    602 Posts 67 Posters 2.3m Views 68 Watching
    • E Offline
      Egnos @BKeyport
      Thanks a loro @BKeyport and @evroom!
      In a few days I will try your advice.
      @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      RTSPStream’s clunky enough that you might find it easier (and better) to run OMXplayer independently of the mirror, like evroom has done, as have I.
      does this mean i have to uninstall the module RTSPStream’s and install only the component OMXplayer?
      • evroomE Offline
        evroom
        @Egnos said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        If you are able to install OMXPlayer, then you can give MMM-RTSPStream a try.
        In principle it does work, depending on what you want to stream.
        If it works for you, perfect, if it doesn’t, then try if omxplayer works standalone,
        Actually testing omxplayer standalone is always a good thing before trying out MMM-RTSPStream.
        MagicMirror version: 2.37.0
        • BKeyportB Offline
          BKeyport Module Developer
          You don’t have to uninstall a module - just take it out of your config. In my case, once I got OMX working, and followed evroom’s instructions to start, I found that using OMX directly rather than through the module is rather cleaner. I can run the hi-def stream for one thing.
            DirkS
            Hi, i have used the Module for a long time now jsut with snapshots. I never streamed live.
            A year ago i switched the native magic mirror to docker install to use it for more devices at the same time. RTSPStream just worked fine after that change. But in last december i updated it and since that moment it stopped working. I had other issues to do so i did not investigate the cause.
            But now i want to get it back working.
            The error i can see via web logging is this:
            Uncaught DOMException: Failed to construct 'WebSocket': The URL 'ws://192.168.10.1:undefined' is invalid.
                at WSSource.start (http://192.168.10.1:82/modules/MMM-RTSPStream/scripts/jsmpeg.min.js:1:16242)
                at new Player (http://192.168.10.1:82/modules/MMM-RTSPStream/scripts/jsmpeg.min.js:1:5838)
                at Class.playStream (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:399:26)
                at Class.rotateStream (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:123:23)
                at Class.setupStreamRotation (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:94:14)
                at Class.resumed (http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:168:22)
                at http://192.168.10.1:82/modules/MMM-RTSPStream//MMM-RTSPStream.js:697:43
            I’ve tried now different ways and also checked if it is streaming. I have installed ffmpeg within the docker container and also the node-rtsp-stream-es6 module. Also i have installed node-rtsp-stream-es6 at one rpi client and just to be sure ffmpeg. But in the past it worked without it.
            Here is my config (now with ffmpeg streaming):
                module: "MMM-RTSPStream",
                position: "bottom_right",
                header: "Rundumblick",
                    autoStart: false,
                    rotateStreams: true,
                    rotateStreamTimeout: 10,
                    moduleWidth: 354,
                    moduleHeight: 240,
                    localPlayer: 'ffmpeg',
                    remotePlayer: 'none',
                    showSnapWhenPaused: true,
                    remoteSnaps: true,
            	debug: true,
                    stream1: {
                        url: 'rtsp://192.168.10.1:7447/5af753a0b1d674c3bbc08189_1',
                        frameRate: 'undefined',
                        hdUrl: 'rtsp://192.168.10.1:7447/5af753a0b1d674c3bbc08189_0',
                        snapshotUrl: 'http://192.168.10.55/snap.jpeg',
                        snapshotType: 'url',
                        snapshotRefresh: 10,
                        width: undefined,
                        height: undefined,
                    stream2: {
                        url: 'rtsp://192.168.10.1:7447/5af75418b1d674c3bbc0818a_1',
                        hdUrl: 'rtsp://192.168.10.1:7447/5af75418b1d674c3bbc0818a_0',
                        snapshotUrl: 'http://192.168.10.56/snap.jpeg',
                        width: undefined,
                        height: undefined,
                    stream3: {
                        url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa9_1',
                        hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa9_0',
                        snapshotUrl: 'http://192.168.10.50/snap.jpeg',
                        width: undefined,
                        height: undefined,
                    stream4: {
                        url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa6_1',
                        hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa6_0',
                        snapshotUrl: 'http://192.168.10.54/snap.jpeg',
                        width: undefined,
                        height: undefined,
            	stream5: {
            	    url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa8_1',
                        hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa8_0',
                        snapshotUrl: 'http://192.168.10.53/snap.jpeg',
                        widht: undefined,
                        height: undefined,
            	stream6: {
            	   url: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa7_2',
            	   hdUrl: 'rtsp://192.168.10.1:7447/59541285b6468d91abd88fa7_0',
                       snapshotUrl: 'http://192.168.10.51/snap.jpeg',
            	   widht: undefined,
            	   height: undefined,
            	stream7: {
                       snapshotUrl: 'http://192.168.10.52/snap.jpeg',
                       widht: undefined,
                       height: undefined,
            can anybody assume where to search the cause? I’m out of ideas :(
            If i just want to have snapshots i get this:
            MMM-RTSPStream.js:712 Uncaught TypeError: Cannot read property 'appendChild' of null
                at Class.socketNotificationReceived (MMM-RTSPStream.js:712)
                at module.js:246
                at r.<anonymous> (socketclient.js:25)
                at r.emit (index.js:83)
                at r.onevent (index.js:83)
                at r.MMSocket.self.socket.onevent (socketclient.js:19)
                at r.onpacket (index.js:83)
                at r.<anonymous> (index.js:83)
                at r.ondecoded (index.js:83)
            • E Offline
              Egnos
              @BKeyport and @evroom I tried to install omxplayer but i always get the same error:
              E: Impossibile trovare il pacchetto omxplayer
              Can you help me?
              Many thanks!
              • BKeyportB Offline
                It looks as though you’re on a Pi, correct? If I recall right OMX should be installed with the OS in more than the “lite” install…If it’s not there, it’s not available in your language, maybe. I’m not too versed in how those installs work.
                • evroomE Offline
                  evroom @Egnos
                  Can you help me?
                  What platform are you on.
                  Raspberry Pi with Debian?
                  lsb_release -a
                  sudo apt-get install omxplayer
                  • E Offline
                    Egnos
                    @BKeyport and @evroom this is my environment:
                    • PC Hp Intel I5.
                    • Raspbian on Virtual Box (using Debian…).
                    First I try to make everything work on the virtual machine and then I transfer everything to PI.
                    Many thanks.
                    • BKeyportB Offline
                      @egnos you might never get OMX working in a virtual environment. It works directly with the hardware to show the picture.
                      I would highly recommend setting it up on the pi now, and setting up SSH to communicate.
                      I also have SAMBA (https://www.juanmtech.com/samba-file-sharing-raspberry-pi/) running on my pi, so I can use Geany for Windows (https://www.geany.org/) to directly edit the raspberry files.
                      • H Offline
                        Hram2008
                        Has anyone been able to get this working with Axis camera products? VLC will pull and display the video stream outside of MM but will not display the same stream on MM when configured.
                        Any thoughts???
                        evroomE BKeyportB 2 Replies Last reply Reply Quote 0
                        • evroomE Offline
                          evroom @Hram2008
                          @Hram2008 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                          Yes, I have.
                          Please show your MMM-RTSPStream part from config.js.
                          • BKeyportB Offline
                            BKeyport Module Developer @Hram2008
                            @Hram2008 have you tried running the URL straight with OMX to see if it works, if it does, you may have issues with the plugin itself, and as the author seems to have disappeared, you could just replace the plugin with OMX cutting the proper hole out of the window (It’ll go in front of whatever is running, so you run it independently, and it just works.
                            omxplayer --no-osd --no-keys --avdict rtsp_transport:tcp --live --fps 30 --orientation 0 --win "640 0 1280 360" [URL]
                            -or-
                            omxplayer --no-osd --no-keys --avdict rtsp_transport:udp --live --fps 30 --orientation 0 --win "640 0 1280 360" [URL]
                            • E Offline
                              Egnos
                              Hello everybody!
                              I’m trying to set up the module by doing some tests.
                              I am using this configuration, using the test stream recommended by the developer “rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov”:
                              		   //position: "middle_center",
                              		   pages: {Security: "middle_center"},
                              		   header: "Test",
                              				autoStart: true,
                              				rotateStreams: false,
                              				moduleWidth: 354,
                              				moduleHeight: 240,
                              				localPlayer: 'omxplayer',
                              				showSnapWhenPaused: false,
                              				remoteSnaps: false,
                              				stream1: {
                              					url: 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov',
                              					width: undefined,
                              					height: undefined,
                              The module starts but I don’t see anything.
                              Below is a screen shot of the MM:
                              2020-04-02-144902-1920x1080-scrot
                              Where am I wrong?
                              Thank you all.
                                bhepler Module Developer @Egnos
                                @Egnos - Have you checked to make sure there is something at that URL? I punched it into VLC and got connection failed.
                                • E Offline
                                  Egnos @bhepler
                                  @bhepler thanks for the answer.
                                  I thought it was just my problem.
                                  I found the link on the gitHub page.
                                  The developer recommends using this link for testing and I thought it worked.
                                  Do you know any public links to test the module?
                                  Regards.
                                  • evroomE Offline
                                    evroom
                                    Try this link:
                                    rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                                    • E Offline
                                      Egnos @evroom
                                      Many thanks @evroom, the link works in VLC but still doesn’t work in MM.
                                      Below what I see on the terminal:
                                      [10:58:31.986] [LOG]    Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,238,1138,480 --live --video_queue 4 --fps 30 --no-osd rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                                      [10:58:32.033] [LOG]    Starting PM2 for omx_stream1
                                      [10:58:43.404] [LOG]    PM2 started for omx_stream1
                                      Are there any errors in config.js?
                                      		   header: "Test",
                                      				autoStart: true,
                                      				moduleWidth: 354,
                                      				moduleHeight: 240,
                                      				remoteSnaps: false,
                                      				stream1: {
                                      					url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                                      					width: undefined,
                                      					height: undefined,
                                      Thanks for your patience!
                                      • evroomE Offline
                                        evroom
                                        What does this say ?
                                        pm2 logs --lines 100
                                        The part where you should see
                                        0|MagicMirror  | Starting stream stream1 with args: [
                                        And
                                        pm2 status
                                        should show
                                        omx_stream1
                                        And can you try it from the command line ?
                                        omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                                        • E Offline
                                          Egnos @evroom
                                          Hi @evroom ,
                                          @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          I never posted this …!
                                          I launched the command on the terminal you recommended but I still don’t see anything, here is the result:
                                          pi@MagicMirror:~ $ omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 354 240" rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                                          Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
                                          Audio codec aac channels 2 samplerate 12000 bitspersample 16
                                          Subtitle count: 0, state: off, index: 1, delay: 0
                                          V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                          And this the log “omxplayer.log”:
                                          omxplayer.log
                                          I paste all the info that the MM prints on the terminal:
                                          > magicmirror@2.10.1 start /home/pi/MagicMirror
                                          > ./run-start.sh
                                          [19:45:33.744] [LOG]    Starting MagicMirror: v2.10.1
                                          [19:45:33.792] [LOG]    Loading config ...
                                          [19:45:33.805] [LOG]    Loading module helpers ...
                                          [19:45:37.253] [LOG]    Initializing new module helper ...
                                          [19:45:37.255] [LOG]    Module helper loaded: MMM-RTSPStream
                                          [19:45:37.256] [LOG]    All module helpers loaded.
                                          [19:45:37.257] [LOG]    Starting server on port 8080 ...
                                          [19:45:37.346] [LOG]    Server started ...
                                          [19:45:37.348] [LOG]    Connecting socket for: MMM-RTSPStream
                                          [19:45:37.350] [LOG]    PM2: Stopping all OMXPlayer Streams...
                                          [19:45:37.352] [LOG]    Sockets connected & modules started ...
                                          [19:45:38.246] [LOG]    Launching application.
                                          [19:45:46.329] [LOG]    Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,238,1138,480 --live --video_queue 4 --fps 30 --no-osd rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
                                          [19:45:46.426] [LOG]    Starting PM2 for omx_stream1
                                          [19:45:53.630] [LOG]    PM2 started for omx_stream1
                                          I don’t understand what’s missing…
                                          • evroomE Offline
                                            evroom
                                            It does look good.
                                            In principle, the line from the pm2 log
                                            should work as standalone.
                                            If it does not play standalone, so from the command line, then it will not work in MMM-RTSPStream.
                                            I would disable the module and make sure nothing is running anymore (no omxplayer stuff).
                                            disabled: true,
                                            pm2 restart mm
                                            pm2 status
                                            Make sure ‘omx_stream1’ is not present.
                                            Stop it when necessary
                                            pm2 stop omx_stream1
                                            pm2 delete omx_stream1
                                            ps -eaf | grep -v grep | grep omxplayer
                                            Kill any omxplayer process (kill -9 ).
                                            Then run omxplayer from command line:
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 30
                                            • 31
                                            • 24 / 31
