    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      A Former User @Hram2008
      @Hram2008
      First, I’m not sure emoji could be displayable on Electron(Chromium) of Raspbian without any additional things(font?). I have no RPI at this moment, so can’t test.
      But I believe it could, And at least, on my other SBCs, it works.
      Frankly says, How to transform exists already in the wiki of github repository, Anyway, I’ll show it again with another sample.
      Before
      Add transform into your target View. (Or you can apply it globally by defaultSet
      transform: (event) => {
        event.title = event.title.replace(/FC/g, "⚽")
        event.title = event.title.replace(" - ", " VS. ")
        event.title = event.title.replace("(T.B.A.)", "")
        event.title = event.title.replace("Bayern München", `< img src='https://logodix.com/logo/337534.jpg' height='20px' width='100px' >`)
        return event
      Then It will show like this;
      After
      H 1 Reply Last reply
      • H
        Hram2008 @Guest
        @Sean
        Thank you for taking the time to respond, not quite what i was looking to do but it did point me in the right direction.
          CharlesDS
          Are they known issues on raspberry pi 2? I’m working on configs without success. Black screen, nothing, but other modules, appears.
          ? 1 Reply Last reply
            A Former User @CharlesDS
            @CharlesDS
            Without log I cannot tell anything. More detailed info be needed. And Of course, on RPI2, it works.
            • Z
              Zinkeler
              everything works fine in landscape-mode. If i change to portrait-mode (display_rotate=1
              avoid_warnings=1 in /boot/config.txt) my calender is not shown. All other modules are on my mirror.
              Can someone give me a hint?
              thx
              Ralph
                A Former User @Zinkeler
                @Zinkeler
                Nothing suspicious.
                Which view are you using? show me your config about this module.
                Z 1 Reply Last reply
                • Z
                  Zinkeler @Guest
                  @Sean
                  { module: ‘MMM-CalendarExt2’,
                  scenes:[
                  views: [“upcoming”,“weeks”],
                  views:[
                  mode: “upcoming”,
                  position: “top_left”,
                  slotTitle: “Demnächst”,
                  maxItems: 4,
                  locale: “de-DE”,
                  calendars: [“Ralph”],
                  mode: “week”,
                  title: “Woche”,
                  type: “row”,
                  position: “bottom_bar”,
                  slotCount: 1,
                  locale: “de-DE”,
                  url: “”,
                    @Zinkeler
                    Well, nothing suspicious in configuration.
                    What log says? open dev-tools on MM screen and see what log says.
                    • Z
                      Zinkeler @Guest
                      @Sean
                      sorry, I’ve never done that. how can i do that?
                      thx
                        @Zinkeler
                        Ctrl + Shift + i (Or different per environment) on MM Screen.
                        D 1 Reply Last reply
                          Doudy @Guest
                          @Sean
                          I just went from MMM-Calendarext to MMM-calendarExt2
                          By following your advice: link text
                          And I have a few questions:
                          alt text
                          • 12/04 Dim. - Pâques
                            It says ‘Tommorow’
                            Why ?
                            How else to translate into (french) ‘Demain’
                          -16/04 and 17/04
                          The deadline for the period is indicated: 4/19
                          How to modify in 19/04
                          -Is it possible to delete the description of the day: “lundi”, “mardi”
                          but leave if there is an end date on another day (period)
                          :winking_face:
                          J 1 Reply Last reply
                            JohnBachini @Doudy
                            @Doudy
                            Did you manage to work out how to change from MM/DD to DD/MM ? As I have same problem.
                              Doudy @JohnBachini
                              I have do this :
                              			locale:"fr-FR",
                              			slotTitleFormat: "DD/MM",
                              			slotSubTitleFormat: "ddd",
                              			slotAltTitleFormat: "DD/MM",
                              • A
                                andyriot
                                while using the “month” view is it possible to hide the previous/next month day slots?
                                I would like to only show this month Day 1 - Day 30/1
                                  JohnBachini @Doudy
                                  @Doudy
                                  @Doudy Great, ill give that a go Thanks
                                    SuperSense
                                    Hi everybody,
                                    first of all. Great Work with MM and the calendarExt2 Module.
                                    I was wondering, is there a way to hide those date informations on fullday events in daily and upcoming view.
                                    Crawled the through the topic, put didn’t found something.
                                    I’m pretty sure, u have to do it with css. but i can’t figure it out. can anybody pls help me?
                                    P 1 Reply Last reply
                                      SARCux @vulkandosii
                                      @vulkandosii your screen looks very well. Can you send me your background?
                                        BenGregg01
                                        @Sean Is there a way to move the time to the bottom right of the event cell like in daily view, instead of it being on the left of the event title for monthly view
                                          pillbug22 @SuperSense
                                          @SuperSense
                                          In case you haven’t found this yet, try looking in MMM-CalendarExt2.css , then look for the CSS block for
                                          .CX2 .period.daily .event.fullday.oneday .startDate {
                                            display:inline;
                                          Change the “inline” to “none” and see if that does what you are looking for.
                                            Robertovj3
                                            @Sean got a question if you could help
                                            I set up my magic mirror following all documentation. But I am having an issue with the MMM-Calendarext2 module.
                                            I configured it how I want, the top left calendar works and shows where it should, but I can’t seem to get the monthly calendar in the bottom_bar, it just covers the whole screen layered on top of the other modules.
                                            I have been trying on my own for a month, any help or direction would be helpful. Thanks!
                                            I want it to look exactly like the example here: https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/doc/Configuration.md
                                            Here is my code:
                                            calendars : [
                                            name: “Jolliffe Activities”,
                                            url: "https://calendar.google.com/calendar/ical/ //took out the rest of url.
                                            views: [
                                            mode: “upcoming”,
                                            position:“top_left”,
                                            title: “Jolliffe Upcoming Activities”,
                                            mode: “month”,
                                            title: “Jolliffe Monthly Activities”,
                                            slotSubTitleFormat: “dddd”,
                                            slotMaxHeight: “120px”,
                                            monthFormat: “[Month:]MM”,},],scenes: [ { name: “DEFAULT”,views: [], },],},
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 24
                                            • 25
                                            • 17 / 25
