    MMM-COVID-19 (Deprecated)
    Scheduled Pinned Locked Moved Health
    71 Posts 16 Posters 38.5k Views 16 Watching
      sdetweil @Guest
      @Sean
        module: "MMM-COVID-19",
        debug:false,
        scanInterval: 1000 * 60 * 60 * 3,
        rotateInterval: 0, // 0 means no rotate
        pinned: [ "World","US Total","France","Spain","Italy"],
        reportTimeFormat: "YYYY.MM.DD hh a",
        drawGraph: true,
        [[global:former-user]] @sdetweil
        Hmmm. For me no problem. There might be CSS collision with other module? (“.graph”)
        And France means only mainland of France, not Sum of all territories of French.
          sdetweil @Guest
          @Sean hm… ok. graph to me means line graph (something different from what was displayed before)…
          I have the table charts…
          france mainland is what I wanted…
            To draw line graph needs canvas or other tricks. For me this enough. But if you have a PR, I will accept with welcome. :)
              sdetweil @Guest
              @Sean ok, i had misunderstood… default is drawgraph:true, so it was no different than before
                banbutcher
                ive reinstalled and now im only getting NZ graph showing and no world or spain or ireland, its solved the rise in cpu usage… hers my config code:
                // Covid-19
                			header: "COVID-19",
                			position: "bottom_right",
                			config:{
                				scanInterval: 1000 * 60 * 60 * 12,
                				rotateInterval: 0,
                				detailProvince: true,
                				pinned: ["Ireland"],
                				pinned: ["Spain"],
                				pinned: ["New Zealand"],
                				myPosition: {latitude:-43.5523955, longitude:172.6328479, metric:"km",}, //or null. // reserved for later.
                				logProvinceCountry: false,
                				logOnce: true,
                		        	sortOrder: null,
                				drawGraph: true,
                any ideas?
                  sdetweil @banbutcher
                  @banbutcher pinned needs to be a single array w multiple names. See mine a few posts back. Also some names have changed
                    banbutcher @sdetweil
                    yup that did it… is it possible to scale the sizes down?
                    ? R S 3 Replies Last reply Reply Quote 0
                      [[global:former-user]] @banbutcher
                      @banbutcher
                      All magic mirror modules have their own css ([module name].css). Look inside of that file then find what you need and override it in your css/custom.css of MagicMirror. Sorry, MM is DIY project so there is no silver bullet out of box.
                        retroflex Project Sponsor Module Developer @banbutcher
                        @banbutcher Another tip to easier find the css class for a certain text… use the Chrome developer tools where you can see all elements and their css attributes graphically.
                          @banbutcher I turned off the little graph at the bottom, drawgraph:false to save space
                          • W Offline
                            war6000
                            @Sean I just wanted to thank you for your work; also it would be helpful to note in GitHub that by setting
                            rotateInterval:0
                            it also disables the third slot (if users only need 2 slots). Again Thank you very much for your work.
                              [[global:former-user]] @war6000
                              @war6000
                              :) Thanks for your mention. Frankly, it is described in README already
                               rotateInterval: 1000 * 5, // 0 means no rotate
                              But I agree it is somewhat not obvious.
                              • W Offline
                                wi_brewer
                                Anybody know why I’m getting this error when I try to start MM?
                                  [[global:former-user]] @wi_brewer
                                  @wi_brewer What is your node version? (node -v)
                                  • W Offline
                                    wi_brewer @Guest
                                    @Sean v7.10.1
                                      @wi_brewer
                                      Too low to run this module. Sorry.
                                      • W Offline
                                        wi_brewer @Guest
                                        @Sean Thanks for the quick replies. What’s the minimum version required?
                                          @wi_brewer
                                          I think to use async arrow function, At least node 8 be needed.
                                          Current Most Recent version is 13.11 and Most recommended version is 12.16 at this moment.
                                          And MagicMirror install guide usually assumes 10.x
                                            siggmur
                                            Possible to add some sort of scaling?
                                            • 3 / 4
