0
      20:09:20 T:18446744072558104967   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
      20:09:21 T:18446744072559101936   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x79d170
      20:09:21 T:18446744072559102429   DEBUG: OMXClock::OMXStop
      20:09:21 T:18446744072559102650   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
      20:09:21 T:18446744072559103080   DEBUG: DllAvUtilBase: Using libavutil system library
      20:09:21 T:18446744072559103130   DEBUG: DllAvCodec: Using libavcodec system library
      20:09:21 T:18446744072559103172   DEBUG: DllAvFormat: Using libavformat system library
      20:09:21 T:18446744072559103634   DEBUG: OMXClock::OMXStop
      20:09:21 T:18446744072559115423   DEBUG: OMXThread::Run - Exited thread with  id -1388339520
      20:09:21 T:18446744072559115981   DEBUG: OMXThread::StopThread - Thread stopped
      20:09:21 T:18446744072559118051   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.clock handle 0x79d170
      • evroomE Offline
        evroom @Number_5
        @Number_5
        Copy/paste error on my side
        omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
        Hope this works better.
        MagicMirror version: 2.37.0
        • N Offline
          Number_5
          Hello evroom,
          thats the result.
          pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
          [rtsp @ 0x1e70770] method OPTIONS failed: 401 Unauthorized
          have a nice day ;)
          20:59:38 T:1866439265   DEBUG: DllBcm: Using omx system library
          20:59:38 T:1866440312   DEBUG: DllOMX: Using omx system library
          20:59:38 T:1866440900   DEBUG: DllAvFormat: Using libavformat system library
          20:59:38 T:1866442436   DEBUG: DBus connection succeeded
          20:59:38 T:1866443340   DEBUG: Keyboard: DBus connection succeeded
          20:59:38 T:1866443488   DEBUG: OMXThread::Create - Thread with id -1387290944 started
          20:59:38 T:1866443585   DEBUG: DllAvUtilBase: Using libavutil system library
          20:59:38 T:1866443604   DEBUG: DllAvCodec: Using libavcodec system library
          20:59:38 T:1866443620   DEBUG: DllAvFormat: Using libavformat system library
          20:59:38 T:1866443952   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/re
          20:59:38 T:1866474815   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/re
          20:59:38 T:1866484802   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
          20:59:38 T:1866485061   DEBUG: OMXThread::StopThread - Thread stopped
          evroomE 2 Replies Last reply Reply Quote 0
          • evroomE Offline
            evroom @Number_5
            @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            401 Unauthorized
            Did you supply your user and password iso xxx.xxx ?
            • N Offline
              Number_5
              Yes, I changed it in xxx.xxx when I send the log to the the fourm
              • evroomE Offline
                evroom @Number_5
                @Number_5
                One more thing.
                Can you also try with subtype=1 and subtype=2 ?
                Looks to be a decoding issue and subtype=0 might be too new for omxplayer.
                Someone claims this is working:
                channel=1&subtype=2
                • N Offline
                  Number_5
                  here the result
                  p```
                  i@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1'
                  [rtsp @ 0xaf9770] method OPTIONS failed: 401 Unauthorized
                  have a nice day ;)
                  21:22:31 T:18446744072654331549   DEBUG: DllBcm: Using omx system library
                  21:22:31 T:18446744072654332606   DEBUG: DllOMX: Using omx system library
                  21:22:31 T:18446744072654333203   DEBUG: DllAvFormat: Using libavformat system library
                  21:22:31 T:18446744072654334714   DEBUG: DBus connection succeeded
                  21:22:31 T:18446744072654335626   DEBUG: Keyboard: DBus connection succeeded
                  21:22:31 T:18446744072654335771   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                  21:22:31 T:18446744072654335867   DEBUG: DllAvUtilBase: Using libavutil system library
                  21:22:31 T:18446744072654335887   DEBUG: DllAvCodec: Using libavcodec system library
                  21:22:31 T:18446744072654335903   DEBUG: DllAvFormat: Using libavformat system library
                  21:22:31 T:18446744072654336238   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
                  21:22:31 T:18446744072654372616   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
                  21:22:31 T:18446744072654377098   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                  21:22:31 T:18446744072654377333   DEBUG: OMXThread::StopThread - Thread stopped
                  pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2'
                  [rtsp @ 0xd1d770] method OPTIONS failed: 401 Unauthorized
                  have a nice day ;)
                  21:23:48 T:18446744072731535779   DEBUG: DllBcm: Using omx system library
                  21:23:48 T:18446744072731536888   DEBUG: DllOMX: Using omx system library
                  21:23:48 T:18446744072731537505   DEBUG: DllAvFormat: Using libavformat system library
                  21:23:48 T:18446744072731538801   DEBUG: DBus connection succeeded
                  21:23:48 T:18446744072731539526   DEBUG: Keyboard: DBus connection succeeded
                  21:23:48 T:18446744072731539667   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                  21:23:48 T:18446744072731539768   DEBUG: DllAvUtilBase: Using libavutil system library
                  21:23:48 T:18446744072731539790   DEBUG: DllAvCodec: Using libavcodec system library
                  21:23:48 T:18446744072731539805   DEBUG: DllAvFormat: Using libavformat system library
                  21:23:48 T:18446744072731540190   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
                  21:23:48 T:18446744072731573465   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
                  21:23:48 T:18446744072731579918   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                  21:23:48 T:18446744072731580203   DEBUG: OMXThread::StopThread - Thread stopped
                  • evroomE Offline
                    evroom @Number_5
                    401 Unauthorized
                    401 Unauthorized
                    means user password combination is not correct.
                    admin:roland
                    Note the : and of course your correct password.
                    • N Offline
                      Number_5
                      sorry,
                      with subtype=0 the second attempt
                      pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                      Input #0, rtsp, from 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0':
                      Metadata:
                        title           : Media Server
                      Duration: N/A, start: 0.080000, bitrate: N/A
                        Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080, 25 fps, 25 tbr, 90k tbn, 90k tbc
                      have a nice day ;)
                      21:49:12 T:545640871   DEBUG: DllBcm: Using omx system library
                      21:49:12 T:545641966   DEBUG: DllOMX: Using omx system library
                      21:49:12 T:545642575   DEBUG: DllAvFormat: Using libavformat system library
                      21:49:12 T:545643867   DEBUG: DBus connection succeeded
                      21:49:12 T:545644603   DEBUG: Keyboard: DBus connection succeeded
                      21:49:12 T:545644749   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                      21:49:12 T:545644849   DEBUG: DllAvUtilBase: Using libavutil system library
                      21:49:12 T:545644870   DEBUG: DllAvCodec: Using libavcodec system library
                      21:49:12 T:545644885   DEBUG: DllAvFormat: Using libavformat system library
                      21:49:12 T:545645216   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                      21:49:12 T:545805065   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                      21:49:13 T:546749810   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                      21:49:13 T:546750434   DEBUG: OMXThread::StopThread - Thread stopped
                      • evroomE Offline
                        evroom @Number_5
                        And with subtype=1 and subtype=2 ?
                        And with channel=1&subtype=1 ?
                        You can leave out the omxplayer.log for the moment.
                        • N Offline
                          Number_5
                          subtyp 0
                          pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
                          Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0':
                            Metadata:
                            Duration: N/A, start: 0.040000, bitrate: N/A
                              Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080, 100 tbr, 90k tbn, 90k tbc
                          have a nice day ;)
                          subtyp 1
                          pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1'
                          Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1':
                            Metadata:
                              Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 352x288, 100 tbr, 90k tbn, 90k tbc
                          have a nice day ;)
                          subtype 2
                          pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2'
                          have a nice day ;)
                          pi@raspberrypi:~ $
                          • N Offline
                            Number_5
                            subtype 2 , with error in the log.
                            pi@raspberrypi:~ $ more omxplayer.log
                            22:23:44 T:18446744072031941972   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
                            22:24:14 T:18446744072062033195   ERROR: COMXPlayer::interrupt_cb - Timed out
                            22:24:14 T:18446744072062033629   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
                            22:24:14 T:18446744072062034345   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                            22:24:14 T:18446744072062034889   DEBUG: OMXThread::StopThread - Thread stopped
                            • evroomE Offline
                              evroom @Number_5
                              @Number_5
                              Video: hevc
                              It looks like this is the problem.
                              The omxplayer cannot handle this, as it seems.
                              Do you have access to this Dahua Config Tool GUI stuff:
                              (I hope the picture shows)
                              Cannot upload a picture to the forum :disappointed_face: :face_with_steam_from_nose:
                              http://www.dh-vision.com/index.php/dahuaencoding
                              How many Channels do you have ?
                              Is there a channel with Compression H.264 (something not H.265) ?
                              Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?
                              What Compresion options are there ?
                              We are looking for a "channel=X&subtype=Y"combination that might work.
                              • N Offline
                                Number_5
                                Hello evroom,
                                here the results
                                How many Channels do you have ? 4 (LUNA DVR Player)
                                channel 1 luna camera is connected and with channel 2 there is the dahua camera , channel 3 and 4 are free,
                                Is there a channel with Compression H.264 (something not H.265) ? yes, i have changed it now from H265 to H264
                                Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?there is a extrastream i have set it from h265 to h264
                                also there was a Zero-Channel at the option “display” disabled , i have it enabled now with h264
                                What Compresion options are there ? h264, h264b , h264 , h264h , h265
                                subtype=0 with h264
                                  Metadata:
                                  Duration: N/A, start: 0.270000, bitrate: N/A
                                    Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 1920x1080, 100 tbr, 90k tbn, 180k tbc
                                have a nice day ;)
                                subtype=1 with h264
                                  Metadata:
                                  Duration: N/A, start: 0.480000, bitrate: N/A
                                    Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 352x288, 100 tbr, 90k tbn, 180k tbc
                                have a nice day ;)
                                subtype=2 with h264, its not working log with error
                                have a nice day ;)
                                pi@raspberrypi:~ $su
                                • evroomE Offline
                                  evroom @Number_5
                                  subtype=1 with h264
                                  Can you try the subtype=1 option and remove the --info part from the command?
                                  • N Offline
                                    Number_5
                                    @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                    omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0’
                                    Hello evroom,
                                    you are the best. now its working!
                                    thanks all for your support. and thanks all for your patience in the past nights.
                                    pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
                                    Video codec omx-h264 width 1920 height 1080 profile 77 fps 30.000000
                                    Subtitle count: 0, state: off, index: 1, delay: 0
                                    V:PortSettingsChanged: 1920x1080@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                    I have put tbe url in the config.js
                                      module: "MMM-RTSPStream",
                                       position: "middle_center",
                                       header: "Test Kamera",
                                           autoStart: true,
                                           rotateStreams: true,
                                           rotateStreamTimeout: 10,
                                           moduleWidth: 354,
                                           moduleHeight: 240,
                                           localPlayer: 'omxplayer',
                                           remotePlayer: 'none',
                                           showSnapWhenPaused: true,
                                           remoteSnaps: true,
                                           stream1: {
                                               url: 'rtsp://XXX:XXX@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0',
                                               frameRate: 'undefined',
                                               snapshotType: 'url',
                                               snapshotRefresh: 10,
                                              width: undefined,
                                               height: undefined,
                                    with
                                    pm2 stop MagicMirror
                                    the mirror stops, but not the stream from the camerea.
                                    Only with the command
                                    pm2 stop 1
                                    the stream stops.
                                    S evroomE 2 Replies Last reply Reply Quote 0
                                      sdetweil @Number_5
                                      @Number_5 you need to write a little script to do pm2 stop 1, then pm2 stop 0
                                      • evroomE Offline
                                        evroom @Number_5
                                        now its working!
                                        Great to hear!
                                        When you add
                                        omxRestart: 1,
                                        in the
                                        part, then when restarting MagicMirror, the omx_stream1 will be stopped and restarted too.
                                        If you really want to stop MagicMirror and omx_stream1, then you will need to stop both:
                                        pm2 stop omx_stream1
                                        Provided that you named you stream1 stream1.
                                        • N Offline
                                          Number_5 @sdetweil
                                          hello sam,
                                          Thank you. You opened the door for me a few days ago. writing small and large scripts will be my next challenge :-). for the first one ,i took up the suggestion from evroom. I hope you will help me with the next projects, :-)
                                          • E Offline
                                            Egnos
                                            Hello to all,
                                            I congratulate the developer of this module which, if I manage to make it work, will be very useful to me! :smiling_face_with_open_mouth_smiling_eyes:
                                            I describe my environment:
                                            I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                                            For now all modules work perfectly except MMM-RTSPStream.
                                            Description of the problem:
                                            I followed the installation guide at this link.
                                            When dependencies are installed the installation fails
                                            Cloning the repository on master branch...
                                            Cloning into 'MMM-RTSPStream'...
                                            remote: Enumerating objects: 16, done.
                                            remote: Counting objects: 100% (16/16), done.
                                            remote: Compressing objects: 100% (14/14), done.
                                            remote: Total 315 (delta 5), reused 6 (delta 2), pack-reused 299
                                            Ricezione degli oggetti: 100% (315/315), 1.13 MiB | 876.00 KiB/s, done.
                                            Risoluzione dei delta: 100% (192/192), done.
                                            Installing dependencies...
                                            > MMM-RTSPStream@2.0.2-dev preinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
                                            > ./scripts/preinstall.sh
                                            Updating packages ...
                                            Trovato:1 http://security.debian.org stretch/updates InRelease
                                            Trovato:2 http://archive.raspberrypi.org/debian stretch InRelease
                                            Ign:3 http://ftp.debian.org/debian stretch InRelease
                                            Trovato:4 http://ftp.debian.org/debian stretch-updates InRelease
                                            Trovato:5 https://deb.nodesource.com/node_10.x stretch InRelease
                                            Trovato:6 http://ftp.debian.org/debian stretch Release
                                            Lettura elenco dei pacchetti... Fatto
                                            Generazione albero delle dipendenze
                                            Lettura informazioni sullo stato... Fatto
                                            152 pacchetti possono essere aggiornati: eseguire "apt list --upgradable" per vederli.
                                            Installing helper tools: devilspie2 and wmctrl...
                                            E: Impossibile trovare il pacchetto omxplayer
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno 100
                                            npm ERR! MMM-RTSPStream@2.0.2-dev preinstall: `./scripts/preinstall.sh`
                                            npm ERR! Exit status 100
                                            npm ERR!
                                            npm ERR! Failed at the MMM-RTSPStream@2.0.2-dev preinstall script.
                                            npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                                            npm ERR!     /home/pi/.npm/_logs/2020-02-20T11_38_51_172Z-debug.log
                                            Failed to install dependencies.
                                            Can you help me?
                                            Thank you all
                                            evroomE BKeyportB 2 Replies Last reply Reply Quote 0
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 30
                                            • 31
                                            • 23 / 31
