    602 Posts 67 Posters 2.4m Views 68 Watching
    • evroomE
      evroom @Number_5
      @Number_5
      One more thing.
      Can you also try with subtype=1 and subtype=2 ?
      Looks to be a decoding issue and subtype=0 might be too new for omxplayer.
      Someone claims this is working:
      channel=1&subtype=2
      MagicMirror version: 2.37.0
      • N
        Number_5
        here the result
        p```
        i@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1'
        [rtsp @ 0xaf9770] method OPTIONS failed: 401 Unauthorized
        have a nice day ;)
        pi@raspberrypi:~/MagicMirror $ more omxplayer.log
        21:22:31 T:18446744072654331549   DEBUG: DllBcm: Using omx system library
        21:22:31 T:18446744072654332606   DEBUG: DllOMX: Using omx system library
        21:22:31 T:18446744072654333203   DEBUG: DllAvFormat: Using libavformat system library
        21:22:31 T:18446744072654334714   DEBUG: DBus connection succeeded
        21:22:31 T:18446744072654335626   DEBUG: Keyboard: DBus connection succeeded
        21:22:31 T:18446744072654335771   DEBUG: OMXThread::Create - Thread with id -1387290944 started
        21:22:31 T:18446744072654335867   DEBUG: DllAvUtilBase: Using libavutil system library
        21:22:31 T:18446744072654335887   DEBUG: DllAvCodec: Using libavcodec system library
        21:22:31 T:18446744072654335903   DEBUG: DllAvFormat: Using libavformat system library
        21:22:31 T:18446744072654336238   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
        21:22:31 T:18446744072654372616   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=1
        21:22:31 T:18446744072654377098   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
        21:22:31 T:18446744072654377333   DEBUG: OMXThread::StopThread - Thread stopped
        pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2'
        [rtsp @ 0xd1d770] method OPTIONS failed: 401 Unauthorized
        have a nice day ;)
        21:23:48 T:18446744072731535779   DEBUG: DllBcm: Using omx system library
        21:23:48 T:18446744072731536888   DEBUG: DllOMX: Using omx system library
        21:23:48 T:18446744072731537505   DEBUG: DllAvFormat: Using libavformat system library
        21:23:48 T:18446744072731538801   DEBUG: DBus connection succeeded
        21:23:48 T:18446744072731539526   DEBUG: Keyboard: DBus connection succeeded
        21:23:48 T:18446744072731539667   DEBUG: OMXThread::Create - Thread with id -1387290944 started
        21:23:48 T:18446744072731539768   DEBUG: DllAvUtilBase: Using libavutil system library
        21:23:48 T:18446744072731539790   DEBUG: DllAvCodec: Using libavcodec system library
        21:23:48 T:18446744072731539805   DEBUG: DllAvFormat: Using libavformat system library
        21:23:48 T:18446744072731540190   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
        21:23:48 T:18446744072731573465   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=2
        21:23:48 T:18446744072731579918   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
        21:23:48 T:18446744072731580203   DEBUG: OMXThread::StopThread - Thread stopped
        evroomE 1 Reply Last reply
        • evroomE
          evroom @Number_5
          @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          401 Unauthorized
          401 Unauthorized
          means user password combination is not correct.
          admin:roland
          Note the : and of course your correct password.
          • N
            Number_5
            sorry,
            with subtype=0 the second attempt
            pi@raspberrypi:~/MagicMirror $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
            Input #0, rtsp, from 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0':
            Metadata:
              title           : Media Server
            Duration: N/A, start: 0.080000, bitrate: N/A
              Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080, 25 fps, 25 tbr, 90k tbn, 90k tbc
            have a nice day ;)
            21:49:12 T:545640871   DEBUG: DllBcm: Using omx system library
            21:49:12 T:545641966   DEBUG: DllOMX: Using omx system library
            21:49:12 T:545642575   DEBUG: DllAvFormat: Using libavformat system library
            21:49:12 T:545643867   DEBUG: DBus connection succeeded
            21:49:12 T:545644603   DEBUG: Keyboard: DBus connection succeeded
            21:49:12 T:545644749   DEBUG: OMXThread::Create - Thread with id -1387290944 started
            21:49:12 T:545644849   DEBUG: DllAvUtilBase: Using libavutil system library
            21:49:12 T:545644870   DEBUG: DllAvCodec: Using libavcodec system library
            21:49:12 T:545644885   DEBUG: DllAvFormat: Using libavformat system library
            21:49:12 T:545645216   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
            21:49:12 T:545805065   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
            21:49:13 T:546749810   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
            21:49:13 T:546750434   DEBUG: OMXThread::StopThread - Thread stopped
            • evroomE
              evroom @Number_5
              And with subtype=1 and subtype=2 ?
              And with channel=1&subtype=1 ?
              You can leave out the omxplayer.log for the moment.
              • N
                Number_5
                subtyp 0
                pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
                Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0':
                  Metadata:
                  Duration: N/A, start: 0.040000, bitrate: N/A
                    Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 1920x1080, 100 tbr, 90k tbn, 90k tbc
                have a nice day ;)
                subtyp 1
                pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1'
                Input #0, rtsp, from 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=1':
                  Metadata:
                    Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 352x288, 100 tbr, 90k tbn, 90k tbc
                have a nice day ;)
                subtype 2
                pi@raspberrypi:~ $ omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2'
                have a nice day ;)
                pi@raspberrypi:~ $
                • N
                  Number_5
                  subtype 2 , with error in the log.
                  pi@raspberrypi:~ $ more omxplayer.log
                  22:23:44 T:18446744072031941972   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
                  22:24:14 T:18446744072062033195   ERROR: COMXPlayer::interrupt_cb - Timed out
                  22:24:14 T:18446744072062033629   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://xxx:xxx@192.168.2.108:554/cam/realmonitor?channel=1&subtype=2
                  22:24:14 T:18446744072062034345   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                  22:24:14 T:18446744072062034889   DEBUG: OMXThread::StopThread - Thread stopped
                  • evroomE
                    evroom @Number_5
                    @Number_5
                    Video: hevc
                    It looks like this is the problem.
                    The omxplayer cannot handle this, as it seems.
                    Do you have access to this Dahua Config Tool GUI stuff:
                    (I hope the picture shows)
                    Cannot upload a picture to the forum :disappointed_face: :face_with_steam_from_nose:
                    http://www.dh-vision.com/index.php/dahuaencoding
                    How many Channels do you have ?
                    Is there a channel with Compression H.264 (something not H.265) ?
                    Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?
                    What Compresion options are there ?
                    We are looking for a "channel=X&subtype=Y"combination that might work.
                    • N
                      Number_5
                      Hello evroom,
                      here the results
                      How many Channels do you have ? 4 (LUNA DVR Player)
                      channel 1 luna camera is connected and with channel 2 there is the dahua camera , channel 3 and 4 are free,
                      Is there a channel with Compression H.264 (something not H.265) ? yes, i have changed it now from H265 to H264
                      Is there a Sub Stream that is enabled with Compression H.264 (something not H.265) ?there is a extrastream i have set it from h265 to h264
                      also there was a Zero-Channel at the option “display” disabled , i have it enabled now with h264
                      What Compresion options are there ? h264, h264b , h264 , h264h , h265
                      subtype=0 with h264
                        Metadata:
                        Duration: N/A, start: 0.270000, bitrate: N/A
                          Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 1920x1080, 100 tbr, 90k tbn, 180k tbc
                      have a nice day ;)
                      subtype=1 with h264
                        Metadata:
                        Duration: N/A, start: 0.480000, bitrate: N/A
                          Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 352x288, 100 tbr, 90k tbn, 180k tbc
                      have a nice day ;)
                      subtype=2 with h264, its not working log with error
                      have a nice day ;)
                      pi@raspberrypi:~ $su
                      • evroomE
                        evroom @Number_5
                        subtype=1 with h264
                        Can you try the subtype=1 option and remove the --info part from the command?
                        • N
                          Number_5
                          @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                          omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0’
                          Hello evroom,
                          you are the best. now its working!
                          thanks all for your support. and thanks all for your patience in the past nights.
                          pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
                          Video codec omx-h264 width 1920 height 1080 profile 77 fps 30.000000
                          Subtitle count: 0, state: off, index: 1, delay: 0
                          V:PortSettingsChanged: 1920x1080@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                          I have put tbe url in the config.js
                            module: "MMM-RTSPStream",
                             position: "middle_center",
                             header: "Test Kamera",
                                 autoStart: true,
                                 rotateStreams: true,
                                 rotateStreamTimeout: 10,
                                 moduleWidth: 354,
                                 moduleHeight: 240,
                                 localPlayer: 'omxplayer',
                                 remotePlayer: 'none',
                                 showSnapWhenPaused: true,
                                 remoteSnaps: true,
                                 stream1: {
                                     url: 'rtsp://XXX:XXX@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0',
                                     frameRate: 'undefined',
                                     snapshotType: 'url',
                                     snapshotRefresh: 10,
                                    width: undefined,
                                     height: undefined,
                          with
                          pm2 stop MagicMirror
                          the mirror stops, but not the stream from the camerea.
                          Only with the command
                          pm2 stop 1
                          the stream stops.
                          S evroomE 2 Replies Last reply
                            sdetweil @Number_5
                            @Number_5 you need to write a little script to do pm2 stop 1, then pm2 stop 0
                            N 1 Reply Last reply
                            • evroomE
                              evroom @Number_5
                              now its working!
                              Great to hear!
                              When you add
                              omxRestart: 1,
                              in the
                              part, then when restarting MagicMirror, the omx_stream1 will be stopped and restarted too.
                              If you really want to stop MagicMirror and omx_stream1, then you will need to stop both:
                              pm2 stop omx_stream1
                              Provided that you named you stream1 stream1.
                              • N
                                Number_5 @sdetweil
                                hello sam,
                                Thank you. You opened the door for me a few days ago. writing small and large scripts will be my next challenge :-). for the first one ,i took up the suggestion from evroom. I hope you will help me with the next projects, :-)
                                • E
                                  Egnos
                                  Hello to all,
                                  I congratulate the developer of this module which, if I manage to make it work, will be very useful to me! :smiling_face_with_open_mouth_smiling_eyes:
                                  I describe my environment:
                                  I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                                  For now all modules work perfectly except MMM-RTSPStream.
                                  Description of the problem:
                                  I followed the installation guide at this link.
                                  When dependencies are installed the installation fails
                                  Cloning the repository on master branch...
                                  Cloning into 'MMM-RTSPStream'...
                                  remote: Enumerating objects: 16, done.
                                  remote: Counting objects: 100% (16/16), done.
                                  remote: Compressing objects: 100% (14/14), done.
                                  remote: Total 315 (delta 5), reused 6 (delta 2), pack-reused 299
                                  Ricezione degli oggetti: 100% (315/315), 1.13 MiB | 876.00 KiB/s, done.
                                  Risoluzione dei delta: 100% (192/192), done.
                                  Installing dependencies...
                                  > MMM-RTSPStream@2.0.2-dev preinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
                                  > ./scripts/preinstall.sh
                                  Updating packages ...
                                  Trovato:1 http://security.debian.org stretch/updates InRelease
                                  Trovato:2 http://archive.raspberrypi.org/debian stretch InRelease
                                  Ign:3 http://ftp.debian.org/debian stretch InRelease
                                  Trovato:4 http://ftp.debian.org/debian stretch-updates InRelease
                                  Trovato:5 https://deb.nodesource.com/node_10.x stretch InRelease
                                  Trovato:6 http://ftp.debian.org/debian stretch Release
                                  Lettura elenco dei pacchetti... Fatto
                                  Generazione albero delle dipendenze
                                  Lettura informazioni sullo stato... Fatto
                                  152 pacchetti possono essere aggiornati: eseguire "apt list --upgradable" per vederli.
                                  Installing helper tools: devilspie2 and wmctrl...
                                  E: Impossibile trovare il pacchetto omxplayer
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 100
                                  npm ERR! MMM-RTSPStream@2.0.2-dev preinstall: `./scripts/preinstall.sh`
                                  npm ERR! Exit status 100
                                  npm ERR!
                                  npm ERR! Failed at the MMM-RTSPStream@2.0.2-dev preinstall script.
                                  npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                                  npm ERR!     /home/pi/.npm/_logs/2020-02-20T11_38_51_172Z-debug.log
                                  Failed to install dependencies.
                                  Can you help me?
                                  Thank you all
                                  evroomE BKeyportB 2 Replies Last reply
                                  • evroomE
                                    evroom @Egnos
                                    @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                    To me it looks like it cannot install omxplayer.
                                    You can try to install it manually.
                                    The script does it using this command:
                                    sudo apt install -y omxplayer
                                    Perhaps another command is needed, or indeed the package to install omxplayer does not exist for your platform.
                                    • BKeyportB
                                      BKeyport Module Developer @Egnos
                                      evroom’s got it right. OMXplayer isn’t being installed. I understand it went under a few management changes, so it could be trying to access an old version or something. RTSPStream’s clunky enough that you might find it easier (and better) to run OMXplayer independently of the mirror, like evroom has done, as have I.
                                      see earlier in this thread: https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/259
                                      steps really to take RTSP-Stream out and run OMX directly:
                                      1. Find the resolution of your screen so you know your range. (1920x1080 in my case)
                                      2. Figure out the resolution of the stream. (640x360 in my case)
                                      3. figure out where on the screen you want it using the top left corner, this would become your X1 and Y1 (I wanted it in the upper right corner, so, that was rather easy)
                                      4. Add width of your stream to X1 for X2, height of your stream to Y1 for Y2.
                                      5. omx player will likely need the following commands: “–avdict rtsp_transport:tcp --live --fps 30” as well as the following
                                      6. The “–win” command string is “X1 Y1 X2 Y2”
                                      7. If you have your screen rotated, and omxplayer doesn’t play along (it likely wont), add “–orientation” and how many degrees to twist (90 = portrait “right”, 180 = landscape “upside down”, 270 Portrait “Left”) command line, and adjust X and Y calculations for 90 or 270 rotation. The X and Y will remain as if the screen isn’t rotated.
                                      I used the first one of these, but the other 3 is as rotated for the same corner.
                                      omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 0 --win “1280 0 1920 360” [url]
                                      omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 90 --win “1560 0 1920 640” [url]
                                      omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 180 --win “1280 0 1920 360” [url]
                                      omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 270 --win “1560 0 1920 640” [url]
                                      • E
                                        Egnos @BKeyport
                                        Thanks a loro @BKeyport and @evroom!
                                        In a few days I will try your advice.
                                        @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                        does this mean i have to uninstall the module RTSPStream’s and install only the component OMXplayer?
                                        • evroomE
                                          evroom
                                          If you are able to install OMXPlayer, then you can give MMM-RTSPStream a try.
                                          In principle it does work, depending on what you want to stream.
                                          If it works for you, perfect, if it doesn’t, then try if omxplayer works standalone,
                                          Actually testing omxplayer standalone is always a good thing before trying out MMM-RTSPStream.
                                          • BKeyportB
                                            You don’t have to uninstall a module - just take it out of your config. In my case, once I got OMX working, and followed evroom’s instructions to start, I found that using OMX directly rather than through the module is rather cleaner. I can run the hi-def stream for one thing.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 30
                                            • 31
                                            • 23 / 31
