    602 Posts 67 Posters 2.3m Views 68 Watching
    • evroomE Online
      evroom
      @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      the link works in VLC but still doesn’t work in MM
      What does this say ?
      pm2 logs --lines 100
      The part where you should see
      0|MagicMirror  | Starting stream stream1 with args: [
      And
      pm2 status
      should show
      omx_stream1
      And can you try it from the command line ?
      omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
      MagicMirror version: 2.37.0
      • E Offline
        Egnos @evroom
        Hi @evroom ,
        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        I never posted this …!
        I launched the command on the terminal you recommended but I still don’t see anything, here is the result:
        pi@MagicMirror:~ $ omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
        Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
        Audio codec aac channels 2 samplerate 12000 bitspersample 16
        Subtitle count: 0, state: off, index: 1, delay: 0
        V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
        And this the log “omxplayer.log”:
        omxplayer.log
        I paste all the info that the MM prints on the terminal:
        > magicmirror@2.10.1 start /home/pi/MagicMirror
        > ./run-start.sh
        [19:45:33.744] [LOG]    Starting MagicMirror: v2.10.1
        [19:45:33.792] [LOG]    Loading config ...
        [19:45:33.805] [LOG]    Loading module helpers ...
        [19:45:37.253] [LOG]    Initializing new module helper ...
        [19:45:37.255] [LOG]    Module helper loaded: MMM-RTSPStream
        [19:45:37.256] [LOG]    All module helpers loaded.
        [19:45:37.257] [LOG]    Starting server on port 8080 ...
        [19:45:37.346] [LOG]    Server started ...
        [19:45:37.348] [LOG]    Connecting socket for: MMM-RTSPStream
        [19:45:37.350] [LOG]    PM2: Stopping all OMXPlayer Streams...
        [19:45:37.352] [LOG]    Sockets connected & modules started ...
        [19:45:38.246] [LOG]    Launching application.
        [19:45:46.329] [LOG]    Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,238,1138,480 --live --video_queue 4 --fps 30 --no-osd rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
        [19:45:46.426] [LOG]    Starting PM2 for omx_stream1
        [19:45:53.630] [LOG]    PM2 started for omx_stream1
        I don’t understand what’s missing…
        • evroomE Online
          evroom
          It does look good.
          In principle, the line from the pm2 log
          should work as standalone.
          If it does not play standalone, so from the command line, then it will not work in MMM-RTSPStream.
          I would disable the module and make sure nothing is running anymore (no omxplayer stuff).
          module: "MMM-RTSPStream",
          disabled: true,
          pm2 restart mm
          pm2 status
          Make sure ‘omx_stream1’ is not present.
          Stop it when necessary
          pm2 stop omx_stream1
          pm2 delete omx_stream1
          ps -eaf | grep -v grep | grep omxplayer
          Kill any omxplayer process (kill -9 ).
          Then run omxplayer from command line:
          • evroomE Online
            evroom @Egnos
            Are there any errors in config.js?
            This is my config that works.
            I think the only real difference is the omxRestart entry.
              disabled: false,
              position: "bottom_right",
              header: "MMM-RTSPStream Test",
                autoStart: true,
                omxRestart: 1,
                rotateStreams: false,
                moduleWidth: "352px", // Width in px of the module.
                moduleHeight: "240px", // Height in px of the module.
                localPlayer: 'omxplayer',
                remotePlayer: 'none',
                showSnapWhenPaused: false,
                remoteSnaps: false,
                stream1: {
                  url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                  frameRate: "25",
                  protocol: "tcp",
                  width: "352px", // The width in px of the stream.
                  height: "240px", // The height in px of the stream.
            • E Offline
              Egnos @evroom
              @evroom many thanks!
              I don’t know why but now I’m viewing the video in MM.
              I haven’t touched anything!
              • E Offline
                Egnos @evroom
                @evroom I finally understood what the problem is … that is VNC.
                I use VNC to connect with the Raspberry PI and for some reason, using the VNC interface, the player is not displayed!
                If instead I turn on the monitor where the Raspberry PI is physically connected I magically see the streaming … whether I run the command from the terminal or with the MM.
                Can you explain this behavior?
                • evroomE Online
                  evroom
                  No, I cannot explain this, but I noticed it too.
                  No video over the VNC connection.
                  When I google, I see this recommendation:
                  Open VNC Server>Options>Troubleshooting. Then make sure "enable experimental direct capture mode is checked.
                  You might give it a try.
                    costascontis
                    hello,lil help,what do i have to add in custom.css to align MMM-RTSPStream window with the module below?
                    https://imgur.com/XQZNEvg
                    • E Offline
                      Egnos @evroom
                      @evroom now, enabling in VNC options “direct capture mode”, also from VNC I see the stream on omxplayer and on MM.
                      Many Thanks! 👍
                      • I Offline
                        imdickie
                        I’m going from a working Raspi3 to a Raspi4 and using the exact same working module configuration I cannot get video on omxplayer using this module.
                        I set up a pristine image and loaded everything one at a time, but this one fails. I pulled out all of the modules to make sure there was nothing in them that was causing the issue.
                        Below is my module config and my logs pulled using pm2 logs mm. There is an error, but I don’t know enough about this to determine the cause. Can anyone review the logs and provide some direction?
                        Thanks.
                        		    position: "bottom_bar",
                        		        autoStart: true,
                        		        rotateStreams: true,
                        		        rotateStreamTimeout: 10,
                        		        moduleWidth: 642,
                        		        moduleHeight: 362,
                        		        showSnapWhenPaused: true,
                        		        remoteSnaps: true,
                        		        stream1: {
                        		            url: 'rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/',
                        		            frameRate: '10',
                        		            snapshotType: 'url',
                        		            snapshotRefresh: 10,
                        		            width: 640,
                        		            height: 360,
                        pi@raspberrypi:~ $ pm2 logs mm --lines 100
                        [TAILING] Tailing last 100 lines for [mm] process (change the value with --lines option)
                        0|mm | [2020-04-08 14:17:49.908] [ERROR] TypeError: Cannot convert undefined or null to object
                        0|mm | at Function.keys ()
                        0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                        0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
                        0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
                        0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                        0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                        0|mm | at Parser.emit (events.js:200:13)
                        0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                        0|mm | at doWrite (_stream_writable.js:417:12)
                        0|mm | at writeOrBuffer (_stream_writable.js:401:5)
                        0|mm |
                        0|mm | > magicmirror@2.11.0 start /home/pi/MagicMirror
                        0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                        0|mm |
                        0|mm | [2020-04-08 14:17:48.507] [LOG] Starting MagicMirror: v2.11.0
                        0|mm | [2020-04-08 14:17:48.514] [LOG] Loading config …
                        0|mm | [2020-04-08 14:17:48.519] [LOG] Loading module helpers …
                        0|mm | [2020-04-08 14:17:49.292] [LOG] Initializing new module helper …
                        0|mm | [2020-04-08 14:17:49.293] [LOG] Module helper loaded: MMM-RTSPStream
                        0|mm | [2020-04-08 14:17:49.293] [LOG] All module helpers loaded.
                        0|mm | [2020-04-08 14:17:49.399] [LOG] Starting server on port 8080 …
                        0|mm | [2020-04-08 14:17:49.421] [LOG] Server started …
                        0|mm | [2020-04-08 14:17:49.422] [LOG] Connecting socket for: MMM-RTSPStream
                        0|mm | [2020-04-08 14:17:49.423] [LOG] PM2: Stopping all OMXPlayer Streams…
                        0|mm | [2020-04-08 14:17:49.424] [LOG] Sockets connected & modules started …
                        0|mm | [2020-04-08 14:17:49.531] [LOG] Launching application.
                        0|mm | [2020-04-08 14:17:49.908] [LOG] Whoops! There was an uncaught exception…
                        0|mm | [2020-04-08 14:17:49.916] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|mm | [2020-04-08 14:17:49.916] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        0|mm | [2020-04-08 14:17:53.508] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 282,1501,922,1861 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@192.168.1.164:554/Streaming/Channels/102/
                        0|mm | [2020-04-08 14:17:53.527] [LOG] Starting PM2 for omx_stream1
                        0|mm | [2020-04-08 14:17:53.698] [LOG] PM2 started for omx_stream1
                        • I Offline
                          imdickie
                          Getting closer. Hoping to get some help based on the new info below.
                          I was able to get a video stream, but…
                          It only works in the middle_center position and the video orientation is rotated 90 deg.
                          I tried using the rotateDegree switch, and it does rotate it, but the video frame stays in the portriat oreintation.
                          Video Oreintation
                          I am using the below config file.
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "Family Calendar",
                          				colored: "true",
                          						symbol: "calendar-check-o ",
                          						color: "#34a95f",
                          						url: "https://calendar.google.com/calendar/ical/xxx/basic.ics"
                          						color: "#b1002c",
                          		  module: "MMM-DarkSkyForecast",
                          		  header: "Weather",
                          		  classes: "default everyone",
                          		  disabled: false,
                          		    apikey: "xxx",
                          		    latitude: "33.481613",
                          		    longitude: "-117.061959",
                          		    iconset: "5c",
                          		    concise: false,
                              		    forecastLayout: "table",
                          		    units: "us"
                          		module: 'MMM-RTSPStream',
                          		position: 'middle_center',
                          		    autoStart: true,
                          		    moduleWidth: 642,
                          		    moduleHeight: 362,
                          		    stream1: {
                          			url: 'rtsp://xxx:xxx@192.168.x.xxx:554/Streaming/Channels/102/',
                          			snapshotUrl: '',
                          			snapshotRefresh: 10, // Seconds
                          			frameRate: "30",
                          			width: 640,
                          		        height: 360,
                          			port: 9999,
                          			module: "compliments",
                          			position: "bottom_center"
                          			module: "newsfeed",
                          			position: "bottom_center",
                          				feeds: [
                          						title: "New York Times",
                          				showSourceTitle: true,
                          				showPublishDate: true
                          	            module: 'MMM-GoogleMapsTraffic',
                          	            position: 'bottom_center',
                          	                key: 'xxx',
                          	                lat: xxx,
                          	                lng: -xxx,
                          	                height: '360px',
                          	                width: '360px',
                          	                styledMapType: "",
                          	                disableDefaultUI: true,
                          	                backgroundColor: 'hsla(0, 0%, 0%, 0)',
                          • evroomE Online
                            evroom
                            @imdickie said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                            In
                            /home/pi/MagicMirror/css/custom.css
                            add
                            .MMM-RTSPStream .innerWrapper {
                              border-style: none;
                            to remove the frame altogether.
                            Or find a way using css to rotate the frame.
                            I tried the positions top_left, top_right, bottom_left and bottom_right.
                            All work.
                            It can be that your other modules are pushing it down.
                            Try to have the module positioned a bit earlier in your config.
                              PointPubMedia
                              @shbatm Do you think it could be possible to run this on another plateform, like pine64 with armbian where omxplayer is not available?
                              The npm install part is not working as omxplayer is not available…
                              • K Offline
                                KumarTRD
                                Has anyone had success getting this module to work with Lorex security cameras? The is the only module preventing my magic mirror being “complete”
                                • BKeyportB Offline
                                  BKeyport Module Developer
                                  1st, have you tried the URL string at https://www.ispyconnect.com/man.aspx?n=Lorex ?
                                  2nd, have you verified that the video player you want is able to run the video stream?
                                    costascontis
                                    i am using vlc as local player to play my stream locally just fine.When i try to access MM from my pc (chrome) using http://mmip:8080 ,my stream is not starting at all.Using ffmpeg for remote player and i also test my stream using ffplay and it works just fine at my rpi3b.What is wrong ???
                                    • BKeyportB Offline
                                      BKeyport Module Developer @costascontis
                                      @costascontis Try a different local player. In testing of the last version I used, VLC had an invalid command line. I honestly have abandoned the module totally in favor of an external approach for the camera.
                                        costascontis @BKeyport
                                        @BKeyport i dont have any problem with vlc as local player ,my issue is with remote player,ffmpeg.I am trying to see the feed from windows pc with chrome.Every other module is working fine ,the live feed is starting but i only see black,no camera image.
                                        • BKeyportB Offline
                                          @costascontis oh, sorry, I misunderstood.
                                          • Z Offline
                                            zzricezz
                                            I’m assuming if i just have 1 stream, it will most likely cause a burn-in issue? any good idea? like transition between a black backgroup ever minute or so for couple of seconds?
                                            Thanks,
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
