    MMM-MyCommute
    286 Posts 80 Posters 720.4k Views 77 Watching
      banbutcher @sdetweil
      if your taking about the API for directions, ive already done that. have entered credit card details too, needed that for GoogleMapsTraffic.
        sdetweil @banbutcher
        @banbutcher Google maps traffic uses the JavaScript map API. This module needs another api
          i have both turned on, at least im sure i do…
          https://drive.google.com/open?id=18ZReMNCAscxCxtJjd1dEo8s2D2u3MOY-
          thanks again
            @banbutcher did that solve the problem? I can’t see whatever is on that Google drive, as it tries to find it on mine
              banbutcher
              another question… as im running GoogleMapsTraffic as a full screen page i was wondering if its possible to show the quickest routes on the map between origin and destination?
                @banbutcher I don’t know what API parameters are available or used by that module
                  banbutcher
                  its just a pic of the list of enabled Apis and directions is on there… no still hasnt solved problem.
                  is their a different key for directions api and another different key for the javascript map api?
                    @banbutcher no. Just have to use the same project and key to enable the apis
                      thats what i thought, i have the right ones enabled and using the same key! :/
                        banbutcher
                        turns out i didnt have the address formatted correctly! took them directly from google maps and it worked great!
                        thanks,
                        Richie
                          banbutcher
                          is there any way of knowing if calendar events are being passed? Ive added this code to mine and nothing gets added to my commute:
                                maxCalendarEvents: 2,
                                maxCalendarTime: 24 * 60 * 60 * 1000,
                                calendarOptions: [
                                        mode: 'driving'
                          am i missing something?
                          • T Offline
                            testdruif
                            Created issue for calendar events regarding arrival time & transit option.
                            Also worth noting that calendar events are only first added when the module refreshes traffic (after 10 minutes from startup)
                            https://github.com/qistoph/MMM-MyCommute/issues/12
                            S T 2 Replies Last reply Reply Quote 0
                              sdetweil @testdruif
                              @testdruif is this module getting cal events as broadcast by the calendar module? How often does the cal module refresh/broadcast?
                              • T Offline
                                testdruif @testdruif
                                @testdruif said in MMM-MyCommute:
                                When the calendar events are added the code crashes further down the line.
                                Code doesn’t add the calendar collor variable.
                                • T Offline
                                  testdruif @sdetweil
                                  @sdetweil Yes, the module gets events from calendar module broadcast.
                                  Another issue: when you have multiple calendar modules configured the array gets wiped at unexpected times.
                                  So you can only use it correctly with 1 calendar module.
                                  because the commute module loads before all calendar entries are processed they are processed on the next “commute update” which is 10m by default config.
                                    sdetweil @testdruif
                                    @testdruif hm… I have a module that uses calendar events broadcast, and gets it right away…
                                      SoleLo
                                      Is there a way to remove the arrival time ?
                                        bhepler Module Developer @SoleLo
                                        @SoleLo - You could probably modify the custom.css file to hide the value of the arrival time.
                                          SoleLo @bhepler
                                          @bhepler would something like this work?
                                          .MMM-MYCommute.arrival-time-only .time {
                                          display: none;
                                          UPDATE: I actually tried
                                          .MMM-MYCommute. transit-arrival-time.time
                                          display: none;
                                          Still doesn’t work.
                                            sun34529
                                            @SoleLo and @bhepler , I’m trying to figure this out as well. Any luck?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
