    MMM-COVID-19 (Deprecated)
    Scheduled Pinned Locked Moved Health
    71 Posts 16 Posters 39.7k Views 16 Watching
      sdetweil @Guest
      @Sean ok, i had misunderstood… default is drawgraph:true, so it was no different than before
        banbutcher
        ive reinstalled and now im only getting NZ graph showing and no world or spain or ireland, its solved the rise in cpu usage… hers my config code:
        // Covid-19
        			module: "MMM-COVID-19",
        			header: "COVID-19",
        			position: "bottom_right",
        			config:{
        				scanInterval: 1000 * 60 * 60 * 12,
        				rotateInterval: 0,
        				detailProvince: true,
        				pinned: ["Ireland"],
        				pinned: ["Spain"],
        				pinned: ["New Zealand"],
        				myPosition: {latitude:-43.5523955, longitude:172.6328479, metric:"km",}, //or null. // reserved for later.
        				logProvinceCountry: false,
        				logOnce: true,
        		        	sortOrder: null,
        				reportTimeFormat: "YYYY.MM.DD hh a",
        				drawGraph: true,
        any ideas?
          sdetweil @banbutcher
          @banbutcher pinned needs to be a single array w multiple names. See mine a few posts back. Also some names have changed
            banbutcher @sdetweil
            yup that did it… is it possible to scale the sizes down?
            ? R S 3 Replies Last reply Reply Quote 0
              A Former User @banbutcher
              @banbutcher
              All magic mirror modules have their own css ([module name].css). Look inside of that file then find what you need and override it in your css/custom.css of MagicMirror. Sorry, MM is DIY project so there is no silver bullet out of box.
                retroflex Project Sponsor Module Developer @banbutcher
                @banbutcher Another tip to easier find the css class for a certain text… use the Chrome developer tools where you can see all elements and their css attributes graphically.
                  @banbutcher I turned off the little graph at the bottom, drawgraph:false to save space
                  • W Offline
                    war6000
                    @Sean I just wanted to thank you for your work; also it would be helpful to note in GitHub that by setting
                    rotateInterval:0
                    it also disables the third slot (if users only need 2 slots). Again Thank you very much for your work.
                      A Former User @war6000
                      @war6000
                      :) Thanks for your mention. Frankly, it is described in README already
                       rotateInterval: 1000 * 5, // 0 means no rotate
                      But I agree it is somewhat not obvious.
                      • W Offline
                        wi_brewer
                        Anybody know why I’m getting this error when I try to start MM?
                          A Former User @wi_brewer
                          @wi_brewer What is your node version? (node -v)
                          • W Offline
                            wi_brewer @Guest
                            @Sean v7.10.1
                              @wi_brewer
                              Too low to run this module. Sorry.
                              • W Offline
                                wi_brewer @Guest
                                @Sean Thanks for the quick replies. What’s the minimum version required?
                                  @wi_brewer
                                  I think to use async arrow function, At least node 8 be needed.
                                  Current Most Recent version is 13.11 and Most recommended version is 12.16 at this moment.
                                  And MagicMirror install guide usually assumes 10.x
                                    siggmur
                                    Possible to add some sort of scaling?
                                      mrdenmark
                                      at the moments i have 2 slots,the first is world total and the second rotates through all the affected countries-can i change the second to rotate though a defined range of countries instead? i don’t have enough scrren space to give each country its own slot.
                                      • L Offline
                                        luxiouronimo
                                        heya, thanks for the module; here’s what myne is looking like with some custom css:
                                        https://imgur.com/a/1y61O7L
                                        can we get a thousands separator? personally i’d like a comma, but i gather folks in other regions might prefer a period, so the option for either would be useful…
                                        also the US Total numbers don’t seem right; there’s a blue bar a few days ago, but no R or NR, but then again, perhaps the data is outta whack or the api is changing as i now see negative numbers in various places…
                                          A Former User @siggmur
                                          @siggmur
                                          What kind of scaling are you meaning? Sorry, I’m not good at English, So more detailed explanation or example be needed.
                                            A Former User @mrdenmark
                                            @mrdenmark
                                            Hmmmm… will consider, but for that, You have to describe all regions to be displayed. I’m not sure it’s really useful or convenience or not. (At this moment, total regions might be over 300s. and not regulated in origianl source)
                                            • 3 / 4
