    602 Posts 67 Posters 2.4m Views 68 Watching
    • E
      Egnos
      @BKeyport and @evroom this is my environment:
      • PC Hp Intel I5.
      • Raspbian on Virtual Box (using Debian…).
      First I try to make everything work on the virtual machine and then I transfer everything to PI.
      Many thanks.
      • BKeyportB
        BKeyport Module Developer
        @egnos you might never get OMX working in a virtual environment. It works directly with the hardware to show the picture.
        I would highly recommend setting it up on the pi now, and setting up SSH to communicate.
        I also have SAMBA (https://www.juanmtech.com/samba-file-sharing-raspberry-pi/) running on my pi, so I can use Geany for Windows (https://www.geany.org/) to directly edit the raspberry files.
        • H
          Hram2008
          Has anyone been able to get this working with Axis camera products? VLC will pull and display the video stream outside of MM but will not display the same stream on MM when configured.
          Any thoughts???
          evroomE BKeyportB 2 Replies Last reply
          • evroomE
            evroom @Hram2008
            @Hram2008 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            Yes, I have.
            Please show your MMM-RTSPStream part from config.js.
            MagicMirror version: 2.37.0
            H 1 Reply Last reply
            • BKeyportB
              BKeyport Module Developer @Hram2008
              @Hram2008 have you tried running the URL straight with OMX to see if it works, if it does, you may have issues with the plugin itself, and as the author seems to have disappeared, you could just replace the plugin with OMX cutting the proper hole out of the window (It’ll go in front of whatever is running, so you run it independently, and it just works.
              omxplayer --no-osd --no-keys --avdict rtsp_transport:tcp --live --fps 30 --orientation 0 --win "640 0 1280 360" [URL]
              -or-
              omxplayer --no-osd --no-keys --avdict rtsp_transport:udp --live --fps 30 --orientation 0 --win "640 0 1280 360" [URL]
              • E
                Egnos
                Hello everybody!
                I’m trying to set up the module by doing some tests.
                I am using this configuration, using the test stream recommended by the developer “rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov”:
                		   module: "MMM-RTSPStream",
                		   //position: "middle_center",
                		   pages: {Security: "middle_center"},
                		   header: "Test",
                				autoStart: true,
                				rotateStreams: false,
                				rotateStreamTimeout: 10,
                				moduleWidth: 354,
                				moduleHeight: 240,
                				localPlayer: 'omxplayer',
                				remotePlayer: 'none',
                				showSnapWhenPaused: false,
                				remoteSnaps: false,
                				stream1: {
                					url: 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov',
                					frameRate: 'undefined',
                					width: undefined,
                					height: undefined,
                The module starts but I don’t see anything.
                Below is a screen shot of the MM:
                2020-04-02-144902-1920x1080-scrot
                Where am I wrong?
                Thank you all.
                bheplerB 1 Reply Last reply
                • bheplerB
                  bhepler Module Developer @Egnos
                  @Egnos - Have you checked to make sure there is something at that URL? I punched it into VLC and got connection failed.
                  E 1 Reply Last reply
                  • E
                    Egnos @bhepler
                    @bhepler thanks for the answer.
                    I thought it was just my problem.
                    I found the link on the gitHub page.
                    The developer recommends using this link for testing and I thought it worked.
                    Do you know any public links to test the module?
                    Regards.
                    • evroomE
                      evroom
                      Try this link:
                      rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                      • E
                        Egnos @evroom
                        Many thanks @evroom, the link works in VLC but still doesn’t work in MM.
                        Below what I see on the terminal:
                        [10:58:31.986] [LOG]    Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,238,1138,480 --live --video_queue 4 --fps 30 --no-osd rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                        [10:58:32.033] [LOG]    Starting PM2 for omx_stream1
                        [10:58:43.404] [LOG]    PM2 started for omx_stream1
                        Are there any errors in config.js?
                        		   header: "Test",
                        				autoStart: true,
                        				moduleWidth: 354,
                        				moduleHeight: 240,
                        				remoteSnaps: false,
                        				stream1: {
                        					url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                        					width: undefined,
                        					height: undefined,
                        Thanks for your patience!
                        evroomE 1 Reply Last reply
                        • evroomE
                          evroom
                          @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                          What does this say ?
                          pm2 logs --lines 100
                          The part where you should see
                          0|MagicMirror  | Starting stream stream1 with args: [
                          And
                          pm2 status
                          should show
                          omx_stream1
                          And can you try it from the command line ?
                          omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                          • E
                            Egnos @evroom
                            Hi @evroom ,
                            @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                            I never posted this …!
                            I launched the command on the terminal you recommended but I still don’t see anything, here is the result:
                            pi@MagicMirror:~ $ omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                            Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
                            Audio codec aac channels 2 samplerate 12000 bitspersample 16
                            Subtitle count: 0, state: off, index: 1, delay: 0
                            V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                            And this the log “omxplayer.log”:
                            omxplayer.log
                            I paste all the info that the MM prints on the terminal:
                            > magicmirror@2.10.1 start /home/pi/MagicMirror
                            > ./run-start.sh
                            [19:45:33.744] [LOG]    Starting MagicMirror: v2.10.1
                            [19:45:33.792] [LOG]    Loading config ...
                            [19:45:33.805] [LOG]    Loading module helpers ...
                            [19:45:37.253] [LOG]    Initializing new module helper ...
                            [19:45:37.255] [LOG]    Module helper loaded: MMM-RTSPStream
                            [19:45:37.256] [LOG]    All module helpers loaded.
                            [19:45:37.257] [LOG]    Starting server on port 8080 ...
                            [19:45:37.346] [LOG]    Server started ...
                            [19:45:37.348] [LOG]    Connecting socket for: MMM-RTSPStream
                            [19:45:37.350] [LOG]    PM2: Stopping all OMXPlayer Streams...
                            [19:45:37.352] [LOG]    Sockets connected & modules started ...
                            [19:45:38.246] [LOG]    Launching application.
                            [19:45:46.329] [LOG]    Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,238,1138,480 --live --video_queue 4 --fps 30 --no-osd rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                            [19:45:46.426] [LOG]    Starting PM2 for omx_stream1
                            [19:45:53.630] [LOG]    PM2 started for omx_stream1
                            I don’t understand what’s missing…
                            • evroomE
                              evroom
                              It does look good.
                              In principle, the line from the pm2 log
                              should work as standalone.
                              If it does not play standalone, so from the command line, then it will not work in MMM-RTSPStream.
                              I would disable the module and make sure nothing is running anymore (no omxplayer stuff).
                              disabled: true,
                              pm2 restart mm
                              pm2 status
                              Make sure ‘omx_stream1’ is not present.
                              Stop it when necessary
                              pm2 stop omx_stream1
                              pm2 delete omx_stream1
                              ps -eaf | grep -v grep | grep omxplayer
                              Kill any omxplayer process (kill -9 ).
                              Then run omxplayer from command line:
                              • evroomE
                                evroom @Egnos
                                This is my config that works.
                                I think the only real difference is the omxRestart entry.
                                  disabled: false,
                                  position: "bottom_right",
                                  header: "MMM-RTSPStream Test",
                                    autoStart: true,
                                    omxRestart: 1,
                                    moduleWidth: "352px", // Width in px of the module.
                                    moduleHeight: "240px", // Height in px of the module.
                                    remoteSnaps: false,
                                    stream1: {
                                      frameRate: "25",
                                      protocol: "tcp",
                                      width: "352px", // The width in px of the stream.
                                      height: "240px", // The height in px of the stream.
                                • E
                                  Egnos @evroom
                                  @evroom many thanks!
                                  I don’t know why but now I’m viewing the video in MM.
                                  I haven’t touched anything!
                                  • E
                                    Egnos @evroom
                                    @evroom I finally understood what the problem is … that is VNC.
                                    I use VNC to connect with the Raspberry PI and for some reason, using the VNC interface, the player is not displayed!
                                    If instead I turn on the monitor where the Raspberry PI is physically connected I magically see the streaming … whether I run the command from the terminal or with the MM.
                                    Can you explain this behavior?
                                    • evroomE
                                      evroom
                                      No, I cannot explain this, but I noticed it too.
                                      No video over the VNC connection.
                                      When I google, I see this recommendation:
                                      Open VNC Server>Options>Troubleshooting. Then make sure "enable experimental direct capture mode is checked.
                                      You might give it a try.
                                        costascontis
                                        hello,lil help,what do i have to add in custom.css to align MMM-RTSPStream window with the module below?
                                        https://imgur.com/XQZNEvg
                                        • E
                                          Egnos @evroom
                                          @evroom now, enabling in VNC options “direct capture mode”, also from VNC I see the stream on omxplayer and on MM.
                                          Many Thanks! 👍
                                          • I
                                            imdickie
                                            I’m going from a working Raspi3 to a Raspi4 and using the exact same working module configuration I cannot get video on omxplayer using this module.
                                            I set up a pristine image and loaded everything one at a time, but this one fails. I pulled out all of the modules to make sure there was nothing in them that was causing the issue.
                                            Below is my module config and my logs pulled using pm2 logs mm. There is an error, but I don’t know enough about this to determine the cause. Can anyone review the logs and provide some direction?
                                            Thanks.
                                            		    position: "bottom_bar",
                                            		        autoStart: true,
                                            		        rotateStreams: true,
                                            		        moduleWidth: 642,
                                            		        moduleHeight: 362,
                                            		        showSnapWhenPaused: true,
                                            		        remoteSnaps: true,
                                            		        stream1: {
                                            		            url: 'rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/',
                                            		            frameRate: '10',
                                            		            snapshotType: 'url',
                                            		            snapshotRefresh: 10,
                                            		            width: 640,
                                            		            height: 360,
                                            pi@raspberrypi:~ $ pm2 logs mm --lines 100
                                            [TAILING] Tailing last 100 lines for [mm] process (change the value with --lines option)
                                            0|mm | [2020-04-08 14:17:49.908] [ERROR] TypeError: Cannot convert undefined or null to object
                                            0|mm | at Function.keys ()
                                            0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                                            0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
                                            0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
                                            0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                                            0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                                            0|mm | at Parser.emit (events.js:200:13)
                                            0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                                            0|mm | at doWrite (_stream_writable.js:417:12)
                                            0|mm | at writeOrBuffer (_stream_writable.js:401:5)
                                            0|mm |
                                            0|mm | > magicmirror@2.11.0 start /home/pi/MagicMirror
                                            0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                            0|mm |
                                            0|mm | [2020-04-08 14:17:48.507] [LOG] Starting MagicMirror: v2.11.0
                                            0|mm | [2020-04-08 14:17:48.514] [LOG] Loading config …
                                            0|mm | [2020-04-08 14:17:48.519] [LOG] Loading module helpers …
                                            0|mm | [2020-04-08 14:17:49.292] [LOG] Initializing new module helper …
                                            0|mm | [2020-04-08 14:17:49.293] [LOG] Module helper loaded: MMM-RTSPStream
                                            0|mm | [2020-04-08 14:17:49.293] [LOG] All module helpers loaded.
                                            0|mm | [2020-04-08 14:17:49.399] [LOG] Starting server on port 8080 …
                                            0|mm | [2020-04-08 14:17:49.421] [LOG] Server started …
                                            0|mm | [2020-04-08 14:17:49.422] [LOG] Connecting socket for: MMM-RTSPStream
                                            0|mm | [2020-04-08 14:17:49.423] [LOG] PM2: Stopping all OMXPlayer Streams…
                                            0|mm | [2020-04-08 14:17:49.424] [LOG] Sockets connected & modules started …
                                            0|mm | [2020-04-08 14:17:49.531] [LOG] Launching application.
                                            0|mm | [2020-04-08 14:17:49.908] [LOG] Whoops! There was an uncaught exception…
                                            0|mm | [2020-04-08 14:17:49.916] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|mm | [2020-04-08 14:17:49.916] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            0|mm | [2020-04-08 14:17:53.508] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 282,1501,922,1861 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/
                                            0|mm | [2020-04-08 14:17:53.527] [LOG] Starting PM2 for omx_stream1
                                            0|mm | [2020-04-08 14:17:53.698] [LOG] PM2 started for omx_stream1
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 30
                                            • 31
                                            • 24 / 31
