    MM on NanopiM4 using Lubuntu...
    21 Posts 3 Posters 4.7k Views 3 Watching
      A Former User @banbutcher
      @banbutcher
      Electron is not installed? What kind of OS are you using? Almost all Debian clones could handle MM. The possible issue might be about GPU driver.
        @banbutcher
        And you can launch Chrom(Chromium) with kiosk fullscreen mode on startup of MagicMirror. It could be alternative solution.
          banbutcher
          im using Lubuntu… not sure about electron, have only come across it when installing hotword and MK2assistant.
          not sure how to launch with kiosk fullscreen mode
          ? 1 Reply Last reply
            @banbutcher
            Hmmm.
            First, Could your default pure MM(without hotword and AMK2) be executed standalone?
            Second, if so, you mean when it would be issued only with Hotword and AMK2? (But in browser, both modules work?)
            Third, if so, It means your Hotword and AMK2 might have missed or failed on electron-rebuild step.
              banbutcher
              it is a complete fresh install, ran this from link above.
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                @banbutcher
                So pure MM also cannot be executable standalone?
                  banbutcher
                  with pm2 stopped, when i type npm start nothin happens untill i manually open chrome and goto localhost
                    sdetweil @banbutcher
                    @banbutcher this means u are starting in server only mode.
                    Can u tell me more?
                    execute
                    bash -x ./run-start.sh
                    And then post the output. (maybe 15 lines)
                    Usually this is because it cannot find xwindows running
                    I made all the changes to run-start
                    on my machine, the output looks like this
                    + '[' -f ./untrack-css.sh ']'
                    + ./untrack-css.sh
                    + grep docker /proc/1/cgroup -qa
                    + '[' -z :0.0 ']'
                    ++ uname -m
                    + arch=x86_64
                    + false=false
                    ++ grep -v '^[[:blank:]]*//' config/config.js
                    ++ awk '{print tolower($2)}'
                    ++ tr -d ',"'\''\r'
                    ++ grep -i serveronly:
                    + serveronly=
                    + serveronly=false
                    ++ pgrep Xorg
                    + xorg=621
                    ++ uname
                    + mac=Linux
                    + '[' false. '!=' false. -o x86_64 == armv6l ']'
                    + '[' 621. == . -a Linux '!=' Darwin ']'
                    + node_modules/.bin/electron js/electron.js
                    B 1 Reply Last reply
                      banbutcher @sdetweil
                      ~/MagicMirror$ bash -x ./run-start.sh
                      + ./untrack-css.sh
                      + '[' -z :0.0 ']'
                      ++ uname -m
                      + arch=aarch64
                      + false=false
                      ++ tr -d ',"'\''\r'
                      + serveronly=
                      + serveronly=false
                      ++ pgrep Xorg
                      + xorg=
                      ++ uname
                      + mac=Linux
                      + '[' false. '!=' false. -o aarch64 == armv6l ']'
                      + '[' . == . -a Linux '!=' Darwin ']'
                      + '[' false. == true. ']'
                      + node serveronly
                      seems to show serveronly to be false?
                        @banbutcher this says xwindows not running( ie text console mode)
                         pgrep Xorg
                        + xorg=
                        Can u do
                        ps -ef
                        So I can fix the script…
                        And also
                        lsb_release -a
                          banbutcher
                          result of ps -ef:
                          UID        PID  PPID  C STIME TTY          TIME CMD
                          root         1     0  0 11:16 ?        00:00:07 /sbin/init
                          root         2     0  0 11:16 ?        00:00:00 [kthreadd]
                          root         3     2  0 11:16 ?        00:00:00 [ksoftirqd/0]
                          root         4     2  0 11:16 ?        00:00:00 [kworker/0:0]
                          root         5     2  0 11:16 ?        00:00:00 [kworker/0:0H]
                          root         7     2  0 11:16 ?        00:00:11 [rcu_sched]
                          root         8     2  0 11:16 ?        00:00:00 [rcu_bh]
                          root         9     2  0 11:16 ?        00:00:00 [migration/0]
                          root        10     2  0 11:16 ?        00:00:00 [watchdog/0]
                          root        11     2  0 11:16 ?        00:00:00 [watchdog/1]
                          root        12     2  0 11:16 ?        00:00:00 [migration/1]
                          root        13     2  0 11:16 ?        00:00:00 [ksoftirqd/1]
                          root        15     2  0 11:16 ?        00:00:00 [kworker/1:0H]
                          root        16     2  0 11:16 ?        00:00:00 [watchdog/2]
                          root        17     2  0 11:16 ?        00:00:00 [migration/2]
                          root        18     2  0 11:16 ?        00:00:00 [ksoftirqd/2]
                          root        20     2  0 11:16 ?        00:00:00 [kworker/2:0H]
                          root        21     2  0 11:16 ?        00:00:00 [watchdog/3]
                          root        22     2  0 11:16 ?        00:00:00 [migration/3]
                          root        23     2  0 11:16 ?        00:00:00 [ksoftirqd/3]
                          root        25     2  0 11:16 ?        00:00:00 [kworker/3:0H]
                          root        26     2  0 11:16 ?        00:00:00 [watchdog/4]
                          root        27     2  0 11:16 ?        00:00:00 [migration/4]
                          root        28     2  0 11:16 ?        00:00:00 [ksoftirqd/4]
                          root        30     2  0 11:16 ?        00:00:00 [kworker/4:0H]
                          root        31     2  0 11:16 ?        00:00:00 [watchdog/5]
                          root        32     2  0 11:16 ?        00:00:00 [migration/5]
                          root        33     2  0 11:16 ?        00:00:00 [ksoftirqd/5]
                          root        35     2  0 11:16 ?        00:00:00 [kworker/5:0H]
                          root        36     2  0 11:16 ?        00:00:00 [kdevtmpfs]
                          root        37     2  0 11:16 ?        00:00:00 [netns]
                          root        38     2  0 11:16 ?        00:00:00 [perf]
                          root        39     2  0 11:16 ?        00:00:00 [khungtaskd]
                          root        40     2  0 11:16 ?        00:00:00 [writeback]
                          root        41     2  0 11:16 ?        00:00:00 [khugepaged]
                          root        42     2  0 11:16 ?        00:00:00 [crypto]
                          root        43     2  0 11:16 ?        00:00:00 [bioset]
                          root        44     2  0 11:16 ?        00:00:00 [kblockd]
                          root        46     2  0 11:16 ?        00:00:00 [ata_sff]
                          root        47     2  0 11:16 ?        00:00:00 [devfreq_wq]
                          root        48     2  0 11:16 ?        00:00:00 [cfg80211]
                          root        49     2  0 11:16 ?        00:00:06 [cfinteractive]
                          root        51     2  0 11:16 ?        00:00:00 [rpciod]
                          root        66     2  0 11:16 ?        00:00:00 [kswapd0]
                          root        67     2  0 11:16 ?        00:00:00 [vmstat]
                          root        68     2  0 11:16 ?        00:00:00 [fsnotify_mark]
                          root        69     2  0 11:16 ?        00:00:00 [SquashFS read w]
                          root        70     2  0 11:16 ?        00:00:00 [nfsiod]
                          root       115     2  0 11:16 ?        00:00:00 [kthrotld]
                          root       116     2  0 11:16 ?        00:00:00 [irq/231-rockchi]
                          root       117     2  0 11:16 ?        00:00:00 [vcodec]
                          root       118     2  0 11:16 ?        00:00:00 [irq/47-ff650000]
                          root       119     2  0 11:16 ?        00:00:00 [irq/46-ff650000]
                          root       121     2  0 11:16 ?        00:00:00 [vcodec]
                          root       122     2  0 11:16 ?        00:00:00 [irq/49-ff660000]
                          root       123     2  0 11:16 ?        00:00:00 [kworker/1:1]
                          root       124     2  0 11:16 ?        00:00:00 [bioset]
                          root       125     2  0 11:16 ?        00:00:00 [bioset]
                          root       126     2  0 11:16 ?        00:00:00 [bioset]
                          root       127     2  0 11:16 ?        00:00:00 [bioset]
                          root       128     2  0 11:16 ?        00:00:00 [bioset]
                          root       129     2  0 11:16 ?        00:00:00 [bioset]
                          root       130     2  0 11:16 ?        00:00:00 [bioset]
                          root       131     2  0 11:16 ?        00:00:00 [bioset]
                          root       132     2  0 11:16 ?        00:00:00 [bioset]
                          root       133     2  0 11:16 ?        00:00:00 [bioset]
                          root       134     2  0 11:16 ?        00:00:00 [bioset]
                          root       135     2  0 11:16 ?        00:00:00 [bioset]
                          root       136     2  0 11:16 ?        00:00:00 [bioset]
                          root       137     2  0 11:16 ?        00:00:00 [bioset]
                          root       138     2  0 11:16 ?        00:00:00 [bioset]
                          root       139     2  0 11:16 ?        00:00:00 [bioset]
                          root       140     2  0 11:16 ?        00:00:00 [bioset]
                          root       141     2  0 11:16 ?        00:00:00 [memory_wq]
                          root       142     2  0 11:16 ?        00:00:00 [nvme]
                          root       145     2  0 11:16 ?        00:00:00 [kworker/2:1]
                          root       146     2  0 11:16 ?        00:00:00 [kworker/5:1]
                          root       147     2  0 11:16 ?        00:00:00 [goodix_wq]
                          root       148     2  0 11:16 ?        00:00:00 [irq/123-rk808]
                          root       149     2  0 11:16 ?        00:00:00 [fusb302_wq]
                          root       150     2  0 11:16 ?        00:00:00 [irq/104-fusb302]
                          root       151     2  0 11:16 ?        00:00:00 [irq/39-rockchip]
                          root       152     2  0 11:16 ?        00:00:00 [dm_bufio_cache]
                          root       154     2  0 11:16 ?        00:00:00 [irq/27-mmc1]
                          root       156     2  0 11:16 ?        00:00:00 [ipv6_addrconf]
                          root       157     2  0 11:16 ?        00:00:00 [krfcommd]
                          root       159     2  0 11:16 ?        00:00:00 [deferwq]
                          root       160     2  0 11:16 ?        00:00:00 [irq/243-rockchi]
                          root       161     2  0 11:16 ?        00:00:00 [irq/244-rockchi]
                          root       162     2  0 11:16 ?        00:00:00 [irq/245-rockchi]
                          root       163     2  0 11:16 ?        00:00:00 [irq/64-analogix]
                          root       164     2  0 11:16 ?        00:00:00 [hpd_queue]
                          root       165     2  0 11:16 ?        00:00:00 [irq/63-ff940000]
                          root       169     2  0 11:16 ?        00:00:00 [gpu_power_off_w]
                          root       172     2  0 11:16 ?        00:00:00 [kbase_job_fault]
                          root       174     2  0 11:16 ?        00:00:00 [bioset]
                          root       175     2  0 11:16 ?        00:00:16 [mmcqd/0]
                          root       176     2  0 11:16 ?        00:00:00 [kworker/3:1]
                          root       228     2  0 11:16 ?        00:00:00 [kworker/4:1H]
                          root       243     2  0 11:16 ?        00:00:00 [jbd2/mmcblk0p1-]
                          root       244     2  0 11:16 ?        00:00:00 [ext4-rsv-conver]
                          root       266     2  0 11:16 ?        00:00:00 [jbd2/mmcblk0p2-]
                          root       267     2  0 11:16 ?        00:00:00 [ext4-rsv-conver]
                          root       294     2  0 11:16 ?        00:00:00 [kauditd]
                          root       303     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-journald
                          root       331     2  0 11:16 ?        00:00:00 [kworker/4:2]
                          root       355     2  0 11:16 ?        00:00:00 [kworker/2:1H]
                          root       369     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-udevd
                          root       387     2  0 11:16 ?        00:00:00 [kworker/3:2]
                          root       463     1  0 11:16 ?        00:00:00 /usr/lib/accountsservice/account
                          gpsd       467     1  0 11:16 ?        00:00:00 /usr/sbin/gpsd -N
                          syslog     469     1  0 11:16 ?        00:00:00 /usr/sbin/rsyslogd -n
                          avahi      485     1  0 11:16 ?        00:00:02 avahi-daemon: running [FriendlyE
                          message+   515     1  0 11:16 ?        00:00:06 /usr/bin/dbus-daemon --system --
                          avahi      541   485  0 11:16 ?        00:00:00 avahi-daemon: chroot helper
                          root       573     2  0 11:16 ?        00:00:00 [kworker/5:1H]
                          root       636     1  0 11:16 ?        00:00:08 /usr/sbin/NetworkManager --no-da
                          root       659     1  0 11:16 ?        00:00:00 /usr/sbin/cups-browsed
                          root       668     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-logind
                          root       690     1  0 11:16 ?        00:00:00 /usr/sbin/cron -f
                          root       705     2  0 11:16 ?        00:00:00 [wl_escan_handle]
                          root       706     2  0 11:16 ?        00:00:01 [dhd_watchdog_th]
                          root       709     2  0 11:16 ?        00:00:02 [dhd_dpc]
                          root       710     2  0 11:16 ?        00:00:00 [dhd_rxf]
                          root       770     1  0 11:16 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
                          root       795     1  0 11:16 ?        00:00:00 /usr/sbin/lightdm
                          dnsmasq    815     1  0 11:16 ?        00:00:00 /usr/sbin/dnsmasq -x /var/run/dn
                          root       863     2  0 11:16 ?        00:00:00 [kworker/3:1H]
                          root       894   795  3 11:16 tty7     00:04:40 /usr/bin/X -core :0 -seat seat0
                          root       997     2  0 11:16 ?        00:00:00 [kbase_event]
                          root      1007     2  0 11:16 ?        00:00:00 [dhd_eventd]
                          root      1008     2  0 11:16 ?        00:00:00 [kworker/1:1H]
                          root      1010     1  0 11:16 ?        00:00:01 /sbin/wpa_supplicant -u -s -O /r
                          root      1026   795  0 11:16 ?        00:00:00 lightdm --session-child 12 15
                          pi        1032     1  0 11:16 ?        00:00:00 /lib/systemd/systemd --user
                          pi        1035  1032  0 11:16 ?        00:00:00 (sd-pam)
                          pi        1038  1026  0 11:16 ?        00:00:00 /sbin/upstart --user
                          pi        1098  1038  0 11:16 ?        00:00:00 upstart-udev-bridge --daemon --u
                          pi        1101  1038  0 11:16 ?        00:00:00 dbus-daemon --fork --session --a
                          pi        1136  1038  0 11:16 ?        00:00:00 gnome-keyring-daemon --start --c
                          pi        1149  1038  0 11:16 ?        00:00:00 upstart-dbus-bridge --daemon --s
                          pi        1153  1038  0 11:16 ?        00:00:00 upstart-file-bridge --daemon --u
                          pi        1155  1038  0 11:16 ?        00:00:00 upstart-dbus-bridge --daemon --s
                          pi        1165  1038  0 11:16 ?        00:00:00 gpg-agent --homedir /home/pi/.gn
                          pi        1182  1038  0 11:16 ?        00:00:00 /usr/bin/lxsession -s Lubuntu -e
                          pi        1187  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd
                          pi        1192  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/us
                          root      1200     2  0 11:16 ?        00:00:00 [kworker/0:1H]
                          pi        1204  1182  0 11:16 ?        00:00:01 openbox --config-file /home/pi/.
                          pi        1207  1182  0 11:16 ?        00:00:34 lxpanel --profile Lubuntu
                          pi        1209  1182  0 11:16 ?        00:00:04 pcmanfm --desktop --profile lubu
                          pi        1215  1038  0 11:16 ?        00:00:00 /usr/bin/ssh-agent -s
                          pi        1224  1038  0 11:16 ?        00:00:08 nm-applet
                          pi        1237  1038  0 11:16 ?        00:00:00 xfce4-power-manager
                          pi        1245  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/xfc
                          pi        1249  1038  0 11:16 ?        00:00:01 /usr/bin/pulseaudio --start --lo
                          rtkit     1250     1  0 11:16 ?        00:00:00 /usr/lib/rtkit/rtkit-daemon
                          root      1259     1  0 11:16 ?        00:00:00 /usr/lib/upower/upowerd
                          pi        1270  1038  0 11:16 ?        00:00:00 /usr/lib/menu-cache/menu-cached
                          pi        1291  1038  0 11:16 ?        00:00:00 /usr/lib/at-spi2-core/at-spi-bus
                          pi        1300  1291  0 11:16 ?        00:00:00 /usr/bin/dbus-daemon --config-fi
                          pi        1305  1038  0 11:16 ?        00:00:00 /usr/lib/at-spi2-core/at-spi2-re
                          pi        1318  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-udisks2-volum
                          root      1321     1  0 11:16 ?        00:00:00 /usr/lib/udisks2/udisksd --no-de
                          pi        1348  1038  0 11:16 ?        00:00:00 /usr/lib/indicator-sound-gtk2/in
                          pi        1349  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/ind
                          root      1411     1  0 11:16 ?        00:00:00 /sbin/dhclient -1 -v -pf /run/dh
                          pi        1412  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-mo
                          pi        1442  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volum
                          pi        1497  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-goa-volume-mo
                          pi        1526  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-afc-volume-mo
                          root      1530     1  0 11:16 ?        00:00:00 /usr/bin/python3 /usr/share/unat
                          root      1545     1  0 11:16 ?        00:00:00 /usr/sbin/sshd -D
                          pi        1555  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd-trash --spaw
                          whoopsie  1568     1  0 11:16 ?        00:00:00 /usr/bin/whoopsie -f
                          root      1597     2  0 11:16 ?        00:00:00 [hci0]
                          root      1598     2  0 11:16 ?        00:00:00 [hci0]
                          root      1599     1  0 11:16 ?        00:00:00 /usr/bin/hciattach /dev/ttyS0 bc
                          root      1606     1  0 11:16 ?        00:00:12 /bin/bash /usr/bin/start-rk3399-
                          root      1611     1  0 11:16 ttyFIQ0  00:00:00 /sbin/agetty --keep-baud 115200
                          root      1612     1  0 11:16 tty1     00:00:00 /sbin/agetty --noclear tty1 linu
                          root      1616     1  0 11:16 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
                          pi        1622     1  0 11:16 ?        00:00:02 PM2 v4.2.3: God Daemon (/home/pi
                          pi        1693  1038  0 11:16 ?        00:00:05 /usr/bin/python /usr/bin/x-termi
                          ntp       1700     1  0 11:16 ?        00:00:02 /usr/sbin/ntpd -p /var/run/ntpd.
                          pi        1747  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/gco
                          pi        1752  1693  0 11:16 ?        00:00:00 gnome-pty-helper
                          pi        1753  1693  0 11:16 pts/1    00:00:00 /bin/bash
                          pi        2623  1207  1 11:18 ?        00:02:03 /usr/lib/chromium-browser/chromi
                          pi        2637  2623  0 11:18 ?        00:00:00 /usr/lib/chromium-browser/chromi
                          pi        2639  2637  0 11:18 ?        00:00:00 /usr/lib/chromium-browser/chromi
                          pi        2660  2623  3 11:18 ?        00:04:22 /usr/lib/chromium-browser/chromi
                          pi        2664  2623  0 11:18 ?        00:00:20 /usr/lib/chromium-browser/chromi
                          root      2671     2  0 11:18 ?        00:00:00 [kbase_event]
                          pi        2714  2639  0 11:18 ?        00:00:06 /usr/lib/chromium-browser/chromi
                          pi        2760  2639  0 11:18 ?        00:00:17 /usr/lib/chromium-browser/chromi
                          pi        3054  2639  1 11:18 ?        00:02:10 /usr/lib/chromium-browser/chromi
                          root      3587     1  0 11:21 ?        00:00:00 /usr/sbin/cupsd -l
                          root      4334     2  0 11:28 ?        00:00:00 [kworker/5:2]
                          root      4498     2  0 11:28 ?        00:00:07 [kworker/1:0]
                          pi        4562  1038  0 11:29 ?        00:00:01 /usr/bin/python /usr/bin/x-termi
                          pi        4572  4562  0 11:29 ?        00:00:00 gnome-pty-helper
                          pi        4573  4562  0 11:29 pts/2    00:00:00 /bin/bash
                          pi        4792  1209  0 11:31 ?        00:00:03 leafpad /home/pi/MagicMirror/con
                          pi        5864  2639  1 11:44 ?        00:01:25 /usr/lib/chromium-browser/chromi
                          pi        5927  2639  0 11:44 ?        00:00:00 /usr/lib/chromium-browser/chromi
                          root      6603     2  0 11:51 ?        00:00:00 [kworker/2:2]
                          root      7776     2  0 12:07 ?        00:00:00 [kworker/4:1]
                          root      8056     2  0 12:11 ?        00:00:03 [kworker/u12:2]
                          root     10915     2  0 12:49 ?        00:00:04 [kworker/0:2]
                          root     12454     2  0 13:11 ?        00:00:00 [kworker/u13:0]
                          root     12691     2  0 13:15 ?        00:00:00 [kworker/u12:0]
                          root     12846     2  0 13:17 ?        00:00:00 [kworker/u13:2]
                          root     13049     2  0 13:20 ?        00:00:00 [kworker/u12:1]
                          root     13163     2  0 13:21 ?        00:00:00 [kworker/0:1]
                          root     13231     2  0 13:22 ?        00:00:00 [kworker/u13:1]
                          root     13260  1606  0 13:22 ?        00:00:00 sleep 2s
                          pi       13261  1753  0 13:22 pts/1    00:00:00 ps -ef
                          pi@FriendlyELEC:~/MagicMirror$
                          and result of lsb-release-a :
                          pi@FriendlyELEC:~/MagicMirror$ lsb_release -a
                          No LSB modules are available.
                          Distributor ID:	Ubuntu
                          Description:	Ubuntu 16.04.6 LTS
                          Release:	16.04
                          Codename:	xenia
                          thanks
                            @banbutcher cool.
                            Can u try pgrep X
                                @banbutcher cool. Edit the run-start.sh and change
                                pgrep Xorg
                                To
                                pgrep X
                                Until I can make the right change
                                Thank you for your help
                                  banbutcher
                                  Perfect, thanks a lot for your help!
                                    @banbutcher I have updated the run-start.sh script… if you would like the latest copy do
                                    curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh > run-start.sh
