    602 Posts 67 Posters 2.4m Views 68 Watching
    • N
      Number_5
      subtype 2 , with error in the log.
      pi@raspberrypi:~ $ more omxplayer.log
      22:23:44 T:18446744072031941972   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
      22:24:14 T:18446744072062033195   ERROR: COMXPlayer::interrupt_cb - Timed out
      22:24:14 T:18446744072062033629   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
      22:24:14 T:18446744072062034345   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
      22:24:14 T:18446744072062034889   DEBUG: OMXThread::StopThread - Thread stopped
      evroomE 1 Reply Last reply
      • evroomE
        evroom @Number_5
        @Number_5
        @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        Video: hevc
        It looks like this is the problem.
        The omxplayer cannot handle this, as it seems.
        Do you have access to this Dahua Config Tool GUI stuff:
        (I hope the picture shows)
        Cannot upload a picture to the forum :disappointed_face: :face_with_steam_from_nose:
        http://www.dh-vision.com/index.php/dahuaencoding
        How many Channels do you have ?
        Is there a channel with Compression H.264 (something not H.265) ?
        Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?
        What Compresion options are there ?
        We are looking for a "channel=X&subtype=Y"combination that might work.
        MagicMirror version: 2.37.0
        • N
          Number_5
          Hello evroom,
          here the results
          How many Channels do you have ? 4 (LUNA DVR Player)
          channel 1 luna camera is connected and with channel 2 there is the dahua camera , channel 3 and 4 are free,
          Is there a channel with Compression H.264 (something not H.265) ? yes, i have changed it now from H265 to H264
          Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?there is a extrastream i have set it from h265 to h264
          also there was a Zero-Channel at the option “display” disabled , i have it enabled now with h264
          What Compresion options are there ? h264, h264b , h264 , h264h , h265
          subtype=0 with h264
          pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
          Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0':
            Metadata:
              title           : Media Server
            Duration: N/A, start: 0.270000, bitrate: N/A
              Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 1920x1080, 100 tbr, 90k tbn, 180k tbc
          have a nice day ;)
          subtype=1 with h264
          pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1'
          Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1':
            Metadata:
            Duration: N/A, start: 0.480000, bitrate: N/A
              Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 352x288, 100 tbr, 90k tbn, 180k tbc
          have a nice day ;)
          subtype=2 with h264, its not working log with error
          pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2'
          have a nice day ;)
          pi@raspberrypi:~ $su
          • evroomE
            evroom @Number_5
            subtype=1 with h264
            Can you try the subtype=1 option and remove the --info part from the command?
            • N
              Number_5
              @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0’
              Hello evroom,
              you are the best. now its working!
              thanks all for your support. and thanks all for your patience in the past nights.
              pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
              Video codec omx-h264 width 1920 height 1080 profile 77 fps 30.000000
              Subtitle count: 0, state: off, index: 1, delay: 0
              V:PortSettingsChanged: 1920x1080@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
              I have put tbe url in the config.js
                module: "MMM-RTSPStream",
                 position: "middle_center",
                 header: "Test Kamera",
                     autoStart: true,
                     rotateStreams: true,
                     rotateStreamTimeout: 10,
                     moduleWidth: 354,
                     moduleHeight: 240,
                     localPlayer: 'omxplayer',
                     remotePlayer: 'none',
                     showSnapWhenPaused: true,
                     remoteSnaps: true,
                     stream1: {
                         url: 'rtsp://XXX:XXX@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0',
                         frameRate: 'undefined',
                         snapshotType: 'url',
                         snapshotRefresh: 10,
                        width: undefined,
                         height: undefined,
              with
              pm2 stop MagicMirror
              the mirror stops, but not the stream from the camerea.
              Only with the command
              pm2 stop 1
              the stream stops.
              S evroomE 2 Replies Last reply
                sdetweil @Number_5
                @Number_5 you need to write a little script to do pm2 stop 1, then pm2 stop 0
                N 1 Reply Last reply
                • evroomE
                  evroom @Number_5
                  now its working!
                  Great to hear!
                  When you add
                  omxRestart: 1,
                  in the
                  part, then when restarting MagicMirror, the omx_stream1 will be stopped and restarted too.
                  If you really want to stop MagicMirror and omx_stream1, then you will need to stop both:
                  pm2 stop omx_stream1
                  Provided that you named you stream1 stream1.
                  • N
                    Number_5 @sdetweil
                    hello sam,
                    Thank you. You opened the door for me a few days ago. writing small and large scripts will be my next challenge :-). for the first one ,i took up the suggestion from evroom. I hope you will help me with the next projects, :-)
                    • E
                      Egnos
                      Hello to all,
                      I congratulate the developer of this module which, if I manage to make it work, will be very useful to me! :smiling_face_with_open_mouth_smiling_eyes:
                      I describe my environment:
                      I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                      For now all modules work perfectly except MMM-RTSPStream.
                      Description of the problem:
                      I followed the installation guide at this link.
                      When dependencies are installed the installation fails
                      Cloning the repository on master branch...
                      Cloning into 'MMM-RTSPStream'...
                      remote: Enumerating objects: 16, done.
                      remote: Counting objects: 100% (16/16), done.
                      remote: Compressing objects: 100% (14/14), done.
                      remote: Total 315 (delta 5), reused 6 (delta 2), pack-reused 299
                      Ricezione degli oggetti: 100% (315/315), 1.13 MiB | 876.00 KiB/s, done.
                      Risoluzione dei delta: 100% (192/192), done.
                      Installing dependencies...
                      > MMM-RTSPStream@2.0.2-dev preinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
                      > ./scripts/preinstall.sh
                      Updating packages ...
                      Trovato:1 http://security.debian.org stretch/updates InRelease
                      Trovato:2 http://archive.raspberrypi.org/debian stretch InRelease
                      Ign:3 http://ftp.debian.org/debian stretch InRelease
                      Trovato:4 http://ftp.debian.org/debian stretch-updates InRelease
                      Trovato:5 https://deb.nodesource.com/node_10.x stretch InRelease
                      Trovato:6 http://ftp.debian.org/debian stretch Release
                      Lettura elenco dei pacchetti... Fatto
                      Generazione albero delle dipendenze
                      Lettura informazioni sullo stato... Fatto
                      152 pacchetti possono essere aggiornati: eseguire "apt list --upgradable" per vederli.
                      Installing helper tools: devilspie2 and wmctrl...
                      E: Impossibile trovare il pacchetto omxplayer
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 100
                      npm ERR! MMM-RTSPStream@2.0.2-dev preinstall: `./scripts/preinstall.sh`
                      npm ERR! Exit status 100
                      npm ERR!
                      npm ERR! Failed at the MMM-RTSPStream@2.0.2-dev preinstall script.
                      npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                      npm ERR!     /home/pi/.npm/_logs/2020-02-20T11_38_51_172Z-debug.log
                      Failed to install dependencies.
                      Can you help me?
                      Thank you all
                      evroomE BKeyportB 2 Replies Last reply
                      • evroomE
                        evroom @Egnos
                        @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        To me it looks like it cannot install omxplayer.
                        You can try to install it manually.
                        The script does it using this command:
                        sudo apt install -y omxplayer
                        Perhaps another command is needed, or indeed the package to install omxplayer does not exist for your platform.
                        • BKeyportB
                          BKeyport Module Developer @Egnos
                          evroom’s got it right. OMXplayer isn’t being installed. I understand it went under a few management changes, so it could be trying to access an old version or something. RTSPStream’s clunky enough that you might find it easier (and better) to run OMXplayer independently of the mirror, like evroom has done, as have I.
                          see earlier in this thread: https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/259
                          steps really to take RTSP-Stream out and run OMX directly:
                          1. Find the resolution of your screen so you know your range. (1920x1080 in my case)
                          2. Figure out the resolution of the stream. (640x360 in my case)
                          3. figure out where on the screen you want it using the top left corner, this would become your X1 and Y1 (I wanted it in the upper right corner, so, that was rather easy)
                          4. Add width of your stream to X1 for X2, height of your stream to Y1 for Y2.
                          5. omx player will likely need the following commands: “–avdict rtsp_transport:tcp --live --fps 30” as well as the following
                          6. The “–win” command string is “X1 Y1 X2 Y2”
                          7. If you have your screen rotated, and omxplayer doesn’t play along (it likely wont), add “–orientation” and how many degrees to twist (90 = portrait “right”, 180 = landscape “upside down”, 270 Portrait “Left”) command line, and adjust X and Y calculations for 90 or 270 rotation. The X and Y will remain as if the screen isn’t rotated.
                          I used the first one of these, but the other 3 is as rotated for the same corner.
                          omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 0 --win “1280 0 1920 360” [url]
                          omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 90 --win “1560 0 1920 640” [url]
                          omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 180 --win “1280 0 1920 360” [url]
                          omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 270 --win “1560 0 1920 640” [url]
                          • E
                            Egnos @BKeyport
                            Thanks a loro @BKeyport and @evroom!
                            In a few days I will try your advice.
                            @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                            does this mean i have to uninstall the module RTSPStream’s and install only the component OMXplayer?
                            • evroomE
                              evroom
                              If you are able to install OMXPlayer, then you can give MMM-RTSPStream a try.
                              In principle it does work, depending on what you want to stream.
                              If it works for you, perfect, if it doesn’t, then try if omxplayer works standalone,
                              Actually testing omxplayer standalone is always a good thing before trying out MMM-RTSPStream.
                              • BKeyportB
                                You don’t have to uninstall a module - just take it out of your config. In my case, once I got OMX working, and followed evroom’s instructions to start, I found that using OMX directly rather than through the module is rather cleaner. I can run the hi-def stream for one thing.
                                  DirkS
                                  Hi, i have used the Module for a long time now jsut with snapshots. I never streamed live.
                                  A year ago i switched the native magic mirror to docker install to use it for more devices at the same time. RTSPStream just worked fine after that change. But in last december i updated it and since that moment it stopped working. I had other issues to do so i did not investigate the cause.
                                  But now i want to get it back working.
                                  The error i can see via web logging is this:
                                  Uncaught DOMException: Failed to construct 'WebSocket': The URL 'ws://192.168.10.1:undefined' is invalid.
                                      at WSSource.start (http://192.168.10.1:82/modules/MMM-RTSPStream/scripts/jsmpeg.min.js:1:16242)
                                      at new Player (http://192.168.10.1:82/modules/MMM-RTSPStream/scripts/jsmpeg.min.js:1:5838)
                                      at Class.playStream (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:399:26)
                                      at Class.rotateStream (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:123:23)
                                      at Class.setupStreamRotation (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:94:14)
                                      at Class.resumed (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:168:22)
                                      at http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:697:43
                                  I’ve tried now different ways and also checked if it is streaming. I have installed ffmpeg within the docker container and also the node-rtsp-stream-es6 module. Also i have installed node-rtsp-stream-es6 at one rpi client and just to be sure ffmpeg. But in the past it worked without it.
                                  Here is my config (now with ffmpeg streaming):
                                      position: "bottom_right",
                                      header: "Rundumblick",
                                          autoStart: false,
                                          moduleWidth: 354,
                                          moduleHeight: 240,
                                          localPlayer: 'ffmpeg',
                                          remoteSnaps: true,
                                  	debug: true,
                                          stream1: {
                                              url: 'rtsp://192.168.10.1:7447/5af753a0b1d674c3bbc08189_1',
                                              hdUrl: 'rtsp://192.168.10.1:7447/5af753a0b1d674c3bbc08189_0',
                                              snapshotUrl: 'http://192.168.10.55/snap.jpeg',
                                              width: undefined,
                                              height: undefined,
                                          stream2: {
                                              url: 'rtsp://192.168.10.1:7447/5af75418b1d674c3bbc0818a_1',
                                              hdUrl: 'rtsp://192.168.10.1:7447/5af75418b1d674c3bbc0818a_0',
                                              snapshotUrl: 'http://192.168.10.56/snap.jpeg',
                                              width: undefined,
                                              height: undefined,
                                          stream3: {
                                              url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa9_1',
                                              hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa9_0',
                                              snapshotUrl: 'http://192.168.10.50/snap.jpeg',
                                              width: undefined,
                                              height: undefined,
                                          stream4: {
                                              url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa6_1',
                                              hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa6_0',
                                              snapshotUrl: 'http://192.168.10.54/snap.jpeg',
                                              width: undefined,
                                              height: undefined,
                                  	stream5: {
                                  	    url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa8_1',
                                              hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa8_0',
                                              snapshotUrl: 'http://192.168.10.53/snap.jpeg',
                                              widht: undefined,
                                              height: undefined,
                                  	stream6: {
                                  	   url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa7_2',
                                  	   hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa7_0',
                                             snapshotUrl: 'http://192.168.10.51/snap.jpeg',
                                  	   widht: undefined,
                                  	   height: undefined,
                                  	stream7: {
                                             snapshotUrl: 'http://192.168.10.52/snap.jpeg',
                                             widht: undefined,
                                             height: undefined,
                                  can anybody assume where to search the cause? I’m out of ideas :(
                                  If i just want to have snapshots i get this:
                                  MMM-RTSPStream.js:712 Uncaught TypeError: Cannot read property 'appendChild' of null
                                      at Class.socketNotificationReceived (MMM-RTSPStream.js:712)
                                      at module.js:246
                                      at r.<anonymous> (socketclient.js:25)
                                      at r.emit (index.js:83)
                                      at r.onevent (index.js:83)
                                      at r.MMSocket.self.socket.onevent (socketclient.js:19)
                                      at r.onpacket (index.js:83)
                                      at r.<anonymous> (index.js:83)
                                      at r.ondecoded (index.js:83)
                                  • E
                                    Egnos
                                    @BKeyport and @evroom I tried to install omxplayer but i always get the same error:
                                    Can you help me?
                                    Many thanks!
                                    • BKeyportB
                                      It looks as though you’re on a Pi, correct? If I recall right OMX should be installed with the OS in more than the “lite” install…If it’s not there, it’s not available in your language, maybe. I’m not too versed in how those installs work.
                                      • evroomE
                                        evroom @Egnos
                                        Can you help me?
                                        What platform are you on.
                                        Raspberry Pi with Debian?
                                        lsb_release -a
                                        sudo apt-get install omxplayer
                                        • E
                                          Egnos
                                          @BKeyport and @evroom this is my environment:
                                          • PC Hp Intel I5.
                                          • Raspbian on Virtual Box (using Debian…).
                                          First I try to make everything work on the virtual machine and then I transfer everything to PI.
                                          Many thanks.
                                          • BKeyportB
                                            @egnos you might never get OMX working in a virtual environment. It works directly with the hardware to show the picture.
                                            I would highly recommend setting it up on the pi now, and setting up SSH to communicate.
                                            I also have SAMBA (https://www.juanmtech.com/samba-file-sharing-raspberry-pi/) running on my pi, so I can use Geany for Windows (https://www.geany.org/) to directly edit the raspberry files.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 30
                                            • 31
                                            • 23 / 31
