    602 Posts 67 Posters 2.4m Views 68 Watching
    • E
      Egnos @bhepler
      @bhepler thanks for the answer.
      I thought it was just my problem.
      I found the link on the gitHub page.
      The developer recommends using this link for testing and I thought it worked.
      Do you know any public links to test the module?
      Regards.
      • evroomE
        evroom
        Try this link:
        rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
        MagicMirror version: 2.37.0
        E 1 Reply Last reply
        • E
          Egnos @evroom
          Many thanks @evroom, the link works in VLC but still doesn’t work in MM.
          Below what I see on the terminal:
          [10:58:31.986] [LOG]    Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,238,1138,480 --live --video_queue 4 --fps 30 --no-osd rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
          [10:58:32.033] [LOG]    Starting PM2 for omx_stream1
          [10:58:43.404] [LOG]    PM2 started for omx_stream1
          Are there any errors in config.js?
          		   module: "MMM-RTSPStream",
          		   //position: "middle_center",
          		   pages: {Security: "middle_center"},
          		   header: "Test",
          				autoStart: true,
          				rotateStreams: false,
          				rotateStreamTimeout: 10,
          				moduleWidth: 354,
          				moduleHeight: 240,
          				localPlayer: 'omxplayer',
          				remotePlayer: 'none',
          				showSnapWhenPaused: false,
          				remoteSnaps: false,
          				stream1: {
          					url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
          					frameRate: 'undefined',
          					width: undefined,
          					height: undefined,
          Thanks for your patience!
          evroomE 1 Reply Last reply
          • evroomE
            evroom
            @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            What does this say ?
            pm2 logs --lines 100
            The part where you should see
            0|MagicMirror  | Starting stream stream1 with args: [
            And
            pm2 status
            should show
            omx_stream1
            And can you try it from the command line ?
            omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
            • E
              Egnos @evroom
              Hi @evroom ,
              @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              I never posted this …!
              I launched the command on the terminal you recommended but I still don’t see anything, here is the result:
              pi@MagicMirror:~ $ omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
              Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
              Audio codec aac channels 2 samplerate 12000 bitspersample 16
              Subtitle count: 0, state: off, index: 1, delay: 0
              V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
              And this the log “omxplayer.log”:
              omxplayer.log
              I paste all the info that the MM prints on the terminal:
              > magicmirror@2.10.1 start /home/pi/MagicMirror
              > ./run-start.sh
              [19:45:33.744] [LOG]    Starting MagicMirror: v2.10.1
              [19:45:33.792] [LOG]    Loading config ...
              [19:45:33.805] [LOG]    Loading module helpers ...
              [19:45:37.253] [LOG]    Initializing new module helper ...
              [19:45:37.255] [LOG]    Module helper loaded: MMM-RTSPStream
              [19:45:37.256] [LOG]    All module helpers loaded.
              [19:45:37.257] [LOG]    Starting server on port 8080 ...
              [19:45:37.346] [LOG]    Server started ...
              [19:45:37.348] [LOG]    Connecting socket for: MMM-RTSPStream
              [19:45:37.350] [LOG]    PM2: Stopping all OMXPlayer Streams...
              [19:45:37.352] [LOG]    Sockets connected & modules started ...
              [19:45:38.246] [LOG]    Launching application.
              [19:45:46.329] [LOG]    Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,238,1138,480 --live --video_queue 4 --fps 30 --no-osd rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
              [19:45:46.426] [LOG]    Starting PM2 for omx_stream1
              [19:45:53.630] [LOG]    PM2 started for omx_stream1
              I don’t understand what’s missing…
              • evroomE
                evroom
                It does look good.
                In principle, the line from the pm2 log
                should work as standalone.
                If it does not play standalone, so from the command line, then it will not work in MMM-RTSPStream.
                I would disable the module and make sure nothing is running anymore (no omxplayer stuff).
                disabled: true,
                pm2 restart mm
                pm2 status
                Make sure ‘omx_stream1’ is not present.
                Stop it when necessary
                pm2 stop omx_stream1
                pm2 delete omx_stream1
                ps -eaf | grep -v grep | grep omxplayer
                Kill any omxplayer process (kill -9 ).
                Then run omxplayer from command line:
                • evroomE
                  evroom @Egnos
                  This is my config that works.
                  I think the only real difference is the omxRestart entry.
                    disabled: false,
                    position: "bottom_right",
                    header: "MMM-RTSPStream Test",
                      autoStart: true,
                      omxRestart: 1,
                      moduleWidth: "352px", // Width in px of the module.
                      moduleHeight: "240px", // Height in px of the module.
                      remoteSnaps: false,
                      stream1: {
                        frameRate: "25",
                        protocol: "tcp",
                        width: "352px", // The width in px of the stream.
                        height: "240px", // The height in px of the stream.
                  • E
                    Egnos @evroom
                    @evroom many thanks!
                    I don’t know why but now I’m viewing the video in MM.
                    I haven’t touched anything!
                    • E
                      Egnos @evroom
                      @evroom I finally understood what the problem is … that is VNC.
                      I use VNC to connect with the Raspberry PI and for some reason, using the VNC interface, the player is not displayed!
                      If instead I turn on the monitor where the Raspberry PI is physically connected I magically see the streaming … whether I run the command from the terminal or with the MM.
                      Can you explain this behavior?
                      • evroomE
                        evroom
                        No, I cannot explain this, but I noticed it too.
                        No video over the VNC connection.
                        When I google, I see this recommendation:
                        Open VNC Server>Options>Troubleshooting. Then make sure "enable experimental direct capture mode is checked.
                        You might give it a try.
                          costascontis
                          hello,lil help,what do i have to add in custom.css to align MMM-RTSPStream window with the module below?
                          https://imgur.com/XQZNEvg
                          • E
                            Egnos @evroom
                            @evroom now, enabling in VNC options “direct capture mode”, also from VNC I see the stream on omxplayer and on MM.
                            Many Thanks! 👍
                            • I
                              imdickie
                              I’m going from a working Raspi3 to a Raspi4 and using the exact same working module configuration I cannot get video on omxplayer using this module.
                              I set up a pristine image and loaded everything one at a time, but this one fails. I pulled out all of the modules to make sure there was nothing in them that was causing the issue.
                              Below is my module config and my logs pulled using pm2 logs mm. There is an error, but I don’t know enough about this to determine the cause. Can anyone review the logs and provide some direction?
                              Thanks.
                              		    position: "bottom_bar",
                              		        autoStart: true,
                              		        rotateStreams: true,
                              		        moduleWidth: 642,
                              		        moduleHeight: 362,
                              		        showSnapWhenPaused: true,
                              		        remoteSnaps: true,
                              		        stream1: {
                              		            url: 'rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/',
                              		            frameRate: '10',
                              		            snapshotType: 'url',
                              		            snapshotRefresh: 10,
                              		            width: 640,
                              		            height: 360,
                              pi@raspberrypi:~ $ pm2 logs mm --lines 100
                              [TAILING] Tailing last 100 lines for [mm] process (change the value with --lines option)
                              0|mm | [2020-04-08 14:17:49.908] [ERROR] TypeError: Cannot convert undefined or null to object
                              0|mm | at Function.keys ()
                              0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                              0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
                              0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
                              0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                              0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                              0|mm | at Parser.emit (events.js:200:13)
                              0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                              0|mm | at doWrite (_stream_writable.js:417:12)
                              0|mm | at writeOrBuffer (_stream_writable.js:401:5)
                              0|mm |
                              0|mm | > magicmirror@2.11.0 start /home/pi/MagicMirror
                              0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                              0|mm |
                              0|mm | [2020-04-08 14:17:48.507] [LOG] Starting MagicMirror: v2.11.0
                              0|mm | [2020-04-08 14:17:48.514] [LOG] Loading config …
                              0|mm | [2020-04-08 14:17:48.519] [LOG] Loading module helpers …
                              0|mm | [2020-04-08 14:17:49.292] [LOG] Initializing new module helper …
                              0|mm | [2020-04-08 14:17:49.293] [LOG] Module helper loaded: MMM-RTSPStream
                              0|mm | [2020-04-08 14:17:49.293] [LOG] All module helpers loaded.
                              0|mm | [2020-04-08 14:17:49.399] [LOG] Starting server on port 8080 …
                              0|mm | [2020-04-08 14:17:49.421] [LOG] Server started …
                              0|mm | [2020-04-08 14:17:49.422] [LOG] Connecting socket for: MMM-RTSPStream
                              0|mm | [2020-04-08 14:17:49.423] [LOG] PM2: Stopping all OMXPlayer Streams…
                              0|mm | [2020-04-08 14:17:49.424] [LOG] Sockets connected & modules started …
                              0|mm | [2020-04-08 14:17:49.531] [LOG] Launching application.
                              0|mm | [2020-04-08 14:17:49.908] [LOG] Whoops! There was an uncaught exception…
                              0|mm | [2020-04-08 14:17:49.916] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              0|mm | [2020-04-08 14:17:49.916] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              0|mm | [2020-04-08 14:17:53.508] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 282,1501,922,1861 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/
                              0|mm | [2020-04-08 14:17:53.527] [LOG] Starting PM2 for omx_stream1
                              0|mm | [2020-04-08 14:17:53.698] [LOG] PM2 started for omx_stream1
                              • I
                                imdickie
                                Getting closer. Hoping to get some help based on the new info below.
                                I was able to get a video stream, but…
                                It only works in the middle_center position and the video orientation is rotated 90 deg.
                                I tried using the rotateDegree switch, and it does rotate it, but the video frame stays in the portriat oreintation.
                                Video Oreintation
                                I am using the below config file.
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: "clock",
                                			position: "top_left"
                                			header: "Family Calendar",
                                				colored: "true",
                                						symbol: "calendar-check-o ",
                                						color: "#34a95f",
                                						url: "https://calendar.google.com/calendar/ical/xxx/basic.ics"
                                						color: "#b1002c",
                                		  module: "MMM-DarkSkyForecast",
                                		  header: "Weather",
                                		  classes: "default everyone",
                                		  disabled: false,
                                		    apikey: "xxx",
                                		    latitude: "33.481613",
                                		    longitude: "-117.061959",
                                		    iconset: "5c",
                                		    concise: false,
                                    		    forecastLayout: "table",
                                		    units: "us"
                                		module: 'MMM-RTSPStream',
                                		position: 'middle_center',
                                		    autoStart: true,
                                		    moduleWidth: 642,
                                		    moduleHeight: 362,
                                		    stream1: {
                                			url: 'rtsp://xxx:xxx@192.168.x.xxx:554/Streaming/Channels/102/',
                                			snapshotUrl: '',
                                			snapshotRefresh: 10, // Seconds
                                			frameRate: "30",
                                			width: 640,
                                		        height: 360,
                                			port: 9999,
                                			module: "compliments",
                                			position: "bottom_center"
                                			module: "newsfeed",
                                			position: "bottom_center",
                                				feeds: [
                                						title: "New York Times",
                                				showSourceTitle: true,
                                				showPublishDate: true
                                	            module: 'MMM-GoogleMapsTraffic',
                                	            position: 'bottom_center',
                                	                key: 'xxx',
                                	                lat: xxx,
                                	                lng: -xxx,
                                	                height: '360px',
                                	                width: '360px',
                                	                styledMapType: "",
                                	                disableDefaultUI: true,
                                	                backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                • evroomE
                                  evroom
                                  @imdickie said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                  In
                                  /home/pi/MagicMirror/css/custom.css
                                  add
                                  .MMM-RTSPStream .innerWrapper {
                                    border-style: none;
                                  to remove the frame altogether.
                                  Or find a way using css to rotate the frame.
                                  I tried the positions top_left, top_right, bottom_left and bottom_right.
                                  All work.
                                  It can be that your other modules are pushing it down.
                                  Try to have the module positioned a bit earlier in your config.
                                  • PointPubMediaP
                                    PointPubMedia
                                    @shbatm Do you think it could be possible to run this on another plateform, like pine64 with armbian where omxplayer is not available?
                                    The npm install part is not working as omxplayer is not available…
                                    • K
                                      KumarTRD
                                      Has anyone had success getting this module to work with Lorex security cameras? The is the only module preventing my magic mirror being “complete”
                                      • BKeyportB
                                        BKeyport Module Developer
                                        1st, have you tried the URL string at https://www.ispyconnect.com/man.aspx?n=Lorex ?
                                        2nd, have you verified that the video player you want is able to run the video stream?
                                          costascontis
                                          i am using vlc as local player to play my stream locally just fine.When i try to access MM from my pc (chrome) using http://mmip:8080 ,my stream is not starting at all.Using ffmpeg for remote player and i also test my stream using ffplay and it works just fine at my rpi3b.What is wrong ???
                                          BKeyportB 1 Reply Last reply
                                          • BKeyportB
                                            BKeyport Module Developer @costascontis
                                            @costascontis Try a different local player. In testing of the last version I used, VLC had an invalid command line. I honestly have abandoned the module totally in favor of an external approach for the camera.
                                            C 1 Reply Last reply
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
