    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      JHermann
      • BKeyportB Offline
        BKeyport Module Developer
        @JHermann Bit of testing here - I took your config, modified it for my URLs rather than your stub urls, removed my custom.css and found an interesting layout.
        I’m using a 1920x1080 monitor.
        In landscape mode (wide monitor) - the daily view is interfering with the upcoming view in either position.
        in portrait mode (Tall monitor) - the daily view does show for me in upper_third, but clashes with upcoming view. If daily view is in bottom_bar, it shows clean, but upcoming and parts of Minical and your weather app is hidden behind the NOAA picture.
        I suspect what’s happening is the NOAA picture is covering up your view in the config that you have.
        Do you have custom.css in place at all?
        Have you tried commenting out the NOAA picture and seeing if it works in upper-third then?
        – B
        Edit: while @Sean likes to test with the normal URLs, I figure if they’re showing in one position, they should show with all of them, unless there’s something else wrong - some of my URLs are still google.
          JHermann
          @BKeyport Hi Mate, I have res set to 1920x1080 and am using portrait mode via screen layout editor and choosing orientation of right.
          Am using a LED TV as the display, I have been emailing Sean and he has the same thoughts that other modules are interfering and he could can get daily view to display in other regions with only the calendar Ext2 module.
          custom.css has only the below in it to reduce margins:
          body {
          margin: 20px;
          position: absolute;
          height: calc(100% - 40px);
          width: calc(100% - 40px);
          I have deleted all other modules from the Config file and still cant display the daily view in other regions at all…weird.
          There must be something I am doing wrong but as as I am inexperienced I am struggling.
          The new Config is below and have emailed Sean a screenshot (havent been able to upload a picture to this forum) and this config as well:
          Any assistance is appreciated.
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 12,
          	units: "metric",
          			     // false, default for all  NON-armv6l devices
          			module: 'MMM-CalendarExt2',
          				url: "https://calendar.google.com/calendar/ical///////////////////",
          				name: "Simona and Jaimie",
          				url: "https://calendar.google.com/calendar/ical///////////////////////////",
          				icon: "emojione-monotone:birthday-cake",
          				url: "https://calendar.google.com/calendar/htmlembed?src=///////////////////////////////",
          				views: [
          				title: "Upcoming Events",
          				mode: "upcoming",
          				maxItems: 5,
          				maxDays: 7,
          				locale: "en",
          				hideOverflow: false,
          				filterPassedEvent: true,
          				dateTimeFormat:"M/D h:mm A",
          				calendars: ["Jaimie","Simona and Jaimie","Birthdays"],
          				title: "All Calendars",
          				mode: "daily",
          				type: "row",
          				position: "top- right",
          				slotCount: 4,
          				locale: "en",
          				scenes: [
          				views: [],
            A Former User @JHermann
            @JHermann
            Have you done something on css/custom.css or main.css or any other css file?
              JHermann
              @Sean Only the Custom.css per below to reduce margins. No other changes to any ,css file as far as i recolect.
              body {
              margin: 20px;
              position: absolute;
              Maybe i should uninstall and start over?
                @JHermann
                Well , this kind of problem is not related to installation. Reinstall might solve the issue, but we don’t know why and how. And there is still possibility of not-solving.
                The most common pitfall might be mistyping.
                This is not a proper symbol of top_right region.
                  JHermann @Guest
                  @Sean Good point, that was a definite typo.
                  • H Offline
                    Hram2008
                    Multiple Icon in upcoming View
                    Please confirm how I can add more then one Icon in the upcoming view, I used the Transform event in "Views"but I can only get one icon to show…
                      A Former User @Hram2008
                      @Hram2008
                      Not possible. Why do you need? By the case, I could consider that feature, but normally, why is it needed?
                      You can transform the title to use emoji instead icon.
                      • H Offline
                        Hram2008 @Guest
                        @Sean
                        Sorry, I am not not able attach an image. What i am trying to do is is the Transform event with specific text to add an emoji to the upcoming view… i.e Calendar event with “Birthday” in name would add a Birthday cake emoji to the event… I want to do this for other text… " Christmas" = x-mas Tree emoji…where other text would display other emoji…
                          @Hram2008
                          First, I’m not sure emoji could be displayable on Electron(Chromium) of Raspbian without any additional things(font?). I have no RPI at this moment, so can’t test.
                          But I believe it could, And at least, on my other SBCs, it works.
                          Frankly says, How to transform exists already in the wiki of github repository, Anyway, I’ll show it again with another sample.
                          Before
                          Add transform into your target View. (Or you can apply it globally by defaultSet
                          transform: (event) => {
                            event.title = event.title.replace(/FC/g, "⚽")
                            event.title = event.title.replace(" - ", " VS. ")
                            event.title = event.title.replace("(T.B.A.)", "")
                            event.title = event.title.replace("Bayern München", `< img src='https://logodix.com/logo/337534.jpg' height='20px' width='100px' >`)
                            return event
                          Then It will show like this;
                          After
                          • H Offline
                            Hram2008 @Guest
                            @Sean
                            Thank you for taking the time to respond, not quite what i was looking to do but it did point me in the right direction.
                              CharlesDS
                              Are they known issues on raspberry pi 2? I’m working on configs without success. Black screen, nothing, but other modules, appears.
                                A Former User @CharlesDS
                                @CharlesDS
                                Without log I cannot tell anything. More detailed info be needed. And Of course, on RPI2, it works.
                                • Z Offline
                                  Zinkeler
                                  everything works fine in landscape-mode. If i change to portrait-mode (display_rotate=1
                                  avoid_warnings=1 in /boot/config.txt) my calender is not shown. All other modules are on my mirror.
                                  Can someone give me a hint?
                                  thx
                                  Ralph
                                    A Former User @Zinkeler
                                    @Zinkeler
                                    Nothing suspicious.
                                    Which view are you using? show me your config about this module.
                                    Z 1 Reply Last reply Reply Quote 0
                                    • Z Offline
                                      Zinkeler @Guest
                                      @Sean
                                      { module: ‘MMM-CalendarExt2’,
                                      scenes:[
                                      views: [“upcoming”,“weeks”],
                                      views:[
                                      mode: “upcoming”,
                                      position: “top_left”,
                                      slotTitle: “Demnächst”,
                                      maxItems: 4,
                                      locale: “de-DE”,
                                      calendars: [“Ralph”],
                                      mode: “week”,
                                      title: “Woche”,
                                      type: “row”,
                                      position: “bottom_bar”,
                                      slotCount: 1,
                                      locale: “de-DE”,
                                      url: “”,
                                        @Zinkeler
                                        Well, nothing suspicious in configuration.
                                        What log says? open dev-tools on MM screen and see what log says.
                                        • Z Offline
                                          Zinkeler @Guest
                                          @Sean
                                          sorry, I’ve never done that. how can i do that?
                                          thx
                                            @Zinkeler
                                            Ctrl + Shift + i (Or different per environment) on MM Screen.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 24
                                            • 25
                                            • 17 / 25
