    MMM-MyCommute
    286 Posts 80 Posters 740.4k Views 77 Watching
      in the MagicMirror folder do
      npm check:config
      fix 1st error, repeat
      I think it is the comma after the only destination
      				color: '#82E5AA'
      loading …
      is the default message many modules put up while getting their data
      but it failed to get the data
      so, this means there was an internal error in the module code
      open the developers window
      (either npm start dev, or use ctrl-shift-i when mirror is running)
      select the console tab, and scroll up to locate any errors, usually red text
      C 3 Replies Last reply
        charp07 @sdetweil
          charp07 @sdetweil
          @sdetweil okay, I’m new but the check:config command is not valid. So tried npm config and it brought up 10 errors.
          Usage:
          Npm config set
          Npm config get …
          Etc
          Etc…
          What does this mean?
            charp07 @sdetweil
            @sdetweil also added comma to that location with no success. Then moved to behind bracket and nothing there either.
              sdetweil @charp07
              @charp07 sorry, I get that command backwards
              npm config:check
              • I
                interman @thoeng
                @thoeng I ran into the same problem. there a few things you can do.
                1. Set the time that the module comes on and goes off. For example, I set my mine from 5:00 am to 8:00 am.
                  startTime and endTime
                2. Hide the module on weekends. Mine does not come up on the weekends. hideDays
                3. Change how many times it goes to google with a request. pollFrequency
                4. add a cheap motion sensor to turn the display on and off (getting one now).
                Hope that helps.
                Dn
                  charp07
                  I swapped to a newer branch of “MMM-MyCommute”. After install, it booted up on the first try. Happy that it is now working. Thanks to all the authors of this module.
                    JRB1988
                    Will this module still be updating in the background during the hidden times? With the Google API, I wouldn’t want it updating when I am not needing it. Thanks!
                    T 1 Reply Last reply
                    • T
                      trawson
                      Is anyone else having issues with the MyCommute module hiding itself but then not re-appearing.
                      I have EndTime setup for 8pm and also HideDays on certain days, however, once it hides, it stays hidden. Until I force it to show using the Remote module.
                      Otherwise, this Module works great, showing all the traffic times as it should.
                      • T
                        trawson @JRB1988
                        @JRB1988 From my experiences, I don’t believe it does.
                          smoysauce
                          Hi I have gotten this module setup and working with destinations (see below), but am trying to get it to show times based on locations of calendar events setup like at the end of the help page but it doesn’t seem to want to show. Am I missing something? My calendar shows my events and locations but not sure if MyCommute is pulling it. I even used the example code from the module Git page and it still didn’t pull anything. Does this not work anymore? Any insight would be much appreciated!
                                  module: 'MMM-MyCommute',
                                  position: 'bottom_left',
                                  header: 'Traffic',
                                          apikey: 'XXX',
                                          origin: 'XXX',
                                          startTime: '06:00',
                                          endTime: '20:00',
                                          destinations: [
                                                  destination: 'XXX',
                                                  label: 'XXX',
                                                  hideDays: [0,6],
                                                  mode: 'driving',
                                                  alternatives: true,
                                                  showSummary: true,
                                                  color: '#82E5AA'
                                                  destination: 'XXX',
                                                  label: 'XXX',
                                                  mode: 'driving',
                                                  alternatives: false,
                                                  showSummary: false,
                                                  color: 'lightblue'
                                          maxCalendarEvents: 2,
                                          calendarOptions: [
                                                  mode: 'driving'
                          • W
                            wagon40
                            everything else is working time, personnel calendar and weather. my commute shows error in red on the side. does show that it is continuing to update. any suggestion?
                            			module: "MMM-MyCommute",
                            			position: "bottom_bar",
                                				apikey: 'google api key',
                                				origin: ' Rd, city, state zip',
                                				startTime: '00:00',
                                				endTime: '23:59',
                                				destinations: [
                                   				 	destination: ' Ave, city, state zip',
                                   				 	label: ' Work1',
                                   				 	mode: 'driving',
                                    				color: '#82E5AA'
                                   				 	label: ' Work2',
                                   				 	mode: 'driving',
                                    				color: '#82E5AA'
                            W 1 Reply Last reply
                            • W
                              wagon40 @wagon40
                              @wagon40
                              I checked the apikey and Google is showing a count of apikey request. So that leads me to believe that it is a MM issue or module issue. Any help would be be great.
                              E 1 Reply Last reply
                              • E
                                Egnos @wagon40
                                @wagon40 said in MMM-MyCommute:
                                @wagon40
                                Hello to all,
                                I have the same problem as @wagon40 , can you help us?
                                The log of the MM shows:
                                [13:48:15.263] [LOG]    MMM-MyCommute: This API project is not authorized to use this API.
                                [13:48:15.268] [LOG]    MMM-MyCommute: This API project is not authorized to use this API.
                                I use the same Google API that uses “MMM-GoogleMapsTraffic” … could it be the cause of the problem?
                                Thanks a lot!
                                • E
                                  Egnos
                                  Is anybody there? 🤔
                                    sdetweil @Egnos
                                    @Egnos
                                    seems pretty clear… the api Project you selected, doesn’t authorize use of the API…
                                    open the google developers console, find the api project and check for the api… maybe Javascript
                                    • E
                                      Egnos @sdetweil
                                      @sdetweil said in MMM-MyCommute:
                                      @Egnos
                                      Dear @sdetweil.
                                      Thee same behavior also has it @wagon40, I thought it was something about the module…but if you’re sure it’s just an API problem … I’ll do a check!
                                      Thanks.
                                        banbutcher
                                        so Ive installed MyCommute and activated the directions api in google and Im getting this error in log…
                                        [14:09:09.679] [LOG] MMM-MyCommute: You must use an API key to authenticate each request to Google Maps Platform APIs.
                                        Im using the same API key for GoogleMapsTraffic.
                                        heres my config section:
                                        // My Commute Start
                                        			position: "bottom_right",
                                            				apikey: 'API - Key',
                                            				origin: 'Start Address',
                                            				startTime: '07:00',
                                            				endTime: '23:30',
                                            				destinations: [
                                               				 	destination: 'Destination',
                                               				 	label: 'Engine Center',
                                               				 	mode: 'driving',
                                                				color: '#82E5AA'
                                               				 	label: 'WHE - Office',
                                               				 	mode: 'driving',
                                                					color: '#82E5AA'
                                        any ideas?
                                          sdetweil @banbutcher
                                          @banbutcher you have to sign on to the Google API console and enable the API.
                                          And u must enter a credit card as part of that.
                                          B 1 Reply Last reply
                                            banbutcher @sdetweil
                                            if your taking about the API for directions, ive already done that. have entered credit card details too, needed that for GoogleMapsTraffic.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
