    MMM-soccer v2
    52 Posts 9 Posters 36.9k Views 9 Watching
      chassain 0 @lavolp3
      @lavolp3
      better but still…
      npm WARN Invalid name: "mmm-soccer v2"
      npm WARN MMM-soccer No description
      npm WARN MMM-soccer No repository field.
      npm WARN MMM-soccer No README data
      npm WARN MMM-soccer No license field.
      added 8 packages from 1 contributor in 4.453s
      found 0 vulnerabilities
      C 1 Reply Last reply
        chassain 0 @chassain 0
        @chassain-0
        name changed in package.json and it’s ok
        lavolp3L 1 Reply Last reply
        • lavolp3L
          lavolp3 Module Developer @chassain 0
          @chassain-0 yeah has also been changed in origin/master now.
          Recognized this as well.
          Sorry for the hickups and looking forward to any comments.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          C 2 Replies Last reply
            chassain 0 @lavolp3
            @lavolp3 thanks to you. I m going to try now
              chassain 0 @lavolp3
              @lavolp3 Nice job…:)
              • lavolp3L
                Node_helper.js needed to be fixed.
                Please do a git pull and restart the mirror if you experience problems.
                StoffbeuteluweS 1 Reply Last reply
                  chassain 0
                  i understand live is ok now with api calls ? i like it
                  • lavolp3L
                    @chassain-0 It should but as I see it doesn’t seem to work. Will check tonight or tomorrow.
                    • StoffbeuteluweS
                      Stoffbeuteluwe Project Sponsor @lavolp3
                      @lavolp3 Hi, does the module work?
                      do I need a api ?
                      Thanks in advance…
                      greetings from Germany
                      • lavolp3L
                        lavolp3 Module Developer @Stoffbeuteluwe
                        @Stoffbeuteluwe HI,
                        live mode seems broken, will fix it tomorrow, but apart from that it works, yes.
                        You need a free api key from football-data.org.
                        Try it out and let me know if you find any problems.
                        • StoffbeuteluweS
                          @lavolp3 Hi, do i have to use the API out of the Email and that’s it?..or do I have to do something else with the API?
                          Thanks in advance
                          • lavolp3L
                            @Stoffbeuteluwe Yes use the key that you have received and put it in your config and that’s it.
                            • StoffbeuteluweS
                              @lavolp3 thank you
                                dirk-graetz
                                Hi lavolp3,
                                your module is crashing if showMatches = false
                                kind regards
                                • lavolp3L
                                  lavolp3 Module Developer @dirk-graetz
                                  @dirk-graetz thanks! Will have a look into it. Have to admit that I am not good in debugging my modules.
                                  • N
                                    Nero
                                    Does this show the Championship, Leagues 1 and 2 in England? Thanks
                                    • lavolp3L
                                      lavolp3 Module Developer @Nero
                                      @Nero No, only Premier League for England.
                                      M 1 Reply Last reply
                                        matze86 @lavolp3
                                        Hey @lavolp3
                                        I want to show the next matches of my team and this doesn’t work.
                                        If I change ‘league’ to ‘next’ (or ‘daily’) the screen displays only the header of the league table ("teams, games & goal difference).
                                        focus_on in combination with " matchtype: ‘league’ " works. My team is highlighted. (see the first config):
                                            module: 'MMM-soccer',
                                            position: 'top_right',
                                               api_key: 'my api',
                                               show: ['BL1'],
                                               colored: true,
                                               focus_on: {
                                        	     'BL1': 'FC Bayern München',
                                               matchType: 'league'
                                        here is my “next” config of this module, which doesn’t work.
                                               api_key: 'my api',
                                               show: ['BL1'],
                                               colored: true,
                                               focus_on: {
                                               matchType: 'next',
                                               numberOfNextMatches: 5
                                        lavolp3L 2 Replies Last reply
                                        • lavolp3L
                                          lavolp3 Module Developer @matze86
                                          @matze86 The setup works for me and shows me the next 5 matches of Bayern München.
                                          It actually also shows the last match so I might have to check that.
                                          • lavolp3L
                                            @matze86 CAn you open the magicmirror page in your browser and check the developer’s tools (f12 --> console) for any errors?
                                            You might also activate debug mode in your config (debug: true) to get more output from the module.
                                            M 2 Replies Last reply
