    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      JHermann
      @BKeyport Hi Mate, I have res set to 1920x1080 and am using portrait mode via screen layout editor and choosing orientation of right.
      Am using a LED TV as the display, I have been emailing Sean and he has the same thoughts that other modules are interfering and he could can get daily view to display in other regions with only the calendar Ext2 module.
      custom.css has only the below in it to reduce margins:
      body {
      margin: 20px;
      position: absolute;
      height: calc(100% - 40px);
      width: calc(100% - 40px);
      I have deleted all other modules from the Config file and still cant display the daily view in other regions at all…weird.
      There must be something I am doing wrong but as as I am inexperienced I am struggling.
      The new Config is below and have emailed Sean a screenshot (havent been able to upload a picture to this forum) and this config as well:
      Any assistance is appreciated.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: 'MMM-CalendarExt2',
      				url: "https://calendar.google.com/calendar/ical///////////////////",
      				name: "Simona and Jaimie",
      				url: "https://calendar.google.com/calendar/ical///////////////////////////",
      				icon: "emojione-monotone:birthday-cake",
      				url: "https://calendar.google.com/calendar/htmlembed?src=///////////////////////////////",
      				views: [
      				title: "Upcoming Events",
      				mode: "upcoming",
      				maxItems: 5,
      				maxDays: 7,
      				locale: "en",
      				hideOverflow: false,
      				filterPassedEvent: true,
      				dateTimeFormat:"M/D h:mm A",
      				calendars: ["Jaimie","Simona and Jaimie","Birthdays"],
      				title: "All Calendars",
      				mode: "daily",
      				type: "row",
      				position: "top- right",
      				slotCount: 4,
      				locale: "en",
      				scenes: [
      				views: [],
        A Former User @JHermann
        @JHermann
        Have you done something on css/custom.css or main.css or any other css file?
          JHermann
          @Sean Only the Custom.css per below to reduce margins. No other changes to any ,css file as far as i recolect.
          body {
          margin: 20px;
          position: absolute;
          Maybe i should uninstall and start over?
            @JHermann
            Well , this kind of problem is not related to installation. Reinstall might solve the issue, but we don’t know why and how. And there is still possibility of not-solving.
            The most common pitfall might be mistyping.
            This is not a proper symbol of top_right region.
              JHermann @Guest
              @Sean Good point, that was a definite typo.
              • H Offline
                Hram2008
                Multiple Icon in upcoming View
                Please confirm how I can add more then one Icon in the upcoming view, I used the Transform event in "Views"but I can only get one icon to show…
                  A Former User @Hram2008
                  @Hram2008
                  Not possible. Why do you need? By the case, I could consider that feature, but normally, why is it needed?
                  You can transform the title to use emoji instead icon.
                  • H Offline
                    Hram2008 @Guest
                    @Sean
                    Sorry, I am not not able attach an image. What i am trying to do is is the Transform event with specific text to add an emoji to the upcoming view… i.e Calendar event with “Birthday” in name would add a Birthday cake emoji to the event… I want to do this for other text… " Christmas" = x-mas Tree emoji…where other text would display other emoji…
                      @Hram2008
                      First, I’m not sure emoji could be displayable on Electron(Chromium) of Raspbian without any additional things(font?). I have no RPI at this moment, so can’t test.
                      But I believe it could, And at least, on my other SBCs, it works.
                      Frankly says, How to transform exists already in the wiki of github repository, Anyway, I’ll show it again with another sample.
                      Before
                      Add transform into your target View. (Or you can apply it globally by defaultSet
                      transform: (event) => {
                        event.title = event.title.replace(/FC/g, "⚽")
                        event.title = event.title.replace(" - ", " VS. ")
                        event.title = event.title.replace("(T.B.A.)", "")
                        event.title = event.title.replace("Bayern München", `< img src='https://logodix.com/logo/337534.jpg' height='20px' width='100px' >`)
                        return event
                      Then It will show like this;
                      After
                      • H Offline
                        Hram2008 @Guest
                        @Sean
                        Thank you for taking the time to respond, not quite what i was looking to do but it did point me in the right direction.
                          CharlesDS
                          Are they known issues on raspberry pi 2? I’m working on configs without success. Black screen, nothing, but other modules, appears.
                            A Former User @CharlesDS
                            @CharlesDS
                            Without log I cannot tell anything. More detailed info be needed. And Of course, on RPI2, it works.
                            • Z Offline
                              Zinkeler
                              everything works fine in landscape-mode. If i change to portrait-mode (display_rotate=1
                              avoid_warnings=1 in /boot/config.txt) my calender is not shown. All other modules are on my mirror.
                              Can someone give me a hint?
                              thx
                              Ralph
                                A Former User @Zinkeler
                                @Zinkeler
                                Nothing suspicious.
                                Which view are you using? show me your config about this module.
                                Z 1 Reply Last reply Reply Quote 0
                                • Z Offline
                                  Zinkeler @Guest
                                  @Sean
                                  { module: ‘MMM-CalendarExt2’,
                                  scenes:[
                                  views: [“upcoming”,“weeks”],
                                  views:[
                                  mode: “upcoming”,
                                  position: “top_left”,
                                  slotTitle: “Demnächst”,
                                  maxItems: 4,
                                  locale: “de-DE”,
                                  calendars: [“Ralph”],
                                  mode: “week”,
                                  title: “Woche”,
                                  type: “row”,
                                  position: “bottom_bar”,
                                  slotCount: 1,
                                  locale: “de-DE”,
                                  url: “”,
                                    @Zinkeler
                                    Well, nothing suspicious in configuration.
                                    What log says? open dev-tools on MM screen and see what log says.
                                    • Z Offline
                                      Zinkeler @Guest
                                      @Sean
                                      sorry, I’ve never done that. how can i do that?
                                      thx
                                        @Zinkeler
                                        Ctrl + Shift + i (Or different per environment) on MM Screen.
                                          Doudy @Guest
                                          @Sean
                                          I just went from MMM-Calendarext to MMM-calendarExt2
                                          By following your advice: link text
                                          And I have a few questions:
                                          alt text
                                          • 12/04 Dim. - Pâques
                                            It says ‘Tommorow’
                                            Why ?
                                            How else to translate into (french) ‘Demain’
                                          -16/04 and 17/04
                                          The deadline for the period is indicated: 4/19
                                          How to modify in 19/04
                                          -Is it possible to delete the description of the day: “lundi”, “mardi”
                                          but leave if there is an end date on another day (period)
                                          :winking_face:
                                            JohnBachini @Doudy
                                            @Doudy
                                            Did you manage to work out how to change from MM/DD to DD/MM ? As I have same problem.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 24
                                            • 25
                                            • 17 / 25
