    MM on NanopiM4 using Lubuntu...
    21 Posts 3 Posters 4.7k Views 3 Watching
      banbutcher
      with pm2 stopped, when i type npm start nothin happens untill i manually open chrome and goto localhost
        sdetweil @banbutcher
        @banbutcher this means u are starting in server only mode.
        Can u tell me more?
        execute
        bash -x ./run-start.sh
        And then post the output. (maybe 15 lines)
        Usually this is because it cannot find xwindows running
        I made all the changes to run-start
        on my machine, the output looks like this
        + '[' -f ./untrack-css.sh ']'
        + ./untrack-css.sh
        + grep docker /proc/1/cgroup -qa
        + '[' -z :0.0 ']'
        ++ uname -m
        + arch=x86_64
        + false=false
        ++ grep -v '^[[:blank:]]*//' config/config.js
        ++ awk '{print tolower($2)}'
        ++ tr -d ',"'\''\r'
        ++ grep -i serveronly:
        + serveronly=
        + serveronly=false
        ++ pgrep Xorg
        + xorg=621
        ++ uname
        + mac=Linux
        + '[' false. '!=' false. -o x86_64 == armv6l ']'
        + '[' 621. == . -a Linux '!=' Darwin ']'
        + node_modules/.bin/electron js/electron.js
        B 1 Reply Last reply
          banbutcher @sdetweil
          ~/MagicMirror$ bash -x ./run-start.sh
          + ./untrack-css.sh
          + '[' -z :0.0 ']'
          ++ uname -m
          + arch=aarch64
          + false=false
          ++ tr -d ',"'\''\r'
          + serveronly=
          + serveronly=false
          ++ pgrep Xorg
          + xorg=
          ++ uname
          + mac=Linux
          + '[' false. '!=' false. -o aarch64 == armv6l ']'
          + '[' . == . -a Linux '!=' Darwin ']'
          + '[' false. == true. ']'
          + node serveronly
          seems to show serveronly to be false?
            @banbutcher this says xwindows not running( ie text console mode)
             pgrep Xorg
            + xorg=
            Can u do
            ps -ef
            So I can fix the script…
            And also
            lsb_release -a
              banbutcher
              result of ps -ef:
              UID        PID  PPID  C STIME TTY          TIME CMD
              root         1     0  0 11:16 ?        00:00:07 /sbin/init
              root         2     0  0 11:16 ?        00:00:00 [kthreadd]
              root         3     2  0 11:16 ?        00:00:00 [ksoftirqd/0]
              root         4     2  0 11:16 ?        00:00:00 [kworker/0:0]
              root         5     2  0 11:16 ?        00:00:00 [kworker/0:0H]
              root         7     2  0 11:16 ?        00:00:11 [rcu_sched]
              root         8     2  0 11:16 ?        00:00:00 [rcu_bh]
              root         9     2  0 11:16 ?        00:00:00 [migration/0]
              root        10     2  0 11:16 ?        00:00:00 [watchdog/0]
              root        11     2  0 11:16 ?        00:00:00 [watchdog/1]
              root        12     2  0 11:16 ?        00:00:00 [migration/1]
              root        13     2  0 11:16 ?        00:00:00 [ksoftirqd/1]
              root        15     2  0 11:16 ?        00:00:00 [kworker/1:0H]
              root        16     2  0 11:16 ?        00:00:00 [watchdog/2]
              root        17     2  0 11:16 ?        00:00:00 [migration/2]
              root        18     2  0 11:16 ?        00:00:00 [ksoftirqd/2]
              root        20     2  0 11:16 ?        00:00:00 [kworker/2:0H]
              root        21     2  0 11:16 ?        00:00:00 [watchdog/3]
              root        22     2  0 11:16 ?        00:00:00 [migration/3]
              root        23     2  0 11:16 ?        00:00:00 [ksoftirqd/3]
              root        25     2  0 11:16 ?        00:00:00 [kworker/3:0H]
              root        26     2  0 11:16 ?        00:00:00 [watchdog/4]
              root        27     2  0 11:16 ?        00:00:00 [migration/4]
              root        28     2  0 11:16 ?        00:00:00 [ksoftirqd/4]
              root        30     2  0 11:16 ?        00:00:00 [kworker/4:0H]
              root        31     2  0 11:16 ?        00:00:00 [watchdog/5]
              root        32     2  0 11:16 ?        00:00:00 [migration/5]
              root        33     2  0 11:16 ?        00:00:00 [ksoftirqd/5]
              root        35     2  0 11:16 ?        00:00:00 [kworker/5:0H]
              root        36     2  0 11:16 ?        00:00:00 [kdevtmpfs]
              root        37     2  0 11:16 ?        00:00:00 [netns]
              root        38     2  0 11:16 ?        00:00:00 [perf]
              root        39     2  0 11:16 ?        00:00:00 [khungtaskd]
              root        40     2  0 11:16 ?        00:00:00 [writeback]
              root        41     2  0 11:16 ?        00:00:00 [khugepaged]
              root        42     2  0 11:16 ?        00:00:00 [crypto]
              root        43     2  0 11:16 ?        00:00:00 [bioset]
              root        44     2  0 11:16 ?        00:00:00 [kblockd]
              root        46     2  0 11:16 ?        00:00:00 [ata_sff]
              root        47     2  0 11:16 ?        00:00:00 [devfreq_wq]
              root        48     2  0 11:16 ?        00:00:00 [cfg80211]
              root        49     2  0 11:16 ?        00:00:06 [cfinteractive]
              root        51     2  0 11:16 ?        00:00:00 [rpciod]
              root        66     2  0 11:16 ?        00:00:00 [kswapd0]
              root        67     2  0 11:16 ?        00:00:00 [vmstat]
              root        68     2  0 11:16 ?        00:00:00 [fsnotify_mark]
              root        69     2  0 11:16 ?        00:00:00 [SquashFS read w]
              root        70     2  0 11:16 ?        00:00:00 [nfsiod]
              root       115     2  0 11:16 ?        00:00:00 [kthrotld]
              root       116     2  0 11:16 ?        00:00:00 [irq/231-rockchi]
              root       117     2  0 11:16 ?        00:00:00 [vcodec]
              root       118     2  0 11:16 ?        00:00:00 [irq/47-ff650000]
              root       119     2  0 11:16 ?        00:00:00 [irq/46-ff650000]
              root       121     2  0 11:16 ?        00:00:00 [vcodec]
              root       122     2  0 11:16 ?        00:00:00 [irq/49-ff660000]
              root       123     2  0 11:16 ?        00:00:00 [kworker/1:1]
              root       124     2  0 11:16 ?        00:00:00 [bioset]
              root       125     2  0 11:16 ?        00:00:00 [bioset]
              root       126     2  0 11:16 ?        00:00:00 [bioset]
              root       127     2  0 11:16 ?        00:00:00 [bioset]
              root       128     2  0 11:16 ?        00:00:00 [bioset]
              root       129     2  0 11:16 ?        00:00:00 [bioset]
              root       130     2  0 11:16 ?        00:00:00 [bioset]
              root       131     2  0 11:16 ?        00:00:00 [bioset]
              root       132     2  0 11:16 ?        00:00:00 [bioset]
              root       133     2  0 11:16 ?        00:00:00 [bioset]
              root       134     2  0 11:16 ?        00:00:00 [bioset]
              root       135     2  0 11:16 ?        00:00:00 [bioset]
              root       136     2  0 11:16 ?        00:00:00 [bioset]
              root       137     2  0 11:16 ?        00:00:00 [bioset]
              root       138     2  0 11:16 ?        00:00:00 [bioset]
              root       139     2  0 11:16 ?        00:00:00 [bioset]
              root       140     2  0 11:16 ?        00:00:00 [bioset]
              root       141     2  0 11:16 ?        00:00:00 [memory_wq]
              root       142     2  0 11:16 ?        00:00:00 [nvme]
              root       145     2  0 11:16 ?        00:00:00 [kworker/2:1]
              root       146     2  0 11:16 ?        00:00:00 [kworker/5:1]
              root       147     2  0 11:16 ?        00:00:00 [goodix_wq]
              root       148     2  0 11:16 ?        00:00:00 [irq/123-rk808]
              root       149     2  0 11:16 ?        00:00:00 [fusb302_wq]
              root       150     2  0 11:16 ?        00:00:00 [irq/104-fusb302]
              root       151     2  0 11:16 ?        00:00:00 [irq/39-rockchip]
              root       152     2  0 11:16 ?        00:00:00 [dm_bufio_cache]
              root       154     2  0 11:16 ?        00:00:00 [irq/27-mmc1]
              root       156     2  0 11:16 ?        00:00:00 [ipv6_addrconf]
              root       157     2  0 11:16 ?        00:00:00 [krfcommd]
              root       159     2  0 11:16 ?        00:00:00 [deferwq]
              root       160     2  0 11:16 ?        00:00:00 [irq/243-rockchi]
              root       161     2  0 11:16 ?        00:00:00 [irq/244-rockchi]
              root       162     2  0 11:16 ?        00:00:00 [irq/245-rockchi]
              root       163     2  0 11:16 ?        00:00:00 [irq/64-analogix]
              root       164     2  0 11:16 ?        00:00:00 [hpd_queue]
              root       165     2  0 11:16 ?        00:00:00 [irq/63-ff940000]
              root       169     2  0 11:16 ?        00:00:00 [gpu_power_off_w]
              root       172     2  0 11:16 ?        00:00:00 [kbase_job_fault]
              root       174     2  0 11:16 ?        00:00:00 [bioset]
              root       175     2  0 11:16 ?        00:00:16 [mmcqd/0]
              root       176     2  0 11:16 ?        00:00:00 [kworker/3:1]
              root       228     2  0 11:16 ?        00:00:00 [kworker/4:1H]
              root       243     2  0 11:16 ?        00:00:00 [jbd2/mmcblk0p1-]
              root       244     2  0 11:16 ?        00:00:00 [ext4-rsv-conver]
              root       266     2  0 11:16 ?        00:00:00 [jbd2/mmcblk0p2-]
              root       267     2  0 11:16 ?        00:00:00 [ext4-rsv-conver]
              root       294     2  0 11:16 ?        00:00:00 [kauditd]
              root       303     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-journald
              root       331     2  0 11:16 ?        00:00:00 [kworker/4:2]
              root       355     2  0 11:16 ?        00:00:00 [kworker/2:1H]
              root       369     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-udevd
              root       387     2  0 11:16 ?        00:00:00 [kworker/3:2]
              root       463     1  0 11:16 ?        00:00:00 /usr/lib/accountsservice/account
              gpsd       467     1  0 11:16 ?        00:00:00 /usr/sbin/gpsd -N
              syslog     469     1  0 11:16 ?        00:00:00 /usr/sbin/rsyslogd -n
              avahi      485     1  0 11:16 ?        00:00:02 avahi-daemon: running [FriendlyE
              message+   515     1  0 11:16 ?        00:00:06 /usr/bin/dbus-daemon --system --
              avahi      541   485  0 11:16 ?        00:00:00 avahi-daemon: chroot helper
              root       573     2  0 11:16 ?        00:00:00 [kworker/5:1H]
              root       636     1  0 11:16 ?        00:00:08 /usr/sbin/NetworkManager --no-da
              root       659     1  0 11:16 ?        00:00:00 /usr/sbin/cups-browsed
              root       668     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-logind
              root       690     1  0 11:16 ?        00:00:00 /usr/sbin/cron -f
              root       705     2  0 11:16 ?        00:00:00 [wl_escan_handle]
              root       706     2  0 11:16 ?        00:00:01 [dhd_watchdog_th]
              root       709     2  0 11:16 ?        00:00:02 [dhd_dpc]
              root       710     2  0 11:16 ?        00:00:00 [dhd_rxf]
              root       770     1  0 11:16 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
              root       795     1  0 11:16 ?        00:00:00 /usr/sbin/lightdm
              dnsmasq    815     1  0 11:16 ?        00:00:00 /usr/sbin/dnsmasq -x /var/run/dn
              root       863     2  0 11:16 ?        00:00:00 [kworker/3:1H]
              root       894   795  3 11:16 tty7     00:04:40 /usr/bin/X -core :0 -seat seat0
              root       997     2  0 11:16 ?        00:00:00 [kbase_event]
              root      1007     2  0 11:16 ?        00:00:00 [dhd_eventd]
              root      1008     2  0 11:16 ?        00:00:00 [kworker/1:1H]
              root      1010     1  0 11:16 ?        00:00:01 /sbin/wpa_supplicant -u -s -O /r
              root      1026   795  0 11:16 ?        00:00:00 lightdm --session-child 12 15
              pi        1032     1  0 11:16 ?        00:00:00 /lib/systemd/systemd --user
              pi        1035  1032  0 11:16 ?        00:00:00 (sd-pam)
              pi        1038  1026  0 11:16 ?        00:00:00 /sbin/upstart --user
              pi        1098  1038  0 11:16 ?        00:00:00 upstart-udev-bridge --daemon --u
              pi        1101  1038  0 11:16 ?        00:00:00 dbus-daemon --fork --session --a
              pi        1136  1038  0 11:16 ?        00:00:00 gnome-keyring-daemon --start --c
              pi        1149  1038  0 11:16 ?        00:00:00 upstart-dbus-bridge --daemon --s
              pi        1153  1038  0 11:16 ?        00:00:00 upstart-file-bridge --daemon --u
              pi        1155  1038  0 11:16 ?        00:00:00 upstart-dbus-bridge --daemon --s
              pi        1165  1038  0 11:16 ?        00:00:00 gpg-agent --homedir /home/pi/.gn
              pi        1182  1038  0 11:16 ?        00:00:00 /usr/bin/lxsession -s Lubuntu -e
              pi        1187  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd
              pi        1192  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/us
              root      1200     2  0 11:16 ?        00:00:00 [kworker/0:1H]
              pi        1204  1182  0 11:16 ?        00:00:01 openbox --config-file /home/pi/.
              pi        1207  1182  0 11:16 ?        00:00:34 lxpanel --profile Lubuntu
              pi        1209  1182  0 11:16 ?        00:00:04 pcmanfm --desktop --profile lubu
              pi        1215  1038  0 11:16 ?        00:00:00 /usr/bin/ssh-agent -s
              pi        1224  1038  0 11:16 ?        00:00:08 nm-applet
              pi        1237  1038  0 11:16 ?        00:00:00 xfce4-power-manager
              pi        1245  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/xfc
              pi        1249  1038  0 11:16 ?        00:00:01 /usr/bin/pulseaudio --start --lo
              rtkit     1250     1  0 11:16 ?        00:00:00 /usr/lib/rtkit/rtkit-daemon
              root      1259     1  0 11:16 ?        00:00:00 /usr/lib/upower/upowerd
              pi        1270  1038  0 11:16 ?        00:00:00 /usr/lib/menu-cache/menu-cached
              pi        1291  1038  0 11:16 ?        00:00:00 /usr/lib/at-spi2-core/at-spi-bus
              pi        1300  1291  0 11:16 ?        00:00:00 /usr/bin/dbus-daemon --config-fi
              pi        1305  1038  0 11:16 ?        00:00:00 /usr/lib/at-spi2-core/at-spi2-re
              pi        1318  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-udisks2-volum
              root      1321     1  0 11:16 ?        00:00:00 /usr/lib/udisks2/udisksd --no-de
              pi        1348  1038  0 11:16 ?        00:00:00 /usr/lib/indicator-sound-gtk2/in
              pi        1349  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/ind
              root      1411     1  0 11:16 ?        00:00:00 /sbin/dhclient -1 -v -pf /run/dh
              pi        1412  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-mo
              pi        1442  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volum
              pi        1497  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-goa-volume-mo
              pi        1526  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-afc-volume-mo
              root      1530     1  0 11:16 ?        00:00:00 /usr/bin/python3 /usr/share/unat
              root      1545     1  0 11:16 ?        00:00:00 /usr/sbin/sshd -D
              pi        1555  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd-trash --spaw
              whoopsie  1568     1  0 11:16 ?        00:00:00 /usr/bin/whoopsie -f
              root      1597     2  0 11:16 ?        00:00:00 [hci0]
              root      1598     2  0 11:16 ?        00:00:00 [hci0]
              root      1599     1  0 11:16 ?        00:00:00 /usr/bin/hciattach /dev/ttyS0 bc
              root      1606     1  0 11:16 ?        00:00:12 /bin/bash /usr/bin/start-rk3399-
              root      1611     1  0 11:16 ttyFIQ0  00:00:00 /sbin/agetty --keep-baud 115200
              root      1612     1  0 11:16 tty1     00:00:00 /sbin/agetty --noclear tty1 linu
              root      1616     1  0 11:16 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
              pi        1622     1  0 11:16 ?        00:00:02 PM2 v4.2.3: God Daemon (/home/pi
              pi        1693  1038  0 11:16 ?        00:00:05 /usr/bin/python /usr/bin/x-termi
              ntp       1700     1  0 11:16 ?        00:00:02 /usr/sbin/ntpd -p /var/run/ntpd.
              pi        1747  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/gco
              pi        1752  1693  0 11:16 ?        00:00:00 gnome-pty-helper
              pi        1753  1693  0 11:16 pts/1    00:00:00 /bin/bash
              pi        2623  1207  1 11:18 ?        00:02:03 /usr/lib/chromium-browser/chromi
              pi        2637  2623  0 11:18 ?        00:00:00 /usr/lib/chromium-browser/chromi
              pi        2639  2637  0 11:18 ?        00:00:00 /usr/lib/chromium-browser/chromi
              pi        2660  2623  3 11:18 ?        00:04:22 /usr/lib/chromium-browser/chromi
              pi        2664  2623  0 11:18 ?        00:00:20 /usr/lib/chromium-browser/chromi
              root      2671     2  0 11:18 ?        00:00:00 [kbase_event]
              pi        2714  2639  0 11:18 ?        00:00:06 /usr/lib/chromium-browser/chromi
              pi        2760  2639  0 11:18 ?        00:00:17 /usr/lib/chromium-browser/chromi
              pi        3054  2639  1 11:18 ?        00:02:10 /usr/lib/chromium-browser/chromi
              root      3587     1  0 11:21 ?        00:00:00 /usr/sbin/cupsd -l
              root      4334     2  0 11:28 ?        00:00:00 [kworker/5:2]
              root      4498     2  0 11:28 ?        00:00:07 [kworker/1:0]
              pi        4562  1038  0 11:29 ?        00:00:01 /usr/bin/python /usr/bin/x-termi
              pi        4572  4562  0 11:29 ?        00:00:00 gnome-pty-helper
              pi        4573  4562  0 11:29 pts/2    00:00:00 /bin/bash
              pi        4792  1209  0 11:31 ?        00:00:03 leafpad /home/pi/MagicMirror/con
              pi        5864  2639  1 11:44 ?        00:01:25 /usr/lib/chromium-browser/chromi
              pi        5927  2639  0 11:44 ?        00:00:00 /usr/lib/chromium-browser/chromi
              root      6603     2  0 11:51 ?        00:00:00 [kworker/2:2]
              root      7776     2  0 12:07 ?        00:00:00 [kworker/4:1]
              root      8056     2  0 12:11 ?        00:00:03 [kworker/u12:2]
              root     10915     2  0 12:49 ?        00:00:04 [kworker/0:2]
              root     12454     2  0 13:11 ?        00:00:00 [kworker/u13:0]
              root     12691     2  0 13:15 ?        00:00:00 [kworker/u12:0]
              root     12846     2  0 13:17 ?        00:00:00 [kworker/u13:2]
              root     13049     2  0 13:20 ?        00:00:00 [kworker/u12:1]
              root     13163     2  0 13:21 ?        00:00:00 [kworker/0:1]
              root     13231     2  0 13:22 ?        00:00:00 [kworker/u13:1]
              root     13260  1606  0 13:22 ?        00:00:00 sleep 2s
              pi       13261  1753  0 13:22 pts/1    00:00:00 ps -ef
              pi@FriendlyELEC:~/MagicMirror$
              and result of lsb-release-a :
              pi@FriendlyELEC:~/MagicMirror$ lsb_release -a
              No LSB modules are available.
              Distributor ID:	Ubuntu
              Description:	Ubuntu 16.04.6 LTS
              Release:	16.04
              Codename:	xenia
              thanks
                @banbutcher cool.
                Can u try pgrep X
                    @banbutcher cool. Edit the run-start.sh and change
                    pgrep Xorg
                    To
                    pgrep X
                    Until I can make the right change
                    Thank you for your help
                      banbutcher
                      Perfect, thanks a lot for your help!
                        @banbutcher I have updated the run-start.sh script… if you would like the latest copy do
                        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh > run-start.sh
