    MMM-MyCommute
    286 Posts 80 Posters 741.2k Views 77 Watching
    • K
      keyun21
      Newbie here I guess i have to pay for Google API service right? without that this module not going to work correct?
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @keyun21
        @keyun21 You have to set up a pay account, including a credit card, but they give you a specific number of free accesses, and if you keep the module to a timeframe that you’d normally look at it, you’d have a hard time exceeding those uses.
        K 1 Reply Last reply
        • K
          keyun21 @BKeyport
          @bkeyport said in MMM-MyCommute:
          Thanks a lot I will look into to see how many I can get free and how to set up module to run specific times?
          • A
            Aries1984 Module Developer
            Hi everybody,
            sorry for the late reply. Haven’t been here much in the last couple of weeks. Here’s my config:
                    module: 'MMM-MyCommute',
                    position: 'bottom_right',
                    header: 'Traffic',
                    classes: 'default everyone',
                        apikey: 'your API Key',
                        origin: 'Marienplatz 1, 80331 München',
                        startTime: '05:00',
                        endTime: '10:00',
                        hideDays: [0, 6],
                        destinations: [
                                destination: 'Belgradstraße 13, 80796 München',
                                label: 'Good Food',
                                mode: 'driving',
                                color: '#82E5AA'
              seanluse41
              Can this module support Japanese addresses?
              The default config and values work for me, but putting in Japanese addresses returns loading… forever.
              • T
                thoeng
                This is great and very practical module! Everything is working on me but i would like to remain below USD200 (40K calls)/mo API call request. This means staying below 1.3K calls/day
                However, after installed I can see 570+ request call in 2 hours on Google API dashboard. This is despite setting pollFrequency: 1200000 (20mins interval) on MM config.
                Any help please?
                I 1 Reply Last reply
                  charp07
                  MM is only loading the “loading…” text for this module. All my other modules are showing right. I am getting request on the Google API Console under the Directions API. So I believe that I must have the module installed correctly. Does anyone know why this would be happening?
                    charp07
                    			apikey: 'my api key from google',
                    			origin: '65 Front St W, Toronto, ON M5J 1E6',
                    			startTime: '00:00',
                    			endTime: '23:59',
                    			hideDays: [0,6],
                    			destinations: [
                    				destination: '14 Duncan St Toronto, ON M5H 3G8',
                    				label: 'Air Canada Centre',
                    				mode: 'walking',
                    				color: '#82E5AA'
                      in the MagicMirror folder do
                      npm check:config
                      fix 1st error, repeat
                      I think it is the comma after the only destination
                      				color: '#82E5AA'
                      loading …
                      is the default message many modules put up while getting their data
                      but it failed to get the data
                      so, this means there was an internal error in the module code
                      open the developers window
                      (either npm start dev, or use ctrl-shift-i when mirror is running)
                      select the console tab, and scroll up to locate any errors, usually red text
                      C 3 Replies Last reply
                        charp07 @sdetweil
                          charp07 @sdetweil
                          @sdetweil okay, I’m new but the check:config command is not valid. So tried npm config and it brought up 10 errors.
                          Usage:
                          Npm config set
                          Npm config get …
                          Etc
                          Etc…
                          What does this mean?
                            charp07 @sdetweil
                            @sdetweil also added comma to that location with no success. Then moved to behind bracket and nothing there either.
                              sdetweil @charp07
                              @charp07 sorry, I get that command backwards
                              npm config:check
                              • I
                                interman @thoeng
                                @thoeng I ran into the same problem. there a few things you can do.
                                1. Set the time that the module comes on and goes off. For example, I set my mine from 5:00 am to 8:00 am.
                                  startTime and endTime
                                2. Hide the module on weekends. Mine does not come up on the weekends. hideDays
                                3. Change how many times it goes to google with a request. pollFrequency
                                4. add a cheap motion sensor to turn the display on and off (getting one now).
                                Hope that helps.
                                Dn
                                  charp07
                                  I swapped to a newer branch of “MMM-MyCommute”. After install, it booted up on the first try. Happy that it is now working. Thanks to all the authors of this module.
                                    JRB1988
                                    Will this module still be updating in the background during the hidden times? With the Google API, I wouldn’t want it updating when I am not needing it. Thanks!
                                    T 1 Reply Last reply
                                    • T
                                      trawson
                                      Is anyone else having issues with the MyCommute module hiding itself but then not re-appearing.
                                      I have EndTime setup for 8pm and also HideDays on certain days, however, once it hides, it stays hidden. Until I force it to show using the Remote module.
                                      Otherwise, this Module works great, showing all the traffic times as it should.
                                      • T
                                        trawson @JRB1988
                                        @JRB1988 From my experiences, I don’t believe it does.
                                          smoysauce
                                          Hi I have gotten this module setup and working with destinations (see below), but am trying to get it to show times based on locations of calendar events setup like at the end of the help page but it doesn’t seem to want to show. Am I missing something? My calendar shows my events and locations but not sure if MyCommute is pulling it. I even used the example code from the module Git page and it still didn’t pull anything. Does this not work anymore? Any insight would be much appreciated!
                                                  position: 'bottom_left',
                                                  header: 'Traffic',
                                                          apikey: 'XXX',
                                                          origin: 'XXX',
                                                          startTime: '06:00',
                                                          endTime: '20:00',
                                                          destinations: [
        destination: 'XXX',
        label: 'XXX',
        hideDays: [0,6],
        mode: 'driving',
        alternatives: true,
        showSummary: true,
        color: '#82E5AA'
        destination: 'XXX',
        label: 'XXX',
        mode: 'driving',
        alternatives: false,
        showSummary: false,
        color: 'lightblue'
                                                          maxCalendarEvents: 2,
                                                          calendarOptions: [
        mode: 'driving'
                                          • W
                                            wagon40
                                            everything else is working time, personnel calendar and weather. my commute shows error in red on the side. does show that it is continuing to update. any suggestion?
                                            			module: "MMM-MyCommute",
                                            			position: "bottom_bar",
                                                				apikey: 'google api key',
                                                				origin: ' Rd, city, state zip',
                                                				startTime: '00:00',
                                                				endTime: '23:59',
                                                				destinations: [
                                                   				 	destination: ' Ave, city, state zip',
                                                   				 	label: ' Work1',
                                                   				 	mode: 'driving',
                                                    				color: '#82E5AA'
                                                   				 	label: ' Work2',
                                                   				 	mode: 'driving',
                                                    				color: '#82E5AA'
                                            W 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
