    602 Posts 67 Posters 2.2m Views 68 Watching
    • evroomE Offline
      evroom @Number_5
      @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      subtype=1 with h264
      Can you try the subtype=1 option and remove the --info part from the command?
      MagicMirror version: 2.35.0
      Test environment:
      MagicMirror version: 2.36.0-develop
      • N Offline
        Number_5
        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        omxplayer --info --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://xxx.xxx@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0’
        Hello evroom,
        you are the best. now its working!
        thanks all for your support. and thanks all for your patience in the past nights.
        pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:RoKu1234@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0'
        Video codec omx-h264 width 1920 height 1080 profile 77 fps 30.000000
        Subtitle count: 0, state: off, index: 1, delay: 0
        V:PortSettingsChanged: 1920x1080@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
        I have put tbe url in the config.js
          module: "MMM-RTSPStream",
           position: "middle_center",
           header: "Test Kamera",
               autoStart: true,
               rotateStreams: true,
               rotateStreamTimeout: 10,
               moduleWidth: 354,
               moduleHeight: 240,
               localPlayer: 'omxplayer',
               remotePlayer: 'none',
               showSnapWhenPaused: true,
               remoteSnaps: true,
               stream1: {
                   url: 'rtsp://XXX:XXX@192.168.2.108:554/cam/realmonitor?channel=1&subtype=0',
                   frameRate: 'undefined',
                   snapshotType: 'url',
                   snapshotRefresh: 10,
                  width: undefined,
                   height: undefined,
        with
        pm2 stop MagicMirror
        the mirror stops, but not the stream from the camerea.
        Only with the command
        pm2 stop 1
        the stream stops.
        S evroomE 2 Replies Last reply Reply Quote 0
          sdetweil @Number_5
          @Number_5 you need to write a little script to do pm2 stop 1, then pm2 stop 0
          • evroomE Offline
            evroom @Number_5
            now its working!
            Great to hear!
            When you add
            omxRestart: 1,
            in the
            part, then when restarting MagicMirror, the omx_stream1 will be stopped and restarted too.
            If you really want to stop MagicMirror and omx_stream1, then you will need to stop both:
            pm2 stop omx_stream1
            Provided that you named you stream1 stream1.
            Test environment:
            • N Offline
              Number_5 @sdetweil
              hello sam,
              Thank you. You opened the door for me a few days ago. writing small and large scripts will be my next challenge :-). for the first one ,i took up the suggestion from evroom. I hope you will help me with the next projects, :-)
              • E Offline
                Egnos
                Hello to all,
                I congratulate the developer of this module which, if I manage to make it work, will be very useful to me! :smiling_face_with_open_mouth_smiling_eyes:
                I describe my environment:
                I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                For now all modules work perfectly except MMM-RTSPStream.
                Description of the problem:
                I followed the installation guide at this link.
                When dependencies are installed the installation fails
                Cloning the repository on master branch...
                Cloning into 'MMM-RTSPStream'...
                remote: Enumerating objects: 16, done.
                remote: Counting objects: 100% (16/16), done.
                remote: Compressing objects: 100% (14/14), done.
                remote: Total 315 (delta 5), reused 6 (delta 2), pack-reused 299
                Ricezione degli oggetti: 100% (315/315), 1.13 MiB | 876.00 KiB/s, done.
                Risoluzione dei delta: 100% (192/192), done.
                Installing dependencies...
                > MMM-RTSPStream@2.0.2-dev preinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
                > ./scripts/preinstall.sh
                Updating packages ...
                Trovato:1 http://security.debian.org stretch/updates InRelease
                Trovato:2 http://archive.raspberrypi.org/debian stretch InRelease
                Ign:3 http://ftp.debian.org/debian stretch InRelease
                Trovato:4 http://ftp.debian.org/debian stretch-updates InRelease
                Trovato:5 https://deb.nodesource.com/node_10.x stretch InRelease
                Trovato:6 http://ftp.debian.org/debian stretch Release
                Lettura elenco dei pacchetti... Fatto
                Generazione albero delle dipendenze
                Lettura informazioni sullo stato... Fatto
                152 pacchetti possono essere aggiornati: eseguire "apt list --upgradable" per vederli.
                Installing helper tools: devilspie2 and wmctrl...
                E: Impossibile trovare il pacchetto omxplayer
                npm ERR! code ELIFECYCLE
                npm ERR! errno 100
                npm ERR! MMM-RTSPStream@2.0.2-dev preinstall: `./scripts/preinstall.sh`
                npm ERR! Exit status 100
                npm ERR!
                npm ERR! Failed at the MMM-RTSPStream@2.0.2-dev preinstall script.
                npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                npm ERR!     /home/pi/.npm/_logs/2020-02-20T11_38_51_172Z-debug.log
                Failed to install dependencies.
                Can you help me?
                Thank you all
                evroomE BKeyportB 2 Replies Last reply Reply Quote 0
                • evroomE Offline
                  evroom @Egnos
                  @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  To me it looks like it cannot install omxplayer.
                  You can try to install it manually.
                  The script does it using this command:
                  sudo apt install -y omxplayer
                  Perhaps another command is needed, or indeed the package to install omxplayer does not exist for your platform.
                  Test environment:
                  • BKeyportB Offline
                    BKeyport Module Developer @Egnos
                    evroom’s got it right. OMXplayer isn’t being installed. I understand it went under a few management changes, so it could be trying to access an old version or something. RTSPStream’s clunky enough that you might find it easier (and better) to run OMXplayer independently of the mirror, like evroom has done, as have I.
                    see earlier in this thread: https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/259
                    steps really to take RTSP-Stream out and run OMX directly:
                    1. Find the resolution of your screen so you know your range. (1920x1080 in my case)
                    2. Figure out the resolution of the stream. (640x360 in my case)
                    3. figure out where on the screen you want it using the top left corner, this would become your X1 and Y1 (I wanted it in the upper right corner, so, that was rather easy)
                    4. Add width of your stream to X1 for X2, height of your stream to Y1 for Y2.
                    5. omx player will likely need the following commands: “–avdict rtsp_transport:tcp --live --fps 30” as well as the following
                    6. The “–win” command string is “X1 Y1 X2 Y2”
                    7. If you have your screen rotated, and omxplayer doesn’t play along (it likely wont), add “–orientation” and how many degrees to twist (90 = portrait “right”, 180 = landscape “upside down”, 270 Portrait “Left”) command line, and adjust X and Y calculations for 90 or 270 rotation. The X and Y will remain as if the screen isn’t rotated.
                    I used the first one of these, but the other 3 is as rotated for the same corner.
                    omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 0 --win “1280 0 1920 360” [url]
                    omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 90 --win “1560 0 1920 640” [url]
                    omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 180 --win “1280 0 1920 360” [url]
                    omxplayer --avdict rtsp_transport:tcp --live --fps 30 --orientation 270 --win “1560 0 1920 640” [url]
                    • E Offline
                      Egnos @BKeyport
                      Thanks a loro @BKeyport and @evroom!
                      In a few days I will try your advice.
                      @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      does this mean i have to uninstall the module RTSPStream’s and install only the component OMXplayer?
                      • evroomE Offline
                        evroom
                        If you are able to install OMXPlayer, then you can give MMM-RTSPStream a try.
                        In principle it does work, depending on what you want to stream.
                        If it works for you, perfect, if it doesn’t, then try if omxplayer works standalone,
                        Actually testing omxplayer standalone is always a good thing before trying out MMM-RTSPStream.
                        Test environment:
                        • BKeyportB Offline
                          You don’t have to uninstall a module - just take it out of your config. In my case, once I got OMX working, and followed evroom’s instructions to start, I found that using OMX directly rather than through the module is rather cleaner. I can run the hi-def stream for one thing.
                            DirkS
                            Hi, i have used the Module for a long time now jsut with snapshots. I never streamed live.
                            A year ago i switched the native magic mirror to docker install to use it for more devices at the same time. RTSPStream just worked fine after that change. But in last december i updated it and since that moment it stopped working. I had other issues to do so i did not investigate the cause.
                            But now i want to get it back working.
                            The error i can see via web logging is this:
                            Uncaught DOMException: Failed to construct 'WebSocket': The URL 'ws://192.168.10.1:undefined' is invalid.
                                at WSSource.start (http://192.168.10.1:82/modules/MMM-RTSPStream/scripts/jsmpeg.min.js:1:16242)
                                at new Player (http://192.168.10.1:82/modules/MMM-RTSPStream/scripts/jsmpeg.min.js:1:5838)
                                at Class.playStream (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:399:26)
                                at Class.rotateStream (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:123:23)
                                at Class.setupStreamRotation (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:94:14)
                                at Class.resumed (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:168:22)
                                at http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:697:43
                            I’ve tried now different ways and also checked if it is streaming. I have installed ffmpeg within the docker container and also the node-rtsp-stream-es6 module. Also i have installed node-rtsp-stream-es6 at one rpi client and just to be sure ffmpeg. But in the past it worked without it.
                            Here is my config (now with ffmpeg streaming):
                                position: "bottom_right",
                                header: "Rundumblick",
                                    autoStart: false,
                                    moduleWidth: 354,
                                    moduleHeight: 240,
                                    localPlayer: 'ffmpeg',
                                    remoteSnaps: true,
                            	debug: true,
                                    stream1: {
                                        url: 'rtsp://192.168.10.1:7447/5af753a0b1d674c3bbc08189_1',
                                        hdUrl: 'rtsp://192.168.10.1:7447/5af753a0b1d674c3bbc08189_0',
                                        snapshotUrl: 'http://192.168.10.55/snap.jpeg',
                                        width: undefined,
                                        height: undefined,
                                    stream2: {
                                        url: 'rtsp://192.168.10.1:7447/5af75418b1d674c3bbc0818a_1',
                                        hdUrl: 'rtsp://192.168.10.1:7447/5af75418b1d674c3bbc0818a_0',
                                        snapshotUrl: 'http://192.168.10.56/snap.jpeg',
                                        width: undefined,
                                        height: undefined,
                                    stream3: {
                                        url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa9_1',
                                        hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa9_0',
                                        snapshotUrl: 'http://192.168.10.50/snap.jpeg',
                                        width: undefined,
                                        height: undefined,
                                    stream4: {
                                        url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa6_1',
                                        hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa6_0',
                                        snapshotUrl: 'http://192.168.10.54/snap.jpeg',
                                        width: undefined,
                                        height: undefined,
                            	stream5: {
                            	    url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa8_1',
                                        hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa8_0',
                                        snapshotUrl: 'http://192.168.10.53/snap.jpeg',
                                        widht: undefined,
                                        height: undefined,
                            	stream6: {
                            	   url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa7_2',
                            	   hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa7_0',
                                       snapshotUrl: 'http://192.168.10.51/snap.jpeg',
                            	   widht: undefined,
                            	   height: undefined,
                            	stream7: {
                                       snapshotUrl: 'http://192.168.10.52/snap.jpeg',
                                       widht: undefined,
                                       height: undefined,
                            can anybody assume where to search the cause? I’m out of ideas :(
                            If i just want to have snapshots i get this:
                            MMM-RTSPStream.js:712 Uncaught TypeError: Cannot read property 'appendChild' of null
                                at Class.socketNotificationReceived (MMM-RTSPStream.js:712)
                                at module.js:246
                                at r.<anonymous> (socketclient.js:25)
                                at r.emit (index.js:83)
                                at r.onevent (index.js:83)
                                at r.MMSocket.self.socket.onevent (socketclient.js:19)
                                at r.onpacket (index.js:83)
                                at r.<anonymous> (index.js:83)
                                at r.ondecoded (index.js:83)
                            • E Offline
                              Egnos
                              @BKeyport and @evroom I tried to install omxplayer but i always get the same error:
                              Can you help me?
                              Many thanks!
                              • BKeyportB Offline
                                It looks as though you’re on a Pi, correct? If I recall right OMX should be installed with the OS in more than the “lite” install…If it’s not there, it’s not available in your language, maybe. I’m not too versed in how those installs work.
                                • evroomE Offline
                                  evroom @Egnos
                                  Can you help me?
                                  What platform are you on.
                                  Raspberry Pi with Debian?
                                  lsb_release -a
                                  sudo apt-get install omxplayer
                                  Test environment:
                                  • E Offline
                                    Egnos
                                    @BKeyport and @evroom this is my environment:
                                    • PC Hp Intel I5.
                                    • Raspbian on Virtual Box (using Debian…).
                                    First I try to make everything work on the virtual machine and then I transfer everything to PI.
                                    Many thanks.
                                    • BKeyportB Offline
                                      @egnos you might never get OMX working in a virtual environment. It works directly with the hardware to show the picture.
                                      I would highly recommend setting it up on the pi now, and setting up SSH to communicate.
                                      I also have SAMBA (https://www.juanmtech.com/samba-file-sharing-raspberry-pi/) running on my pi, so I can use Geany for Windows (https://www.geany.org/) to directly edit the raspberry files.
                                      • H Offline
                                        Hram2008
                                        Has anyone been able to get this working with Axis camera products? VLC will pull and display the video stream outside of MM but will not display the same stream on MM when configured.
                                        Any thoughts???
                                        • evroomE Offline
                                          evroom @Hram2008
                                          @Hram2008 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          Yes, I have.
                                          Please show your MMM-RTSPStream part from config.js.
                                          Test environment:
                                          • BKeyportB Offline
                                            BKeyport Module Developer @Hram2008
                                            @Hram2008 have you tried running the URL straight with OMX to see if it works, if it does, you may have issues with the plugin itself, and as the author seems to have disappeared, you could just replace the plugin with OMX cutting the proper hole out of the window (It’ll go in front of whatever is running, so you run it independently, and it just works.
                                            omxplayer --no-osd --no-keys --avdict rtsp_transport:tcp --live --fps 30 --orientation 0 --win "640 0 1280 360" [URL]
                                            -or-
                                            omxplayer --no-osd --no-keys --avdict rtsp_transport:udp --live --fps 30 --orientation 0 --win "640 0 1280 360" [URL]
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 30
                                            • 31
                                            • 24 / 31
