Help with MMM-Remote control
12 Posts 4 Posters 3.4k Views 4 Watching
  • N Offline
    nakulbende
    Hello - I am trying to install MMM-remote control to have some control over my raspberry pi. My config file looks like:
    			module: 'MMM-Remote-Control',
    			//position: 'top_bar',
    				        apiKey: "XXXXXXXXXXXXXXX",
    And my header for the config file looks like:
    address: "localhost",
    	port: 8080,
    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.114"],
    I do not get a control page when I go to 192.168.1.15:8080/remote.html (which is my IP for Pi) from my computer (which has .1.14 IP). Is there something I am missing? I have tried this with or without the api key, which I know is optional for basic functionality.
    S 1 Reply Last reply Feb 19, 2020, 2:27 PM Reply Quote 0
    • S Away
      sdetweil @nakulbende
      @nakulbende said in Help with MMM-Remote control:
      address: “localhost”,
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.114”],
      this setup means ONLY apps INSIDE the pi can connect to the MagicMirror app
      so, change it to
      address: "0.0.0.0",
      	port: 8080,
      	ipWhitelist: [],
      that allows ANY system to connect
      • N Offline
        nakulbende
        As always, Sam - thanks so much! I did those changes, and it broke MMM-pi-hole which is stuck on loading. It also crashes magicmirror every 5 minutes or so. This happens even if I just change the address and allowed ip whitelist, comment out remote control and pistats. Any ideas?
        S 1 Reply Last reply Feb 21, 2020, 3:02 PM Reply Quote 0
        • S Away
          @nakulbende have no idea… all that does is say
          listen on all interfaces (ethernet, wireless, maybe pi-hole creates one?, in which case you would need to specifiy the address of the prefered interface, ethernet for example, or wifi… but JUST ONE)
          ipWhitelist:[] means allow anyone to connect on the interface and port
            BKeyport Module Developer
            I’d make Sam’s changes, but change the port number - something else could be grabbing the port for some reason.
            I use 60001.
              Stoffbeuteluwe Project Sponsor
                port: 8080,
                ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:xxxxxxxxxxxxxx", "xxxxxxxxxxxxxx"],
                replace the xxxx with your ip address …thats it
                  you don’t need api key…
                    @nakulbende
                     xxxxxxxxxxxxxx:8080/remote.html
                    ip must be the same like in ip whitelist,
                    it must be the ip of you device you want (tablet or phone ore pc) for controlling your magic mirror
