    Help with MMM-Remote control
    12 Posts 4 Posters 5.9k Views 4 Watching
    • N Offline
      nakulbende
      As always, Sam - thanks so much! I did those changes, and it broke MMM-pi-hole which is stuck on loading. It also crashes magicmirror every 5 minutes or so. This happens even if I just change the address and allowed ip whitelist, comment out remote control and pistats. Any ideas?
        sdetweil @nakulbende
        @nakulbende have no idea… all that does is say
        listen on all interfaces (ethernet, wireless, maybe pi-hole creates one?, in which case you would need to specifiy the address of the prefered interface, ethernet for example, or wifi… but JUST ONE)
        ipWhitelist:[] means allow anyone to connect on the interface and port
        • BKeyportB Offline
          BKeyport Module Developer
          I’d make Sam’s changes, but change the port number - something else could be grabbing the port for some reason.
          I use 60001.
          • StoffbeuteluweS Offline
            Stoffbeuteluwe Project Sponsor
                        module: 'MMM-Remote-Control',
              port: 8080,
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:xxxxxxxxxxxxxx", "xxxxxxxxxxxxxx"],
              replace the xxxx with your ip address …thats it
                you don’t need api key…
                  @nakulbende
                   xxxxxxxxxxxxxx:8080/remote.html
                  ip must be the same like in ip whitelist,
                  it must be the ip of you device you want (tablet or phone ore pc) for controlling your magic mirror
                      address: "0.0.0.0",
                      • N Offline
                        nakulbende
                        Hello all,
                        I changed my port - which seems like it might interfere. So, my config looks like:
                        address : '0.0.0.0',
                        	port: 60001,
                        	ipWhitelist: [],
                        // Remote-Control
                        			//position: 'top_bar',
                        				//showModuleApiMenu: true,
                                //apiKey: "85237761aaf14513a6007e9989a465a3",
                        Here is what the output look like:
                        pi@magicmirror:~/MagicMirror $ npm start
                        > magicmirror@2.10.1 start /home/pi/MagicMirror
                        > ./run-start.sh
                        [11:52:56.840] [LOG]    Starting MagicMirror: v2.10.1
                        [11:52:56.869] [LOG]    Loading config ...
                        [11:52:56.908] [LOG]    Loading module helpers ...
                        [11:52:56.915] [LOG]    No helper found for module: alert.
                        [11:52:57.153] [LOG]    Initializing new module helper ...
                        [11:52:57.156] [LOG]    Module helper loaded: updatenotification
                        [11:52:57.177] [LOG]    Initializing new module helper ...
                        [11:52:57.179] [LOG]    Module helper loaded: MMM-BurnIn
                        [11:52:57.187] [LOG]    Initializing new module helper ...
                        [11:52:57.188] [LOG]    Module helper loaded: MMM-WatchDog
                        [11:52:57.453] [LOG]    Initializing new module helper ...
                        [11:52:57.456] [LOG]    Module helper loaded: MMM-Remote-Control
                        [11:52:57.461] [LOG]    No helper found for module: currentweather.
                        [11:52:57.467] [LOG]    No helper found for module: compliments.
                        [11:52:57.475] [LOG]    No helper found for module: clock.
                        [11:52:57.477] [LOG]    No helper found for module: calendar_monthly.
                        [11:52:59.221] [LOG]    Initializing new module helper ...
                        [11:52:59.223] [LOG]    Module helper loaded: calendar
                        [11:53:05.323] [LOG]    Initializing new module helper ...
                        [11:53:05.325] [LOG]    Module helper loaded: MMM-Buller
                        [11:53:06.691] [LOG]    Initializing new module helper ...
                        [11:53:06.694] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                        [11:53:06.702] [LOG]    No helper found for module: MMM-DailyPokemon.
                        [11:53:06.708] [LOG]    No helper found for module: MMM-MBTA.
                        [11:53:06.714] [LOG]    No helper found for module: MMM-MBTA1.
                        [11:53:06.720] [LOG]    No helper found for module: MMM-MBTA2.
                        [11:53:08.583] [LOG]    Initializing new module helper ...
                        [11:53:08.585] [LOG]    Module helper loaded: MMM-MyCommute
                        [11:53:08.586] [LOG]    No helper found for module: MMM-pihole-stats.
                        [11:53:08.588] [LOG]    All module helpers loaded.
                        [11:53:08.591] [LOG]    Starting server on port 60001 ...
                        [11:53:08.609] [INFO]   You're using a full whitelist configuration to allow for all IPs
                        [11:53:08.624] [LOG]    Server started ...
                        [11:53:08.627] [LOG]    Connecting socket for: updatenotification
                        [11:53:08.630] [LOG]    Connecting socket for: MMM-BurnIn
                        [11:53:08.633] [LOG]    Connecting socket for: MMM-WatchDog
                        [11:53:08.635] [LOG]    Starting module helper: MMM-WatchDog
                        [11:53:08.637] [LOG]    Connecting socket for: MMM-Remote-Control
                        [11:53:08.639] [LOG]    Starting node helper for: MMM-Remote-Control
                        [11:53:08.713] [LOG]    Connecting socket for: calendar
                        [11:53:08.715] [LOG]    Starting node helper for: calendar
                        [11:53:08.717] [LOG]    Connecting socket for: MMM-Buller
                        [11:53:08.721] [LOG]    Connecting socket for: MMM-DarkSkyForecast
                        [11:53:08.722] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                        [11:53:08.724] [LOG]    Connecting socket for: MMM-MyCommute
                        [11:53:08.726] [LOG]    ====================== Starting node_helper for module [MMM-MyCommute]
                        [11:53:08.727] [LOG]    Sockets connected & modules started ...
                        [11:53:09.118] [LOG]    Launching application.
                        [11:53:18.043] [LOG]    WatchDog started. Maximum timeout: 25s.
                        [11:53:18.543] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                        [11:53:18.704] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendarxxxxx
                        [11:53:18.836] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendarxxxxxx
                        [11:53:21.289] [LOG]    Task lists:
                        [11:53:21.293] [LOG]    To read (xxxx)
                        [11:53:21.295] [LOG]    Ideas (xxxxDQzNDow)
                        [11:53:21.296] [LOG]    Life (xxxx)
                        [11:53:21.298] [LOG]    Random thoughts (xxxx)
                        [11:53:21.300] [LOG]    HomeToDo (xxxx)
                        [11:53:21.302] [LOG]    PlantBabies (xxxx)
                        [11:53:21.304] [LOG]    Shopping (xxxx)
                        Pi-hole stats not only fails to load, the whole setup crashes every 2 moinutes or so
                        [17764:0222/114938.526868:FATAL:memory_linux.cc(36)] Out of memory.
