    MMM-Spotify
    249 Posts 51 Posters 344.1k Views 54 Watching
      bminer1 @Guest
      @Sean i restarted the pi and my computer that is running the spotify. Everything is running and working as it should. buttons work, displays very well and its all good. Sorry, for the false alarm. noob moment.
        matt216
        Love the module, but noticed it makes the mirror by far the noisiest device on my network. Any idea why it talks so much to the spotify api?
          A Former User @matt216
          @matt216
          Because, Spotify playback API doesn’t be designed to push the status to the caller. The module should use pooling to get CURRENT playback status whenever it is needed. Set bigger value to updateInterval.
            matt216 @Guest
            @Sean thanks, appreciate the reply. Makes sense!
            • MondfischM Offline
              Mondfisch
              i am using your Module a couple of Months, it always worked well…
              …but since the last Update, it “hangs” after a couple of Minutes, which means,
              it still shows up, but the Title-Information and the Time is frozen.
              I am using MMM-Spotify and MMM-NowPlayingOnSpotify (I also use MMM-Carousel,
              so I have different “screens” on which I use both Modules, but not simultaneously.
              While MMM-Spotify is “freezing”, MMM-NowPlayingonSpotify is going on well…
              They worked BOTH OK, before the Update…
              Any Ideas?
                A Former User @Mondfisch
                @Mondfisch
                Hmmm. A recent update was for just multi-account supporting. Can you show backend log when it happened?
                  Mondfisch
                  Thank you for answering…
                  I´m not sure which log do you mean… Can you give me a path, i will post it, then…
                  • W Offline
                    woodstock37
                    I have similar situation like @Mondfisch described. And once problem appears, I got below log:
                    [15:46:23.437] [LOG] [SPOTIFY] API Request fail on : /v1/me/player
                    [15:46:23.440] [LOG] { Error: Client network socket disconnected before secure TLS connection was established
                    at TLSSocket.onConnectEnd (_tls_wrap.js:1092:19)
                    at Object.onceWrapper (events.js:273:13)
                    at TLSSocket.emit (events.js:187:15)
                    at endReadableNT (_stream_readable.js:1090:12)
                    at process._tickCallback (internal/process/next_tick.js:63:19)
                    code: ‘ECONNRESET’,
                    path: null,
                    host: ‘api.spotify.com’,
                    port: 443,
                    localAddress: undefined } undefined
                    [15:46:23.458] [LOG] Whoops! There was an uncaught exception…
                    [15:46:23.461] [ERROR] TypeError: Cannot read property ‘statusCode’ of undefined
                    at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:199:34)
                    at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                    at Request.emit (events.js:182:13)
                    at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                    at ClientRequest.emit (events.js:182:13)
                    at TLSSocket.socketErrorListener (_http_client.js:382:9)
                    at TLSSocket.emit (events.js:182:13)
                    at emitErrorNT (internal/streams/destroy.js:82:8)
                    at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
                    [15:46:23.470] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [15:46:23.472] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [16:09:49.712] [LOG] Shutting down server…
                    I tried to uninstall and install the module, but no luck, the problem keeps exist. Not sure if there is any solution on it.
                      A Former User @woodstock37
                      @woodstock37
                      Try to set updateInterval: to 2000 or 3000. I’ll inspect later.
                      • W Offline
                        woodstock37 @Guest
                        @Sean Thanks for your suggestion. It definitely helps. Thanks.
                        • E Offline
                          Ezz91
                          Re: [MMM - Spotify]
                          Hi @Sean
                          Just a suggestion, If you could include the heart/like button on the controls (to add the current song to your liked playlist)
                          Thanks!
                          p.s installed and works perfectly with 2 accounts!
                          • L Offline
                            Lasmazze
                            Hi @Sean, I just have a question I read the whole forum but I did not find the answer.
                            I installed Raspotify on my Raspberry pi, but when I launch my mirror, I cannot launch music by saying “music play”, only from my phone, once I have started the music from my phone and I connect it on raspotify I can change the music as well as all the other commands.
                            And spotify does not launch with onStart.
                              module: "MMM-Spotify",
                              position: "bottom_left",
                                style: "mini", // "default" or "mini" available
                                control: "hidden", //"default", "hidden" available
                                updateInterval: 1000,
                                onStart: {
                                  deviceName: "RASPOTIFY", //if null, current(last) activated device will be.
                                  spotifyUri: "spotify:track:0hNduWmlWmEmuwEFcYvRu1"
                                  //when search is set, sportifyUri will be ignored.
                            thank you for your answers.
                              A Former User @Lasmazze
                              @Lasmazze
                              Limitation of api. Until spotify really starts, api doesn’t return even the device list. So module can do nothing. Sorry.
                                banbutcher
                                im wondering if its possible to allign the spotify module to the right edge of the screen? ive recently added a covid-19 module and the spotify module alligns its self with the longer left edge. also is it possible to increse the padding on the bottom, i just want to space it away from th e covid module.
                                hopefully the link works and you can see what i mean…
                                https://drive.google.com/open?id=1_n5ntrUBSJITaOsOVct8U_-VpiiMSaAr
                                thanks,
                                Richie
                                  A Former User @banbutcher
                                  @banbutcher
                                  Try this. (But it could make unexpected result by your other modules. anyway worthy to try)
                                  /* In your `css/custom.css` */
                                  #SPOTIFY {
                                      position: absolute;
                                      right:0;
                                  Or you can adjust by manual.
                                  #SPOTIFY {
                                    left: 150px ; /* depends on your layout */
                                  • L Offline
                                    Lasmazze @Guest
                                    @Sean Ok thank you for your answer. apart from that your modules work really well, continue like that!
                                      SuperfrogMe
                                      Hi !
                                      Thirst, thanks to the devs for this module and the multi account function !
                                      I have a problem with the module. After some songs, the module stay stuck on a song.
                                      I have only some modules on my MM, and all others modules work fine.
                                      We are 2 at home, with 2 premium account and 1 Spotify Connect receiver. We mainly use le Spotify Connect receiver.
                                      The problem occurs with all the revceivers (Spotify connect or smartphones).
                                      Do you have an idea of the problem ?
                                            "USERNAME": "First user",
                                            "CLIENT_ID" : "xxx",
                                            "CLIENT_SECRET" : "yyy",
                                            "AUTH_DOMAIN" : "http://localhost",
                                            "AUTH_PATH" : "/callback",
                                            "AUTH_PORT" : "8888",
                                            "SCOPE" : "user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state",
                                            "TOKEN" : "./firstuser_token.json"
                                            "USERNAME": "Second user",
                                            "CLIENT_ID" : "zzz",
                                            "CLIENT_SECRET" : "www",
                                            "TOKEN" : "./seconduser_token.json"
                                        SuperfrogMe @SuperfrogMe
                                        I did a clean total reinstallation of my RPI3 under Raspbian Buster. Always the same problem, module blocked after a few minutes.
                                        Can we think of a bug?
                                        I will reinstall MMM-Spotify with only 1 account configured to see if the problem recurs.
                                        • F Offline
                                          ForrestFire2222
                                          Hi!
                                          I have been trouble shooting an install of MMM-Spotify for a few days now and I can’t seem to authorize/authenticate the token…
                                          When executing Step 4 of the install Get Auth;
                                          cd ~/MagicMirror/modules/MMM-Spotify node first_auth.js
                                          My terminal hangs up and I need to CTRL-C to get out.
                                          pi@raspberrypi:~/MagicMirror $ npm start dev
                                          > magicmirror@2.11.0 start /home/pi/MagicMirror
                                          > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                                          [2020-04-20 17:46:11.400] [LOG]    Starting MagicMirror: v2.11.0
                                          [2020-04-20 17:46:11.413] [LOG]    Loading config ...
                                          [2020-04-20 17:46:11.427] [LOG]    Loading module helpers ...
                                          [2020-04-20 17:46:11.433] [LOG]    No helper found for module: alert.
                                          [2020-04-20 17:46:11.538] [LOG]    Initializing new module helper ...
                                          [2020-04-20 17:46:11.539] [LOG]    Module helper loaded: updatenotification
                                          [2020-04-20 17:46:11.541] [LOG]    No helper found for module: clock.
                                          [2020-04-20 17:46:12.258] [LOG]    Initializing new module helper ...
                                          [2020-04-20 17:46:12.260] [LOG]    Module helper loaded: MMM-Spotify
                                          [2020-04-20 17:46:12.262] [LOG]    All module helpers loaded.
                                          [2020-04-20 17:46:12.503] [LOG]    Starting server on port 8080 ...
                                          [2020-04-20 17:46:12.531] [LOG]    Server started ...
                                          [2020-04-20 17:46:12.533] [LOG]    Connecting socket for: updatenotification
                                          [2020-04-20 17:46:12.535] [LOG]    Connecting socket for: MMM-Spotify
                                          [2020-04-20 17:46:12.539] [LOG]    Sockets connected & modules started ...
                                          [2020-04-20 17:46:12.700] [LOG]    Whoops! There was an uncaught exception...
                                          [2020-04-20 17:46:12.701] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                              at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                                              at listenInCluster (net.js:1274:12)
                                              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                                              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                                            code: 'EADDRINUSE',
                                            errno: 'EADDRINUSE',
                                            syscall: 'listen',
                                            address: '127.0.0.1',
                                            port: 8080
                                          My 8080 port is already in use causing an error? I’ve followed the installation procedure and verified my callback in Spotify Dev is copy and pasted as http://localhost:8888/callback
                                          My spotify.config.json;
                                                "USERNAME": "myname",
                                                "CLIENT_ID" : "spot_id",
                                                "CLIENT_SECRET" : "spot_secret",
                                                "TOKEN" : "./myname_token.json"
                                          My MagicMirror config.js;
                                          var config = {
                                                  address: "localhost",           // Address to listen on, can be:
                                                  port: 8080,
        // Set [] to allow all IP addresses
                                                  language: "en",
                                                  timeFormat: 24,
                                                  units: "imperial",
        // false, default for all  NON-armv6l devices
        position: "lower_third",
        updateInterval: 2000,
        onStart: null, // disable onStart feature with `null`
        allowDevices: [], //If you want to limit devices to display info, use this.
        // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                                          Any help, thanks
                                            A Former User @ForrestFire2222
                                            @ForrestFire2222
                                            It’s not issue of module. You just executed MagicMirror twice.
                                            • 12
                                            • 13
                                            • 6 / 13
