    Hello World modul
    5 Posts 2 Posters 4.6k Views 2 Watching
    • G
      gismo2006
      Hi, a little questions. If I use the config option text: “Hello World” in the Hello World module fpr example. I have the problem the text Hello World will display to big. My question how can i config the hight of this Words? I have try the html parameter but they produce only misstakes. I found out then I write
      between the Word they will past the second word in a new line. Because of that i think maybe html code will work. But no.
      greets gismo
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @gismo2006
        @gismo2006 you could use the predefined classes from main.css like
        text: "<div class='small'>Hello World</div>"
        or
        text: "<div style='font-size: 14px;'>Hello World</div>"
        • G
          gismo2006
          OK, thank you. Dud I understand right? I have to create in my module folder a file called main.css? And there I have to put your code? Is this right? Will it load them alone or have I to put some code in my *.js file to? Sorry, but I never worked whit css :-)
          Greets gismo
          • strawberry 3.141S
            @gismo2006 you mentioned that you want to put this in the helloworld module, so my example should go into the config
                module: "helloworld",
                position: "bottom_bar",
            • G
              gismo2006
              Oh OK sorry I I haven’t understand you right. It was my mistake. I will try your post tonight. Thank you again
              Greets gismo
