Hello World modul
5 Posts 2 Posters 3.8k Views 2 Watching
  • G Offline
    gismo2006
    Hi, a little questions. If I use the config option text: “Hello World” in the Hello World module fpr example. I have the problem the text Hello World will display to big. My question how can i config the hight of this Words? I have try the html parameter but they produce only misstakes. I found out then I write
    between the Word they will past the second word in a new line. Because of that i think maybe html code will work. But no.
    greets gismo
    S 1 Reply Last reply Oct 27, 2016, 10:23 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @gismo2006
      @gismo2006 you could use the predefined classes from main.css like
      text: "<div class='small'>Hello World</div>"
      or
      text: "<div style='font-size: 14px;'>Hello World</div>"
      • G Offline
        gismo2006
        OK, thank you. Dud I understand right? I have to create in my module folder a file called main.css? And there I have to put your code? Is this right? Will it load them alone or have I to put some code in my *.js file to? Sorry, but I never worked whit css :-)
        Greets gismo
        S 1 Reply Last reply Oct 28, 2016, 3:04 PM Reply Quote 0
          @gismo2006 you mentioned that you want to put this in the helloworld module, so my example should go into the config
              module: "helloworld",
              position: "bottom_bar",
          • G Offline
            gismo2006
            Oh OK sorry I I haven’t understand you right. It was my mistake. I will try your post tonight. Thank you again
            Greets gismo
